![]() Join Date: Apr 2014 Location: Brisbane, QLD, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 225
(Thread Starter) | Not Ranked : 0 score Hi All, I have a problem with my CX7 but I am putting it here because it is a general issue and I hope more people see it here and can help. I have just installed a K04-882, JBR 3.5" WPI, ETS intercooler and a Stratified Base Map to suit. My mod thread is here Seen the light and modding CX7 for more power The car is running rich on WOT runs and Lex suspects a boost leak. I need to fix this before we continue with tuning. I have attached the initial third gear log in Virtual Dyno format which shows AFR decreasing from around 11 to around 9.5. After finding this I read up all the threads on finding boost leaks and made myself a boost leak detector. Here it is installed in the end of the WPI. I used a regulated air supply of around 30psi from my compressor and a tyre inflation gauge. Untitled by ozynigma, on FlickrThe first thing I found was my Cobb XLE was dumping boost at about 10 to 12psi. I found this with the BPV return hose disconnected from the BPV and plugged. I put the OEM BPV back on and was able to get close to 20psi before leaking boost. I figure the Cobb needs a stronger spring. i don't know why the previous owner had it set so weak. I also found the intercooler boost tubes needed tighter clamping. At this point I was pressuring the whole intake to around 20psi and the only leakage I could detect was around the PCV hose from the valve cover to the WPI. As this is not normally pressurised I didn't try and fix it. I then did another uphill log run in 1st, 2nd and 3rd gear. The second gear portion of the log is attached. The AFR performance was better dropping from around 11.5 to 10. I have also attached the VD boost and AFR graphs. The car is a lot more drivable with the OEM BPV back on. What else can I do to find and fix the rich running under WOT? Have I done anything wrong in the boost leak testing? Even with the PCV plugged on the WPI I was still getting pressure leaking from the valve cover. I assume this is getting through the throttle body, manifold, valves and down past the rings?
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified |
(Thread Starter) | Not Ranked : 0 score Edit. BTW the boost tubes are SURE. Sorry but they came for free with the ETS intercooler and I like the colour blue. If anyone seriously thinks these are the issue I will put the stock boost tubes back on.
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
| Not Ranked : 0 score Did you check the PCV hose on the manifold for leak (its in between the manifold and block)? Did you check ''commanded AFR'' versus ''actual AFR'' when logging...the CX-7 tuning is wicked...I found some very weird thing while going over all tables
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement Last edited by torquemaniac; 09-27-2014 at 05:22 AM. Reason: MSF Database - Automerged Doublepost |
No I have not logged "commanded AFR" yet. I was assuming that the map is commanding appropriate values hence Lex concern at the running richer than expected. It is not an OTS map, it is specific to my mods. You make an interesting point though that the CX7 ECU might be handling the commanded values differently to a 3 or 6. After all Versatuner is the only company to have cracked our ECU's.
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified | |
You absolutely need to log ''commanded AFR'' and ''actual AFR'' before suspecting a leak...if ''actual AFR'' is the same as ''commanded AFR'', you have no leak FYI, Mazdaedit also has a software for the CX-7 epifanSoftware | mazdaEdit I know a tuner that tune any Mazda with this software (Pro license...)
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement | |
| Not Ranked : 0 score Tell Lex that you did the leak test and that you feel everything is buttoned up. He may just need to touch up the fuel curve now. |
![]() Join Date: Dec 2013 Location: Pinckney, Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 794
Groaned at 8 Times in 3 Posts
| Not Ranked : 0 score Are your afr's high ten's @ wot? If so I'd have to think that's normal depending on gas type. I've working with rob @ freek and my afr's were dipping into high 10's @ wot. Switching gas stations helped. I'm right on target now. What were your afr's like before you installed everything?
__________________ 2011 MS3 COBB AP/Hypnotic Tuned/JBR 3.5in WP/CS Wiper Delete/EBAY DP/CS RMM/CS Lowering springs/Maisonvi shift bushings and knob/OBX Catback/AT Internals/Synapse DV/ CP-E TMIC/E30 |
Edit: For clarity the worse was with the stock TMIC reinstalled with no testing of connections and with the Cobb BPV installed and the OEM tune. So it wasn't before all mods were done.
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified Last edited by Ozynigma; 09-27-2014 at 03:59 PM. | |||
| The Following User Says Thank You to Ozynigma For This Useful Post: | torquemaniac (09-27-2014) |
(Thread Starter) | Not Ranked : 0 score I did another second gear log up hill today. I have attached the log file. I can provide another log file with more parameters if required. It starts a bit high in the rev range, my son was a bit slow to hit record. The actual AFR is running about 0.5 to almost 1 below the "desired"/"commanded" AFR. There are no obvious leaks between the turbo and the manifold. The thing that is bothering me is that my crankcase seems to be pressurised with pressure escaping through the cam cover PCV. Does this indicate my crank case PCV check valve has failed and is letting manifold boost pressure into the crankcase? I was hoping not as the manual says I have to remove the intake manifold to remove and check the PCV check valve. If it is the check valve should I replace with OEM or rig up something more effective on that line? Someone over here in Oz was making up stronger check valves to use with bigger turbos and oil catch cans.
A catch can setup is always a good thing, especialy with more boost (more blowby) and if the EGR is still connected (blowby + EGR = gunk buildup)
Thanks I read that thread and a few others a few days ago. I have just ordered a new PCV check valve for like $16 from Mazda. I retested this morning and I have reduced leaking from the top PCV hose. I still can't get more than about 15 psi to hold as measures on my dodgy tyre inflation gauge. Why do they go to 150psi and have poor graduation and precision to 30psi? I think I may have enough in the kitty to buy an OCC. There is a used CS one going cheap here on eBay but only the can and bracket no valves or hoses or clamps. I will have another look at the JBR and Matt Damond ones. I think one of them does CX7 specific hoses.
| Not Ranked : 0 score The key is getting one with a check valve.
| Not Ranked : 0 score I told you...to make it work with a tire inflation pump, you need ''da pink pyjamas'' ![]() AS for the catch can, the best ones have media to help catch oil (non-media CC have about a 30% efficiency)
(Thread Starter) | Not Ranked : 0 score Thanks for your input. The Matt Damond one has a check valve standard. The JBR has it as an added cost option. The MD is under $200.
Both MD and JBR do hose kits the right length for the CX7 with their catch cans. I almost ordered the MD OCC yesterday but ordered an Aussie made check valve from an OzMPS forum member instead. This should help me solve the immediate check valve problem this week as I will be waiting about 3 weeks for shipping after I order the catch can. I think I have figured out my BPV problem. I don't think the Cobb has a problem. I used a scale to test it and it is taking about 8psi pressure differential to move the piston and 18psi to open it fully. So the fact that I was generating the 8psi pressure differential at around 12psi boost pressure indicates I might have a leak from the vacuum/boost hose connection from the manifold to the BPV. So the plan is to get the improved check valve tomorrow hopefully and pull the intake manifold and replace the check valve and check the BPV hose connection.
| The Following 3 Users Say Thank You to Ozynigma For This Useful Post: |
| Not hitting boost targets, not boost leak | ADHDAdditiv | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 28 | 07-18-2014 02:18 PM |
| Not hitting Stage 2 boost targets (boost leak?) | Bubba Ho-Tep | 2010 MS3 - ECU Computer Tuning | 15 | 04-26-2012 08:25 PM |
| Help a Dummy (finding boost leak) | helmetface | MazdaSpeed 3/6 - Turbo Induction | 12 | 05-24-2011 04:57 PM |
| Vacuum leak, but no boost leak? | vbt101 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 23 | 04-18-2010 01:06 PM |
| Finding Source of Oil Leak, Are Octane Ratings Real?, Bearing Problem on Honda Civic, HCCI Engine, Another Bogus 'Gas Sa | Haltech | Automotive News | 1 | 07-11-2008 06:13 PM |
