![]() Join Date: Aug 2013 Location: Grand Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score I'm currently running an AEM Truboost(which sucks) Can I run this turbo with the stock BCS until I get a Grimspeed 3 port? What are the disadvantages to doing this? Do I need to do anything different? Any restrictor pill? Thanks |
![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,824
Groans: 75
| Not Ranked : 0 score I think its fine. Someone like @Lex; could say for sure. I made my own 3 port for pretty cheap. Hit me with a PM since you are local and I might be able to help save you some cash.
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC |
![]() Join Date: Apr 2013 Location: Tonawanda, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 74
| Not Ranked : 0 score Just ran into a similiar issue, why not run Wastegate spring pressure only? Run a line from boost source to wastegate top nipple (check this to make sure). How to route your BCS lines 2 and 3 port, iwg and ewg ^^ should get you on your way edit: this is temporary until you get your 3 port; and you should feel out your boost first to make sure you aren't overboosting if your wastegate is F'd
__________________ Koni Yellows / Eibach Pro Springs / CX & Treadstone FMIC / HTP 3.5" / PowerSlot Rotors / Moog Rear Endlinks / ProSport Boost Gauge / CP-E Defrost Vent Pod / Autotech HPFP / Cobb AP V3 / BNR S1->S3->Modded S3 / CP-E Stage 2 RMM / JBR Boost Tubes / JBR Recirc Tube / JBR EGR Block Off / |
| Not Ranked : 0 score The most effective way to run with the stock ebcs is to add the Stratified boost dial. Otherwise you won't be able to increase boost pressure much over spring.
(Thread Starter) | Not Ranked : 0 score Hmmmm upon further inspection, could I use the AEM solenoid? It's a MAC. It looks decent. How would I wire it to the stock harness. I'm at work so I'm gonna look into it tonight. |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,870
Search for diy 3 port ebcs tapping.... tap tap
tapping.... tap tap
__________________ 08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock! 99 Miata NB - Stock for now Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors Last edited by DSIT995; 09-09-2013 at 11:25 AM. Reason: MSF Database - Automerged Doublepost | ||
(Thread Starter) | Not Ranked : 0 score Can't I just use my stock bcs harness clip? Somehow? |
| Not Ranked : 0 score The AEM solenoid should work fine. You just need to either source a connector or splice into the OEM harness. The OEM BCS doesn't have a removable connector.
Ill post pics in a few. It actually turned out nice ![]() I think I'm all set. Just ordered a new boost gauge cause the truboost gauge is useless without the bcs. So as soon as that arrives, I'll be able to start tuning this thing. It's running a map from Ptuning and boy does it suck. I can feel that it's being held back. The timing is just so low. I can't wait to get some power out of this thing. | |
| BT opinions, ATP GT3071r, relatively stock MS3 | Dark | MazdaSpeed 3/6 - Big Turbo Builds | 24 | 11-15-2010 10:42 AM |
