 Old 05-22-2009, 09:26 AM   #1
06speed's Avatar
Posts: 96   (View Stats)
06speed will become famous soon enough
Groaned at 25 Times in 7 Posts
Default greddy type s bov
today i installed my new greddy type s bov and i was wondering if anyone else has or have had that same bov and was it easy to adjust.
06speed is offline   Reply With Quote
 Old 05-22-2009, 09:47 AM   #2
MTuning's Avatar
Posts: 362   (View Stats)
MTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond repute
Groaned at 16 Times in 8 Posts
peace out
MTuning is offline   Reply With Quote
 Old 05-22-2009, 11:41 AM   #3
jay32m's Avatar
Posts: 161   (View Stats)
jay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant futurejay32m has a brilliant future
I have the type s on mine and have had it for almost a year now and I love it. Like MTuning stated you have to loosen and tighten until you don't get any compressor surge and make sure it holds boost. One thing that you will have to look out for is that mine did rub the plastic under the hood but I easily fixed that by turning the purple head around and the problem was solved.
Cobb SRI // Cobb AP // SU Turbosmart BOV // CNT Catless TBE // PG FMIC // SU RMM // JBR PMM 70D // TWM Shifter Bushings // Eibach Pro Kit // Sensen Struts/Shocks // 18x7.5 Konig Countersteers // Moddiction Anvil 2 knob // Autotech Internals
jay32m is offline   Reply With Quote
 Old 05-22-2009, 11:54 AM   #4
06speed's Avatar
how many springs did your bov come with because mine only had one the one that came in it.
 Old 05-22-2009, 04:41 PM   #5
bnoon's Avatar
Posts: 1,770   (View Stats)
I had a "fake" type S valve on my old air/water and loved it. I will most likely use one again with the new air/water.
Just start at the low setting and adjust it up until the BOV sound goes "cha cha cha chaaaaaaa" a bit, then loosen it back up until it just goes "chaaaaaaaa" nice and smooth.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
 Old 05-24-2009, 09:29 AM   #6
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
the TYPE S comes with two springs. it seems the person you bought it from did the "Single Spring Mod" to keep the Bov from causing compressor surge. I would contact them back to make sure you get the other spring just to have it on hand
i have a TYPE S and have never had a problem with Compressor Surge. i have been running both springs the whole time. i switched to the single spring mod but there was no change in performance since i never had a problem running both. so i put the spring back in.
http://www.evomoto.com/tech_info.php?tPath=1&tech_id=7
"Tuning"
i would start by tightening the screw to the hard side to where a 1/3 of the screw is sticking out. never adjust the screw while the nuts are tight. make sure to loosen them
then adjust from there. drive the car, if you are getting poping when accelerating hard. then the BOV is too "hard." loosen it a bit..
just drive and adjust, drive and adjust. thats what i do.
just to let you know, to get closest to that "TYPE S VTA" sound while in recirc. my BOV has to be tuned to the hard sid emore than anything.
but the result is a Great pop off sound but the car runs a bit richer.
my car wouldnt pop inbetween shifts but it would pop during WOT or when i would shift into the next gear. it would pop upon getting on the gas here and there
hope this helps
2015 Mazda 6
 Old 05-19-2010, 08:18 PM   #7
ajjohnson4's Avatar
Posts: 9   (View Stats)
ajjohnson4 is an unknown quantity at this point
I'm
haveimg problems with my rs. To
loose or to tight the only sound I
get is a low wired sound at mid throttle
now and then like sucking air
ajjohnson4 is offline   Reply With Quote
 Old 05-20-2010, 03:56 PM   #8
theschrum's Avatar
Posts: 1,031   (View Stats)
I love my Greddy type S. Adjusting was easy, but make sure you loosen the jamnut before you turn the bolt or the threads will get stripped (common problem w/ this BOV).
 Old 05-20-2010, 05:57 PM   #9
FenixTX717's Avatar
Posts: 246   (View Stats)
FenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant future
I've had my type-s since 06 and haven't had problems with it. Did the single spring mod and when I put new springs in because the new springs, having both of them, were way to tight.
Another good BOV that is the same if not better than the old type-s is the NGR or NRG bov. My buddy has the that one and we took them apart and the diaphram in the NGR(NRG) was much better than the type-s which has been known to fail after being used for awhile.
BUT easy fix is just replace the diaphram for it. Easy.
FenixTX717 is offline   Reply With Quote
 Old 04-10-2013, 01:03 PM   #10
blackspeed223's Avatar
Posts: 54   (View Stats)
blackspeed223 is a glorious beacon of lightblackspeed223 is a glorious beacon of lightblackspeed223 is a glorious beacon of lightblackspeed223 is a glorious beacon of lightblackspeed223 is a glorious beacon of light
Just got my bob today and was wondering how u guys installed urs when it came to the recerq hose? Cuz i blocked mine off but read else where on here that it threw a cel after a bit... Is this true?
blackspeed223 is offline   Reply With Quote
 Old 04-10-2013, 01:13 PM   #11
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
Holy thread revival batman!!!!
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 04-10-2013, 01:17 PM   #12
Haha I knew this would stur the pot!!! I did the noob thing and searched and found this. I only ask because I don't wna throw a cel and wna be sure cuz another thread said it would... But my buddy had one on his wrx and we did the same thing and it was fine.
 Old 04-10-2013, 01:29 PM   #13
dale_gribble's Avatar
Posts: 4,720   (View Stats)
At first I was thinking, holy shit a n00b did a search on their own and found an old relevant thread. Then I realized you want to do full VTA.......
Keep searching. You're doing it wrong.
MINI H1 6.0 - CAR LED TAILS
 Old 04-10-2013, 01:34 PM   #14
darth_speeder's Avatar
Posts: 653   (View Stats)
darth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the world
inb4mylittleponythread
[SIGPIC][/SIGPIC] Corn Fed//Richtuned
darth_speeder is offline   Reply With Quote
 Old 04-10-2013, 05:10 PM   #15
Mommy everyone is picking on me!!! lol ok typical noob mistake i rushed into it and went the ricer way because i wanted the sound... its been so long since ive had my hands on a car to tune and add things to i guess i jumped the gun! (F-ing BROWNIE!!) So in other words that stupid thing is coming off and im meeting up with a guy who sold his MS3 and is getting rid of his COBB SRI!
 Old 04-11-2013, 07:41 PM   #16
sidekick's Avatar
Posts: 3,093   (View Stats)
That SRI will give you all the noise you want, even with the OEM BPV. At least you searched... That's more than we can say for most brownies. Lol.
greddy type R will it fit? Buildabong MazdaSpeed 3/6 - Turbo Induction 16 10-17-2008 02:45 PM
greddy type rs 5mm 1/8" pt vacc nipple part number skeeter149 MazdaSpeed 3/6 - Turbo Induction 0 07-06-2008 07:59 PM
Page generated in 0.35565 seconds with 32 queries
