  • 1 Post By
 Old 03-18-2014, 01:23 PM   #1
King Scumbag's Avatar
Posts: 2,384   (View Stats)
Originally Posted by XerocX View Post
Hello I just bought this GFB respons with the high boost whistling trumpet, I am running it full VTA using the guardian angel, the thing is that it's whistling while I'm on throttle, isn't it supposed to only whistle when blowing off?? Please help if you know what is the problem, thank you.
I would go back and check your spring adjusment. GFB has a video on adjusting the RESPONs. If spring pressure is loose or too tight not sure which one i belive is can result in it staying open constantly. That or your just hearing your turbo.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
Question!! Djlovesspeed Wheels & Tires - BLACK 4 05-08-2013 10:52 AM
HID Question iammike 2010 MS3 - Car Audio & Electronics 11 12-21-2012 05:31 PM
New guy with a question Renegade Mazdaspeed3/6 General Discussion 19 05-30-2011 05:20 AM
mbc question boostislove 2010 MS3 - Turbo Induction 42 11-28-2010 10:00 PM
BPV question shobiz89 MazdaSpeed 6 - Engine, Transmission & Driveline 8 03-19-2009 10:25 AM
Page generated in 0.23036 seconds with 21 queries
