![]() Join Date: Mar 2016
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Not sure what my options are if the cold air doesn't fit do i have to buy a short ram intake? At that point am i better off speeding the extra bit and buy crock sports FMIC with true ram air TMIC replacement Looking to do it for cheap but not half assed Sent from my SM-G920W8 using Tapatalk |
![]() Join Date: Jun 2014 Location: Rolling Meadows, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42
| Not Ranked : 0 score I would say do some more research because practically all of the FMIC kits available out there have some sort of different routing in the engine bay. I see the CX Racing FMIC piping a lot with a TR8 core and your choice of crash bar. Usually that combo should leave you with enough room for your cold air intake. I'd say this route is a better option. Or you could even get the JBR under piping kit and route the pipes under the engine, which mean more room up top. This is why I'm saying to review all the options because every manufacturer has a different way of routing. I think the only one that may not fit with a cold air intake is the Cobb FMIC because they pipes go down where the intake goes, but I'm not 100% sure on that.
__________________ 2011 Mazdaspeed3 Mod List: FREEKTUNED ETS TMIC Autotech HPFP Internals CS Stage II SRI + TIP Tial QR UR Catback UR Catless Test Pipe Damond RMM Damond SSP |
Sent from my SM-G920W8 using Tapatalk | |
| Not Ranked : 0 score I think the CX Racing piping goes down in front of your dipstick, so you should be okay with that. There should be a DIY on that somewhere on here so you can see how it's routed, maybe in the Gen 2 section, but I'll leave that for you to look up .
![]() Join Date: Jul 2016
| Not Ranked : 0 score I have Cobb fmic with injen cai so it will fit |
| The Following 2 Users Say Thank You to Tech168 For This Useful Post: | blackms3_71 (07-26-2016), Djohns (08-04-2016) |
| Not Ranked : 0 score I would say not to worry about the CAI and get a regular, high flow filter and intake. The temperature difference you see with the CAI is almost meaningless as soon as the air hits the turbo, gets compressed, heats up 150 or more degrees, then gets cooled down by the intercooler etc. I'm a big fan of upgrading the TMIC and spraying Meth. Best flow and cooling of all worlds
__________________ Max Bolted and Built Stock K04 |
| The Following User Says Thank You to sheston For This Useful Post: | MS3Shadow (07-26-2016) |
![]() Join Date: Apr 2011 Location: La Grange, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score I had an ATP FMIC and Cobb SRI. It fit fine.
__________________ 2007 Red MS3: 4" ported PTE 5858, HTP intake, HTP undermount, Treadstone TR8, HKS BOV (VTA), Custom exhaust mani, V-band dp, CNT exhaust, ACT clutch, ACT 6-puck PP, Damond PMM, RMM & TMM, Koni yellows, Eibach prokit springs, Damond OCCs (vented & not). |
| Not Ranked : 0 score I say build your own front mount! I built mine and saved a ton of money even after having the pipes powder coated.
| The Following User Says Thank You to Djohns For This Useful Post: | robbspeed (08-04-2016) |
![]() Join Date: Sep 2015 Location: Monongahela PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
Sent from my LG-H820 using Tapatalk | |
| Not Ranked : 0 score Making a piping kit with pvc first so it's not so much of a trial and error. Take those measurements and try to find pre bent piping. I was lucky because my dad has access to a pipe bender at work.
| Not Ranked : 0 score If I recall correctly it was around $400.
| Cobb FMIC vs Exhaust Depot FMIC | mrjoshyman | MazdaSpeed 3/6 - Turbo Induction | 44 | 04-20-2009 10:30 AM |
