 Old 03-02-2009, 06:47 AM   #1
wassup61's Avatar
Posts: 1,232   (View Stats)
wassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the world
Originally Posted by ptperformance View Post
Water over air and be done with it.
Don't you mean air over water? Yes, this is a good option for drag cars or cars that are driven in consistently HOT climates (desert etc.) However, for daily drivers in mixed climates, there is too much too much work involved to have it on a daily driver.
Things like leaky cores/frozen cores are common in colder climates (in Chicago, we have a daytime temp of 45-50 and then bam 17 degrees-FUCK WINTER.) If you run distilled water the cooling is great, but it WILL freeze and then you have a problem. Running coolant is an option, but to realize the full benefit from the heat capacity of water, you have to run distilled, and purging the system day to day such as in my climate is a HUGE pain in the ass.
FMIC/TMIC is a good, low hassle option, that in combination with meth can generate ambient or below ambient boost temps.
-Jeff at PG
All wagon, No traction
wassup61 is offline   Reply With Quote
Cobb FMIC vs Exhaust Depot FMIC mrjoshyman MazdaSpeed 3/6 - Turbo Induction 44 04-20-2009 10:30 AM
Cabinet choices show Obama warms to action on climate Haltech Automotive News 0 01-18-2009 10:10 PM
downpipe choices cgburton12 MazdaSpeed 6 - Engine, Transmission & Driveline 19 09-01-2008 02:19 AM
Cobb Ap FMIC map with Cobb FMIC not driveable Unoriginalusername MazdaSpeed 3/6 - ECU Computer Tuning 119 07-20-2008 08:40 AM
Page generated in 0.23587 seconds with 21 queries
