![]() | | #41 | ![]() |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
| Not Ranked : 0 score -Nancy Pelosi
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts |
| The Following 3 Users Say Thank You to smoogs12 For This Useful Post: |
![]() | | #42 | ![]() |
![]() Join Date: Dec 2013 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 60
| Not Ranked : 0 score Since someone already revived this thread I have a question. Currently running blue two shims but installing my gtx3071 Saturday. Should I be changing to a different spring or should I ask my tuner? Hate to bother him with questions not pertaining to my tuning (install stuff).
__________________ 2011 Speed3 Tech- GTX3071 EWG Ceramic Coated hotside - ATP DUMP - TIAL 38MM External Wastegate - HTP 3.5" Full intake - COBB DownPipe - 3 Bar Map w/ FastBits Adapter - Grimmspeed EBCS - Forge V2 - JBR Battery Tray - 51r Battery - Matt Damond VTA OCC - Matt Damond Full EGR Delete - Denso Step Colder Plugs - Treadstone TR6 - CX Piping Modded for gen2 - JBR SSP/Solid Bushings/Heavy Knob - JBR RMM - SURE TMM - SURE PMM - AutoTech Internals - AP v2 Tuned BY NISHAN - Sonic Tuning S3 Coilovers - SPC Camber Arms - TSW Intelagos Rotary Forged - Conti Extreme DW - StopTech Pads - SouthBend Stg 2 Endurance - FUTURE MODS Built Bottom End - 5th Port - Meth - Exhaust Manifold - CatBack Exhaust - Slicks |
![]() | | #43 | ![]() |
![]() Join Date: Jun 2015 Location: Abington MA
Rep Power: 0 ![]() ![]() Thanks: 7
| Not Ranked : 0 score So I have also just got my forge v2 bpv. I'm seeing a lot of blue spring talk for the speed 3 and since they're the same engine I'm wondering if I need to use that as well. Blue spring one shim? Is that the consensus on completely stock besides accessport? I'm running like 17 psi. I am not hearing any whoosh noise at all. Used green and yellow springs. |
![]() | | #44 | ![]() |
| Not Ranked : 0 score Blue two shims as posted many times.
![]() | | #45 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
| Not Ranked : 0 score I used red spring. But I was at 24 psi. Blue spring, 2 shims is the general consensus.
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress |
![]() | | #46 | ![]() |
![]() Join Date: Feb 2015
Rep Power: 0 ![]() Thanks: 0
| Neutral : -1 score Ok so I know everyone posts about blue 2 shim and all that but now with accessports with tuning and all all if your a little of stock boost like 16.5 and a little up should blue and one shim be best or just no shims or start using yellow spring. I know I read all the comments but I just want to know lol sorry |
| The Following User Says NO Thank You to Chris1208 For This Un-useful Post: | Addikted To Boost (09-11-2015) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/forge-boost-bypass-valve-spring-shim-11573/ | ||||
| Êóçíèöà ÁÏ è ïîâûñèòü ãåðìåòè÷íîñòü âîïðîñ - Ñòðàíèöà 2 - Ôîðóìû Mazda 6 Mazda 6: Ôîðóì / Ôîðóì Mazda Atenza | This thread | Refback | 06-01-2015 09:44 AM | |
| Forge BPV and boost leak question - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-27-2014 07:10 AM | |
| Forge BPV V2 maintenance. | This thread | Refback | 03-29-2012 01:39 PM | |
| FORGE WGA | TRU-BOOST | MazdaSpeed 3/6 - Turbo Induction | 119 | 06-20-2011 11:29 AM |
| Possible track spring spring setup for use with Koni yellows | stretch | MazdaSpeed 3/6 - Suspension & Brakes | 154 | 04-18-2011 12:18 PM |
| Forge VTA | TurboMazda1313 | MazdaSpeed 3/6 - Turbo Induction | 9 | 06-27-2008 04:00 PM |
