![]() Join Date: Jun 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score For all you guys that are considering this as an upgrade, mechanically it's like 2.5-3 out of 10. I'm pretty much a noob, and got it done by myself in under 2 hours. A couple of hints for installation: get some cardboard and cover both sides of the ETS before you install, that way it's protected from bumps, tools, and plain bad luck. I would use those same pieces to cover up the stocker TMIC as well, for storage, and tape up the hot/cold side ports. I would also consider doing any intake mods at the same time, and if you're looking to upgrade the driver side trans mount, do that too, since you'll be in the same general area as the TMIC. I would lastly check ALL of your clamps. Mine were tight, but I was lucky, there are some stories floating around of guys w/ weird underboosting, stutter, knock retard etc etc because their clamps weren't tight. If people want an install writeup, I can do one, but sorry no pics, didn't want to grease up my camera. Driving: well, I crudely datalogged, and the ETS definitely takes longer to heatsoak. However, heatsoak it does. Once you get driving though, the boost air temps drop dramatically, and in a hurry, only a couple of seconds to lose 25+ degrees of BAT. The stocker doesn't cool off as much. The drop is even more dramatic at full throttle. AFR's seem stable: 14.7 at idle, 11/12's at full throttle. LTFT's are steady for me, in the 8 range. I recommend this, especially for guys that are starting to fully bolt up. Last edited by red07; 12-02-2008 at 02:34 PM. Reason: getting forgetful in my dotage... |
| The Following User Says Thank You to red07 For This Useful Post: | skeeter149 (12-02-2008) |
![]() Join Date: Sep 2008 Location: Lynchburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,559
| Not Ranked : 0 score sweet i have been eyeballin one of the polished ones on SU but i think they are on backorder... dammit
__________________ 09 MGM MS3 BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score odd you had to take the battery out, but yeah i felt the same about mine. |
(Thread Starter) | Not Ranked : 0 score In retrospect I didn't have to, but I wanted a bit more room to get at the boost tube clamps. I also checked and tightened all the clamps as a precaution, so I pulled it. I had better go edit my first post, now that I think about this more. |
![]() Join Date: Jul 2008 Location: West Des Moines, IA
Rep Power: 854 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score Damn dude, under 2 hour install??? Were you not able to reach the bolts on the clamps or what? I installed a used ETS before I built my air/water setup and it's a 20-30 minute job at most to swap out to another TMIC. Where did you spend most of your time??? I'm not trying to make fun, I'm genuinely shocked...
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall |
| The Following User Says Thank You to bnoon For This Useful Post: | breakfstincluded (09-27-2013) |
(Thread Starter) | Not Ranked : 0 score I know that's damned slow, but at least I'm honest. I was moving slow, and due to this being my first turbocar, I was paranoid about missing steps, so I took care to pull everything off and organize them along the garage wall in order of removal. I also spent time putting away the stocker TMIC, locktited all the bolts, cleaned hardware, looking for sockets, etc. At a guess, total time from walking out to washing hands was 1.5 hours, which is <2. Wait till I try the sway bars, that ought to be a 2-month job based on my (lack of ) skills! |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| Not Ranked : 0 score yeah its a good tmic! you loose less boost vs stock too...
__________________ |
(Thread Starter) | Not Ranked : 0 score Oh nuts, you just reminded me of datalogging boost on stocker vs ETS... Seems to me that I gained ~1# of max boost, which is fine w/ me, the car pulls hard, especially in 3rd/4th. |
| The Angry Goose ![]() Join Date: Jun 2008 Location: Villa Park, IL
Rep Power: 701 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groaned at 9 Times in 6 Posts
| Not Ranked : 0 score I will say it again.....I NEED ME ONE OF THESE! Thanks for the impressions.
__________________ Hector 2014 Mazda 3 2008 Mazdaspeed3-SOLD 1979 Mazda Rx7 |
(Thread Starter) | Not Ranked : 0 score I got lucky timing-wise, John @ PTP had a couple for sale at a very good price new. I believe he's out of them, so I won't post a price, but suffice it to say that it was <$80 shipped over the price of some of the used ones on this board. If you don't *need* one right now, I believe that SU and Protege garage are both working on upgraded TMIC's. When theirs come out, prices may drop on the ETS and/or people will sell theirs off to get the next latest'n'greatest. One of my biggest reasons for getting this vs a FMIC is that it will be a lot easier to return to stock for the dealership visits. |
![]() Join Date: Nov 2008 Location: Michigan
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score ETS is selling the 3.25" for $499 currently on their website, seems like a pretty good price and way lower than the TRZ one thats coming out, who knows how long that sale will last though.
(Thread Starter) | Not Ranked : 0 score 499? That's a good price. The last few used ETS TMIC's were 400-450 IIRC, although in all fairness at least one of them had the powdercoating option. Is that shipped, or is shipping extra? |
![]() Join Date: Sep 2008 Location: USA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 392
| Not Ranked : 0 score I ordered the street unit 3.25 TMIC that's replacing the ETS on their website. It's selling for the old price of the ETS, but I also got the 7% thanksgiving discount. I'm hoping that it will be a quality piece and live up to what I've seen from the company so far.
__________________ 2008 Sunlight Silver MAZDASPEED 3 [SIGPIC][/SIGPIC] MODS: COBB SF SRI, Mazdaspeed CBE 3", Street Unit 62a Rear Motor Mount, Street Unit Shifter Bushings, COBB Shift Weight, Forge Bypass Valve (Blue Shim). |
| Not Ranked : 0 score Sorry, that must have only been a black friday price only its back up to $595 on their website.
(Thread Starter) | Not Ranked : 0 score Ah, well, sorry to hear that for all of you still looking to get this. |
![]() Join Date: Aug 2008 Location: Low Profile, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score What are your other mods?
__________________ The mass of men lead lives of quiet desperation. What is called resignation is actually a lack of boost. Mods: Defi Blue Racer Boost Gauge, 2nd Fiamm Horn (Low Tone) SU Mid-Pipe. Cobb Adjustable Shifter (now "functioning as intended" with 20mm allen bolts and locking nuts), CP-e Nano SRI. Sometime in the not-too-distant future: Airbox (?) and SU/ETS 3.25 TMIC |
(Thread Starter) | Not Ranked : 0 score ETS, MSCAI run as a shorty, AP flash V103B stage 1 + MSCAI, RPMC turbo inlet, TRZ motor mount. |
![]() Join Date: Mar 2008 Location: Canada
| Not Ranked : 0 score ... just a heads-up for ya: Leaking Intercooler at Cold Pipe - Mazda6 / Atenza
__________________ 2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual. |
![]() | | #19 | ![]() |
| Not Ranked : 0 score how does it ride? |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score LBV, I'll have to keep an eye out for that. So far I think it's fine. I did a visual check before install, to make sure I didn't see any pinholes or incomplete welds, and it looked good there. The welds aren't the best, but then again they covered all the seams, so good enough for me. Keeping an eye on the boost shows me steady #'s during idle/cruise, and appropriate boost #'s during WOT. How does it ride? Very well, no fuel cut so far. The coldest I've done a hard run so far was @ 48 degrees in 3rd gear, no cut of any sort, the car pulled hard all the way to 5800, when I ran out of room. Keep in mind I'm running my MSCAI as a shorty, so the underhood temps may very well be keeping the air from being too dense due to the cold. The total combo of my mods gives me boost as low as ~2600-2700 RPM's, although I'm never foot-to-the-floor below 3000, I "squeeze" into the throttle as opposed to violently mashing it straight down. So far max boost I've seen is 17.2 around 4000RPM's. No weird boost spikes (yet). I have to download that datalogging upgrade on my AcessPort and get some hard #'s: boost, AFR, knock retard, boost air temp, fuel pressure. |
| Spy Shots: BMW X6 5.0iS puts the "sport" in "sports activity coupe" | Haltech | Automotive News | 0 | 07-28-2008 06:30 AM |
| Separate "Appearance" from "Wheels/Tires" | KaiserSoze | Website Help/Feedback | 1 | 04-21-2008 08:33 PM |
| Pics Aplenty: MANSORY McLaren SLR "Renovatio" and Ferrari 599 GTB "Stallone" | Haltech | Automotive News | 0 | 04-08-2008 04:20 PM |
| Volkswagen drops "Passat" sticks with "CC" for new sedan | Haltech | Automotive News | 1 | 04-03-2008 04:29 PM |
