![]() Join Date: Jan 2009 Location: PHX/SV AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 772
Groans: 94
Groaned at 43 Times in 33 Posts
(Thread Starter) | Not Ranked : 0 score Hey there just had quick question. Last week here in SV,(5000 Ft. elevation) I was able to hold 20 PSI when the temp was in the low 30-40's... But today It was about 70 degrees and I could barely hit 19 PSI in 2nd and no more than 18 in third. I know nothing is loose. So either A) It's the temp or B) My turbo is starting to go (It has been smoking for about 4 months)
__________________ 321 HP/348TQ-- 13.940 @ 106 /3kft ASL |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score cold air is more dense, so it is not odd that you will see higher boost levels when it is colder out. |
![]() Join Date: Apr 2008 Location: San Diego
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 577
Groans: 38
| Not Ranked : 0 score yes as said cold air is more dense so boost will be higher and you will be running slightly leaner due to more air present. This is PART of the cold weather cut this car gets for some people...it boosts higher and isnt ready for it so it cuts. |
| Not Ranked : 0 score If i dont tweek my MBC for temp changes i can see huge differences. I keep it set at 20psi. If the temp drops below 50 degrees that turns to 25psi real quick !! |
![]() Join Date: Jul 2008 Location: West Des Moines, IA
Rep Power: 853 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score Our weather is up and down so much in winter, I feel like I'm turning the damn knob every other day on my MBC. With my winter tires I'm only set for about 14 psi right now anyway though... and still spin into 3rd. Dang 205's just give it up to easy.
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall |
| Thermonuclear Skeet ![]() Join Date: Jul 2008 Location: Triad N.C.
Rep Power: 3875 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,765
Groans: 188
Groaned at 333 Times in 222 Posts
| Not Ranked : 0 score Maybe I am wrong but I thought that our wastegate regulates boost to a specific number no matter what the temperature is. You may spool up faster but not nessecarily more. Again maybe I am wrong, maybe our cars even alow more boost in the cold due to the less chance of temperature sourced detonation.
__________________ El Fantasmo Del Negro Helicopter Cat LIVES ![]() |
Groans: 38
| Not Ranked : 0 score the WG does regulate boost, but 18psi of hot air is not the same as 18psi of cold air, the cold one is more densely packed with oxygen atoms so even though the turbo is pushing 18psi and thinks it all good the motor is seeing more air due to it being more densely packed with oxygen so it reads higher boost. Thats a basic- not exact -explanation of how I see it. |
![]() Join Date: Aug 2008 Location: Behind the wheel
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score Interesting... there is a thread here where several people, including me have the exact opposite issue -- the colder it gets, the less boost we see. Theory that made the most sense (to me) is that the car does not target a boost level but rather targets a specific load. Well, since colder air is denser air, less boost is needed to reach a target load, if in fact that is how the ECU is programmed. |
| The Angry Goose ![]() Join Date: Jun 2008 Location: Villa Park, IL
Rep Power: 701 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groaned at 9 Times in 6 Posts
I see less boost when cold.
__________________ Hector 2014 Mazda 3 2008 Mazdaspeed3-SOLD 1979 Mazda Rx7 | |
Groans: 38
| Not Ranked : 0 score I spike higher when cold but then it quickly cuts from my fuel pressure dropping and then its lower boost to redline. it is lower boost overall so you guys are right on that.... |
| The Following 2 Users Say Thank You to phantom6294 For This Useful Post: | djuosnteisn (02-27-2009), FantasmoNegro (02-27-2009) |
Groans: 38
| Not Ranked : 0 score well thats basically exactly what I meant, I said how whether hot or cold the turbo always pushes the same psi but the motor see's more air. just didnt use correct terms. The mass air flow will be greater due to the increased density while the turbo is doing 18psi. |
| Not Ranked : 0 score Even on stock boost control my car always sees more boost in the cold. I can tell you this the ecu sure as hell doesnt use the map sensor to determine boost. I had my map clamp set to 2psi and as long as i used stock boost control, i got stock boost levels. I honestly think the map sensor on this car serves only 2 purposes.... 1 to give the ecu an intake air temp reading ti determine proper fueling, because lets face it the temp at the Maf is uselesa on a turbo car. And 2 to trigger overboost cut. |
![]() Join Date: Sep 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 145
| Not Ranked : 0 score stock boost controller will hold stock boost until the wastegate is maxed (on catless exhaust only i guess<---my experience) and then it will start to creep like crazy.
__________________ All wagon, No traction |
Groans: 45
| Not Ranked : 0 score this car basically has 3 different mappings for the throttle which controls boost. it bases it off of requested load, boast air temps, barometric pressure and rpm's. there will be more info on this soon. |
| The Following User Says Thank You to bova For This Useful Post: | djuosnteisn (02-27-2009) |
| Boost Air Temps/Intake Air Temp | Stan-O | Cobb Access Port/Maps | 20 | 05-03-2009 12:55 PM |
| What effect can a hybrid valve have on a map? | builthatch | MazdaSpeed 3/6 - ECU Computer Tuning | 3 | 01-19-2009 01:47 PM |
| Hyundai eyes 'halo' effect from Genesis | Haltech | Automotive News | 0 | 09-17-2008 08:20 AM |
| Boost drops FMIC intake temps? | kingpin748 | MazdaSpeed 3/6 - Turbo Induction | 4 | 07-17-2008 08:57 AM |
