| Banned ![]() Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,321
Groaned at 196 Times in 127 Posts
(Thread Starter) | Not Ranked : 0 score Ok so i put on the FMIC and im not really that happy with it. First off the thing needs ALOT of adjusting to get it to fit right. The throttle body hose clamps will not fit. The battery tray now push up against the inlet pipe. The stock tmic cover pushes up against the hot pipe which pushes up against the ecu black cover tray. The ram intake design sits to high and needs to be literally bent to have the hood closed. Theres no threads on the bov flang. Part of the bumper understray will not fit cause you have to cut the bumper to make it fit, which im not willing to do. One of the pipes rests against the rad in two spots. Overall the fit of this thing SUCKS. Ok so i finish it up and go to start it, starts stumbles and dies. WTF theres no leaks, i try again and again and it eventually starts. Car warmed up and idled fine. Took for a drive and it drives a lil different. Kind of liek on on off switch right were you begin to build boost. The car boosts 17psi and holds it. With the ets it hit 19 and held it... Drove about 15-20 miles so far not problems really. Car feels strong, but im just not happy with it. Well c if i get any lean codes liek others have reported. Overall if i knew what i knoiw now, i would have kept my top mount. |
| The Following 3 Users Say Thank You to Laloosh For This Useful Post: |
![]() Join Date: Mar 2008 Location: West Palm Beach, Fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score sorry for your misfortune, but you've confirmed everything that I was worried about with this kit. corksport seems to be really on top of things quality-wise, but when I learned that the MAF housing was larger than stock on this kit, I started really wondering if other things weren't up to snuff as well. I think I am going to stick with the top mount until someone gets a much better front mount solution going. |
| Door is THAT Way Mate ----> ![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score I went to an FMIC on my VW. It was originally SMIC. I never got it just right. Fitting was a bit off and I was always jostling pipes around and tightening clamps to try and get it right. I never got it. I put the SMIC back on and just dealt with the heatsoak. |
(Thread Starter) | Not Ranked : 0 score Ill see how i feel about it the more i drive it, for now im "eh" not worth it |
| Not Ranked : 0 score You're probably a lot more handy with a wrench than I am. I wouldn't write it off just yet. |
(Thread Starter) | Not Ranked : 0 score went out for lunch and its kind of growing me on, but still eh |
![]() Join Date: Mar 2008 Location: Twin Cities
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Got pics?????
__________________ --2008 Black Mica MS3-- |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score do you have it set to recirc or vta? if in recirc can you still here your bypass valve? |
(Thread Starter) | Not Ranked : 0 score its set to vta |
| Not Ranked : 0 score I don't want to spend $1100 on an "eh" mod, that's for sure. |
| The Following 2 Users Say Thank You to sleeper3 For This Useful Post: | rondog7575 (07-15-2013), wolly6973 (12-31-2013) |
![]() Join Date: Mar 2008 Location: California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
Groaned at 34 Times in 12 Posts
| Not Ranked : 0 score That's crazy, Laloosh.. you sure you have it in right? Mine doesn't hit anywhere and the only place it's tight is near the A/C pulley(about an inch). Mine never stumbled at start-up, no CEL, no nothing! It's far smoother than stock.. This is how the car should have come from the factory. I absolutely couldn't be more pleased with the system. I did have to trim the black TMIC cover just a hair to clear the pipe, but that was it. |
| Not Ranked : 0 score I'm driving my Suburban today so I don't have access to any quick shots. I can snap some when I get home if you'd like.. Let me know specifically what you want to see and I'll post it, or e-mail it to you. I'm sure you know what you're doing, but it does sound like something is off. Mine is a perfect fit. |
| The Following User Says Thank You to Overboost3 For This Useful Post: | SofaKingAwesome (06-17-2013) |
| I was worried about the MAF housing as well including that i would most likely have to change the BPV. I guess the real test will be at the track, BUT.. i bet it looks cool as hell.
| Not Ranked : 0 score Here ya go.. |
| The Following User Says Thank You to Overboost3 For This Useful Post: | lilred (12-13-2012) |
| Not Ranked : 0 score werd to ya mutha! |
(Thread Starter) | Not Ranked : 0 score That pretty much what mine looks like. Your is touching the ecu tracy as well, and i bet its hitting the tmic cover also. |
| Not Ranked : 0 score No, it's not hitting the ECU cover/battery tray or the TMIC cover. I have about an inch between the pipe and ECU cover and about 2 inched between the pipe and TMIC cover, but I did trim back the cover. |
| The Following User Says Thank You to Overboost3 For This Useful Post: | atvfreek (02-21-2013) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score does this kit come with the tbolt clamps? i want them on every piece of tubing. If not, which sizes and how many of each do i need?
__________________ On motor #3 Turbo #2 Now have a SSM 08 STi!! |
![]() | | #20 | ![]() |
![]() | | #21 | ![]() |
![]() Join Date: Mar 2008 Location: Minneapolis, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 804
| Not Ranked : 0 score Just feel it out, I think most of us who are neutral on x brand parts are too quick to give a thumbs down. While other who are brand fanbois are too quick to give the thumbs up. |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yea thats what im going to end up doing. I got the thing for a killer price, kinda of jumped on it without doing much research about it. Well c how it goes, if i stay cel free and the car puts out some track numbers than i cant complain |
![]() | | #23 | ![]() |
![]() Join Date: Mar 2008 Location: Lawrenceville GA
| Not Ranked : 0 score Guess yours is laid out different from mine. I had no issues with fitment. I sprayed soapy water to check for leaks once it did idle. I did have an issue starting mine at first and it stay running but once the ecu learned it was fine.
__________________ [SIGPIC][/SIGPIC]www.myspace.com/rican219 MODS: TWM Short Shifter Stage 2, CPE downpipe Highflow Cat, Corksport 3 inch Catback, SU motor Mount, HKS BOV VTA, Spin on Oil filter conversion, Greddy Turbo timer, H&R Springs, Sport Max wheels, Corksport Strut Tower Brace, Corksport FMIC,Turbine Tech Front Engine Mount, Turbine Tech Rear Diff Bracket and Bushings, PROcede EMS, 2871r, Dash Hawk |
![]() | | #24 | ![]() |
| Not Ranked : 0 score soapy water would not bubble even with a gigantic leak. just fyi. there is no pressure in the system at an idle. |
![]() | | #25 | ![]() |
| Not Ranked : 0 score I know that but the idle would change if there was leak
![]() | | #26 | ![]() |
| Not Ranked : 0 score Oh, mine doesn't hit in the back corner of the TMIC cover like yours does. Did you try pushing the pipe a little deeper? I don't like how that sounds. |
![]() | | #27 | ![]() |
| Not Ranked : 0 score I have a couple of t-bolt clamps for the TB if you need 'em. |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score that pipe is as far as it will go, as for the clamps, its only the 2 tbody clamps so im not that concerned. |
![]() | | #29 | ![]() |
![]() Join Date: Mar 2008 Location: Windsor Ontario Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 197
| Not Ranked : 0 score Thats a nice looking set up, I kinda like the way they set up the new intake also.
__________________ 2010 Victory Red HHR SS 2008 CPW MS3 (SOLD) 2004 Black SRT-4 (SOLD) |
![]() | | #30 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1904 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score Thats weird Chris it seemed to bolt right up to my car decently! |
| The Following 3 Users Say Thank You to driver311 For This Useful Post: |
![]() | | #31 | ![]() |
| Not Ranked : 0 score how do you feel about yours so far?
__________________ Ribs. I had ribs for lunch. That's why I'm doing this. sleeper3 - 2.234, 8.742 @ 84.18, 13.365 @ 106.75 (I/IN/IC/MM) |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Good ole check engine light. p2177 yea this things a winner. Tell you guys what though, the car does pull hard with it. I htink im going to stick a silicon couple in the maf housing to make it about 2.6. |
![]() | | #33 | ![]() |
I really expected more out of corksport. now I'm doubting their other products...
__________________ Ribs. I had ribs for lunch. That's why I'm doing this. sleeper3 - 2.234, 8.742 @ 84.18, 13.365 @ 106.75 (I/IN/IC/MM) | |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score same thing as the cpe intake. The maf is smaller then the surrounding piping. Ill knife edge the silicone to make it as smooth as possible. Well there goes my day tomorrow. |
![]() | | #35 | ![]() |
| Not Ranked : 0 score I haven't had any issues with mine no CEL's. Have you called them with your issues? They are a great company they will work with you if you ask.
![]() | | #36 | ![]() |
![]() Atleast its pulling hard. Hopefully its not running lean. Ill get the dh back asap. | |
![]() | | #37 | ![]() |
Groans: 370
| Not Ranked : 0 score Did you email CS and ask/let them know about their MAF housing being too big? |
![]() | | #38 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
| Not Ranked : 0 score Laloosh hit me up, I will post some pictures of our kit when I get it on the car. |
![]() | | #39 | ![]() |
| Not Ranked : 0 score I'd be interested in what you come up with too!
![]() | | #40 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
| Not Ranked : 0 score looks like i'm staying with my top mount which will be here next week.
__________________ Black Mica '07 Mazdaspeed3 Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing Reppin' ProtegeGarage for life! |
| The Following User Says Thank You to mrlilguy157 For This Useful Post: | occschemguy (03-12-2008) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/corksport-front-mount-intercooler-74/ | ||||
| Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more | This thread | Refback | 03-25-2008 04:47 PM | |
| Corksport Ram Air Box | bova | MazdaSpeed 3/6 - Turbo Induction | 3 | 04-08-2010 06:42 PM |
| Corksport FMIC Kit | bova | MazdaSpeed 3/6 - Turbo Induction | 22 | 06-12-2008 08:44 PM |
| Going all corksport exhaust it looks like... | Haltech | MazdaSpeed 3 - Engine, Transmission & Driveline | 20 | 03-26-2008 11:22 PM |
| CorkSport DP + Vibrant | SLS MS3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 03-24-2008 10:57 AM |
