![]() | | #41 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
| Not Ranked : 0 score
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress |
| The Following User Says Thank You to himurax13 For This Useful Post: | mazdaspeeding (06-20-2012) |
![]() | | #42 | ![]() |
Groans: 111
| Not Ranked : 0 score ...compared to the OEM TMIC - yes. Compared to another decent aftermarket TMIC - you'll never know (but I do).
![]() | | #43 | ![]() |
![]() Join Date: Apr 2010 Location: Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 265
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score ^^^ Not sure if you read but I ran the CPE TMIC for 2 months before I switched to the UR FMIC. Getting the lower BATS sooner and slightly lower BATS overall, especially on WOT pulls definitely made the car faster. I don't have dyno charts to back this up but I've definitely ran a good aftermarket TMIC and I'm happier/faster with the FMIC. |
![]() | | #44 | ![]() |
![]() Join Date: Mar 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
(Thread Starter) | Not Ranked : 0 score Somebody install a MD OCC V3 with a FMIC ? If I want a FMIC + Cold air Intake + OCC on my speed3 does it possible ? The MD OCC V3 : - Mounted on the transmission, underneath the factory intake/short-ram intakes - Designed to allow space with cold air intakes - Easy to drain, the drain spout can be reached from above the engine - Occupies the space for most front-mount intercooler piping I already have a Cold Air Intake + MD OCC v3. Do I must keep my CPE TMIC ? Thanks for your help
__________________ 2008 MAZDASPEED3 Black Stratified Tuned / Stage 2 |
![]() | | #45 | ![]() |
(Thread Starter) | Not Ranked : 0 score no idea ???
![]() | | #46 | ![]() |
![]() Join Date: Mar 2008 Location: Phoenix
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
I had a custom one made to replace the factory TMIC and it was awesome for cold air all the time. Just keep the water resevoir out of the engine bay and you'll keep some great overall water temps. Parts you need: http://www.frozenboost.com/product_i...94b20935595571 http://www.frozenboost.com/index.php...94b20935595571 http://www.frozenboost.com/product_i...oducts_id=1227 http://compare.ebay.com/like/2906133...Types&var=sbar
__________________ Mike B Love cars but wrestling comes first! ![]() World's quickest and fastest Ecoboost Flex http://www.youtube.com/watch?v=XT_zwVaXHwg 2011 Ford Flex Tuxedo Black Titanium EB 12.4@109 on Motor/12.38@113 on nitrous Megan Coilovers, Custom fuel system, E85, custom cutout, lots of fun. 2013 Ford F-150 Ecoboost FX4 | |
![]() | | #47 | ![]() |
__________________ 2008 MAZDASPEED3 Black Stratified Tuned / Stage 2 | |
![]() | | #48 | ![]() |
![]() Join Date: Nov 2010 Location: Moscow, Russia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
Groaned at 23 Times in 2 Posts
__________________ Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc.. | |
![]() | | #49 | ![]() |
| Not Ranked : 0 score Here is a running thread of TMIC v. stock comparos. There is also a TMIC v. FMIC comparo that I ran. http://www.mazdaspeedforum.org/forum/foru...ost-em-131840/
![]() | | #50 | ![]() |
Groans: 255
I believe top mounts start loosing their efficiency and start heatsoaking after 5,000 RPMs during 4th gear runs. On 3rd gear runs, that didn't seem to be an issue.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
![]() | | #51 | ![]() |
| Not Ranked : 0 score The guy I sold it to put up pics of his install: 4DRHTRD's creation reborn! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score Nobody drive a FMIC + OCC + CAI here ? Is it possible ???
![]() | | #53 | ![]() |
![]() Join Date: Apr 2012 Location: irving,tx
| Not Ranked : 0 score Yes @TheFlash; gen1 has horrible intercooler ducting. If you don't want to do this Lower your IAT's with SRI then go FMIC i would personally get a gen2 hood and call it a day. They don't heaksoak as bad as a gen1 |
![]() | | #54 | ![]() |
But it isn't as efficient as a FMIC ... no
![]() | | #55 | ![]() |
| Not Ranked : 0 score Trust me, TMIC + WMI FTW. Kick the $400 down and just get a WMI kit. I'm a believer. My temps will go lower and stay lower than any FMIC now. I wish I did it sooner. The first time you do a WOT pull with WMI and your BATs drop below ambient and hold about 10F over your IATs at the end of the pull, pull after pull, you will thank me.
![]() | | #56 | ![]() |
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,954
tapafuck
__________________ 2010 velocity red mica ms3 AP/AT internals JBR 3.5" whale peen (non rubber for more feeling) JBR SSP/bushings JBR RMM JBR tigs/ egr delete/ coolant bypass JBR stage 2 OCC CS test pipe Turbosmart BPV (stocker currently on) SS lines/super blue/stoptech pads | |
![]() | | #57 | ![]() |
![]() Join Date: May 2011 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
Groaned at 340 Times in 107 Posts
| Not Ranked : 0 score Can tell you this... I just moved to Las Vegas...holy hell. HAD to buy a front mount. Car was hating it. Stupid traffic, long stop lights, Intake temp climbs up to 160+ at a red light. And it's not even summer yet. The top mount just needs to keep moving- that's the problem. Still makes up to 130... but drops fast as soon as I move again. Last edited by crtguns; 04-28-2013 at 01:22 AM. |
![]() | | #58 | ![]() |
(Thread Starter) | Not Ranked : 0 score Is it possible to go with FMIC and keep my MD OCC V3 because I have a Canadian MS3 ?? It's the only problem I can have if I go FMIC ... I don't know where I can put my OCC after ...
![]() | | #59 | ![]() |
(Thread Starter) | Not Ranked : 0 score Suggestions ...
![]() | | #60 | ![]() |
(Thread Starter) | Not Ranked : 0 score Anybody fit a FMIC + CAI + MD OCC ??? Somedy drive his speed3 with this setup ?
![]() | | #61 | ![]() |
(Thread Starter) | Not Ranked : 0 score Must I drag my car if I want to go FMIC ?
![]() | | #62 | ![]() |
(Thread Starter) | Not Ranked : 0 score No idea man ...
![]() | | #63 | ![]() |
![]() Join Date: Oct 2008 Location: Calgary Alberta
Groaned at 114 Times in 37 Posts
hard to take this seriously. Space restrictions on the front of the ms6 make it hard to do a real and fair comparison.
__________________ 2009 Subaru WRX 265 Sedan || Cobb AP || Cobb SF intake w/ air box || Process West TMIC || Tein Springs || Grimspeed 3 port || Forge BPV || Invidia Catback || UR Downpipe || Kartboy short throw w/ cobb knob and bushings || Cobb Heatshield || DW65c fuel pump || NGK 1 steps In Garage for Spring || HSD Coilovers || Eibach f+r sway bars || Whiteline positraction bushing kit || Kartboy Endlinks || Whitelink endlink reinforcements || GTSpec front + rear sway bars || Stoptech front and rear rotors,pads,lines Sold 2007 MS3 295 whp 350 Torque 2010 Evo X 440AWHP 11.7 @ 113 2009 Ralliart w/ xswap 320AWHP (first in canadia to break 300whp in gen2 RA) 12.4@ 108 2004 srt-4 s2 2006 ms6 2005 srt-4 s3 w/toys 12.16 @ 117 Last edited by secondchance; 08-13-2013 at 11:03 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #64 | ![]() |
We've had this debate. You lost. No secondchances- literally and figuratively. You were talking out of your asshole and got collectively shut down. I can link that thread if you forgot about it.
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 | |
| The Following User Says Thank You to dale_gribble For This Useful Post: | bcmountainspeed (08-14-2013) |
![]() | | #65 | ![]() |
Go back in your hole child. You are clearly stupid enough to think wmi is only a cooling agent, and not an octane additive, and likely dont understand how or why WATER helps with cooling. I'll wait while you google it though.
__________________ 2009 Subaru WRX 265 Sedan || Cobb AP || Cobb SF intake w/ air box || Process West TMIC || Tein Springs || Grimspeed 3 port || Forge BPV || Invidia Catback || UR Downpipe || Kartboy short throw w/ cobb knob and bushings || Cobb Heatshield || DW65c fuel pump || NGK 1 steps In Garage for Spring || HSD Coilovers || Eibach f+r sway bars || Whiteline positraction bushing kit || Kartboy Endlinks || Whitelink endlink reinforcements || GTSpec front + rear sway bars || Stoptech front and rear rotors,pads,lines Sold 2007 MS3 295 whp 350 Torque 2010 Evo X 440AWHP 11.7 @ 113 2009 Ralliart w/ xswap 320AWHP (first in canadia to break 300whp in gen2 RA) 12.4@ 108 2004 srt-4 s2 2006 ms6 2005 srt-4 s3 w/toys 12.16 @ 117 | |
![]() | | #66 | ![]() |
| Not Ranked : 0 score So the fact that it raises octane as well as cooling is a bad thing? You don't need the water for cooling either. 100% meth will also cool the intake charge. Adding water to the mix fucks with the distillation curve of the methanol. Don't worry, I'll wait while you google distillation curves.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
![]() | | #67 | ![]() |
![]() Join Date: Jul 2013 Location: Buckley, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 73
| Not Ranked : 0 score Just to answer the question of "why mazda gave the MS a tmic". It's cheaper to mass produce. Less labor in the factory.
__________________ Corksport SRI - TIP - Vibrant TBE - Turbo XS FMIC - Autotech FP Internals - Ebay Downpipe - Eibach Springs - JBR RMM - Turbosmart DualPort BPV - Cobb Accessport - Tork Upgraded VVT - Grimmspeed EBCS - Snow Performance Stage 2 Meth Kit - Tuned by Tork Motorsports. |
![]() | | #68 | ![]() |
| Not Ranked : 0 score @secondchance, you lost all credibility when you said that outside air passing through the intercooler is colder after passing through the intercooler. Remember that nugget of wisdom?
| The Following User Says Thank You to dale_gribble For This Useful Post: | sidekick (08-14-2013) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/change-my-top-mount-intercooler-front-mount-116749/ | ||||
| FMIC do I need it ??? - Page 2 | This thread | Refback | 08-13-2013 07:54 AM | |
| TMIC or FMIC | seige123 | MazdaSpeed 3/6 - Turbo Induction | 12 | 04-25-2014 05:10 PM |
| Cp-e Tmic vs CS fmic | BlewisMSF11' | 2010 MS3 - Turbo Induction | 73 | 04-25-2012 09:00 AM |
| HP Gains- fully bolted w/stock TMIC vs. FMIC/bigger TMIC | Chimmike | MazdaSpeed 3/6 - Turbo Induction | 6 | 07-04-2011 03:18 PM |
| TMIC change, expected boost drop? | Uranium9v | Cobb ATR Support | 20 | 05-16-2010 07:57 PM |
