 Old 02-26-2015, 10:30 AM   #1
leka's Avatar
Posts: 144   (View Stats)
leka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to behold
Milky is my OCC, the engine oil is very normal, no strange smell. Pure engine oil.
I will post a log this coming days, will need to send a log either way to my tuner
I also changed my pcv Valve, seemed to helped a little.
My OCC setup is pcv to catch can, intake side plugged.
Valve cover to catch can. And catch can to TIP for vacuum
Mazdaspeed 6 2006
Sp63 Longblock with Mahle and manly, ported head, keyed crank and cams, stiffer springs, GTX2867R IWG, Freaks intake 4 inch,Autotech Internals, Stratified Ebc + GA, CP-E injector seals, CS Custom pipes FMIC, Snow performance stage2 100% meth, Cp-E decatted downpipe, Custom Catback with VareX mufflers, EGR Delete, SURE TMM+PMM+RMM, South Bend Clutch Stage3 Daily, CS rear diff mount, TurbineTech Front diff mount, CS rear swaybar, Racingbeat rear Endlinks, Matt Damond PS cooler, JBR OCC Stage 2, Bosch 3 bar MAP w/ PNP Harness, BC coilovers, Tenzo R Type M 19" 235/35, Sure Shortshift, Xcarlink, Speed performance Aux fan control, Synchronic DV BOV, DBA front rotor, Ebc yellow stuff(FR), EBC greenstuff (R), Stoptech brakelines and Finally, Tuned By Lex @ Stratified
Current INFO : tuning is paused due the winter.
Waiting to be installed: Cp-e exhaust manifold stock flange with MVR 44 external wastegate and dump tube.
leka is offline   Reply With Quote
Catless DP question deekspeed 2010 MS3 - Engine, Transmission & Driveline 30 06-04-2013 08:43 PM
FMIC and Catless Exhaust Question johnspeed3 Gen2 MS3 General Discussion 12 05-03-2013 06:53 AM
Quick question abt CNT Catless DP xtasy MazdaSpeed 3 - Engine, Transmission & Driveline 11 01-22-2012 04:02 PM
Page generated in 0.23080 seconds with 21 queries
