| Not Ranked : 0 score Bright, the boost season, no cat and no hpfp isn't a good idea. the first one is a pita to remove but you may just disconnect the flange where the second cat usually connect to inspect the primary with a test light.... btw, rotten eggs smell isn't a perfect proof of a plugged cat, some brand new may smell just because of fuel or a car that remain granny driven and then pushed a bit more... It could be that, blocking in or out of the engine will prevent the turbo from making good boost...i dont keep cat long enough to test but my sister burned is honda with a plugged one, the valves overlap phase of the engine made it eat some part of the cat internal...
| The Following User Says Thank You to Jeff23spl For This Useful Post: | arnold600 (10-11-2018) |
| Impossible to get my boost target | Mini Franki | 2010 MS3 - Fuel, Nitrous & Water Injection | 33 | 08-08-2018 04:11 PM |
| Car not reaching target boost | Pacmonk | Mazdaspeed3/6 General Discussion | 19 | 10-16-2015 12:22 PM |
| Not hitting my target boost | TheProYodler | 2010 MS3 - ECU Computer Tuning | 26 | 08-11-2014 09:02 PM |
| Not hitting target Boost. PLZ HELP | mgramata | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 9 | 04-22-2014 09:01 PM |
| Can not reach target boost | MS3SHAY | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 03-02-2014 06:15 PM |
