![]() Join Date: Aug 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 165
Groaned at 7 Times in 4 Posts
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) |
![]() Join Date: May 2012 Location: Ontario
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 89
| Not Ranked : 0 score Can you link to the info?
__________________ My car thread: http://www.mazdaspeedforum.org/forum/forum/f542/pwdunmore-s-2012-a-150456/ |
![]() Join Date: Mar 2014 Location: Barre, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 344
| Not Ranked : 0 score I saw a teaser pic of a new BNR that was like more in line with a GT35 frame turbo. He said he's not calling it an S5 because it differs from all his other so much. That what you're thinking about?
__________________ 2015 Mazda 3-slow 99 Brilliant Black Miata- slow too |
(Thread Starter) | Not Ranked : 0 score It was mentioned in this thread BNR S3 or BNR S4 and when I asked edgeautosport.com about it, they mentioned that a new one should be out soon.
| Not Ranked : 0 score Copied from the BNR Facebook page: Mazdaspeed 3 and 6 owners will have a new product from BNR soon after the new year! We are soon to release our gt35 series with a .82 a/r exhaust housing for 44mm turbosmart external wastegate. The compressor housing is a T04E with 4" inlet 2.5" outlet with antisurge! The compressor wheel is custom to BNR and is 62mm on the inducer and 88mm on the exducer. We expect around 70-75 lbs per min at a medium pressure ratio 28-35 psi. Most OE hardware will bolt on (oil feed, water lines ect. You can keep your expensive stock flange custom manifolds and down pipes and save lots of money instead of replacing the whole system!
I will now have to buy a 3.5" coupler.I'm not too sure if the previous version is still available. Edgeautosport said I would have to wait for the new one which should be about 1 month. I'm hoping the HTP 3" intake coupled to the 3.5" inlet doesn't cause an issue in terms of spool and overall performance. I doubt it will, especially since my goal is below 400 whp. Hopefully someone else can chime in as I wait for Bryan to respond to a few other questions that I asked him.
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) Last edited by BuddySpeed3; 01-07-2017 at 04:27 PM. Reason: MSF Database - Automerged Doublepost | ||
There's an revision to the current S4. It'll be with an 3.5" inlet instead of the current 3" inlet. Sent from my Pixel XL
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
| The Following User Says Thank You to MS3Shadow For This Useful Post: | WetzMS3 (01-10-2017) |
![]() Join Date: Mar 2012 Location: Nashville, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
| Not Ranked : 0 score I sent Bryan a message earlier this week and never got a response cause I was told they were shipping after Christmas and now I was told another 2 weeks.. I thought I read somewhere in addition to the larger compressor housing inlet, that it wasn't going to taper down like the 1st version was, could be wrong. |
| The Following 2 Users Say Thank You to MS3Shadow For This Useful Post: | IlleztImportz (01-08-2017), Thor Hammer (01-10-2017) |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,088
Groans: 30
| Not Ranked : 0 score I've talked to Bryan directly and the 35-style frame turbo is known as the S6 and has a EWG turbine housing with a 44mm outlet for a gate to be mounted on similar to the ATP EWG housings but it's true .82 a/r and again larger wastegate orifice. It's not for stock block peeps so don't bother unless you have k1 rods minimum and are revving past 6700rpm. Also I doubt it will work with a Mazdaspeed 6 just looking at the location of the gate and fact that the PTO has the coolant inlet where the wastegate would be located on the bottom of the turbine housing. The S5 is a turbo a friend of mine has been testing for Bryan for some time and it's just a big wheel S4 with ported turbine housing and bigger comp wheel and comp inlet, same otherwise.
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning Last edited by impossible; 01-08-2017 at 01:09 AM. |
| The Following 2 Users Say Thank You to impossible For This Useful Post: | Thor Hammer (01-10-2017), WetzMS3 (01-10-2017) |
Groans: 30
| Not Ranked : 0 score deleted comment
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning Last edited by impossible; 01-28-2017 at 11:59 PM. |
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor Last edited by Djohns; 01-08-2017 at 02:55 PM. | |
I only wanna spend my money once this time around. I'm on my third intake for crying out loud! lol
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) | |
Groans: 211
I spoke with RPM yesterday as my turbo is smoking at random. He talked me into the revised S4. As MS3Shadow mentioned it will have a 3.5" inlet. We had a bad phone connection but the jist I got is AR is revised and it should spool up quicker. What TIP and intake would you guys run with this turbo? I currently have a CPE to stock turbo TIP and AEM CAI. Could I adapt my CAI to a larger TIP and run that? Or would I get better performance running a whole new intake? Like a JBR tru 3.5 SRI?
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
| The Following User Says Thank You to MS3Shadow For This Useful Post: | Thor Hammer (01-10-2017) |
| Not Ranked : 0 score I really want this revised s4. It's slightly annoying that I bought mine, haven't even opened it and boom now there's a revised version with a 3.5" inlet and that's what I wanted. Go figure, maybe someone with a 3" intake will wanna trade the new one for mine. Fixed.
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor Last edited by Djohns; 01-10-2017 at 09:59 AM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
| Not Ranked : 0 score HTP 3.5" intake. Avoid the AIDS.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
| The Following User Says Thank You to WetzMS3 For This Useful Post: | Djohns (01-10-2017) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score What issues do people have? I don't have any issues with mine, nor have I heard of people having issues?
![]() | | #20 | ![]() |
| Not Ranked : 0 score Now now, let's not make this into an intake thread.. Seems the bnrs4 v2 keeps getting pushed back as far as shipping out goes. I was told after Christmas, that time came I was told two more weeks. I was just told again this morning it'll be the end of the month! I hate waiting, was almost tempted to just throw down more moniez for a 3076, but broke.. |
![]() | | #21 | ![]() |
![]() Join Date: Jun 2016 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 56
| Not Ranked : 0 score Hey as long as I has options of S4v2 and S5 and this GT35 frame behemoth to choose from come summertime, I'll be happy as a Hindu cow. Let's hope my new K04 doesn't decide it wants to be another warranty replacement before that...
__________________ 2012 Velocity Red Mica MS3 Tech For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now Handling: JBR .250 RSB w/ billet brackets. So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver. |
![]() | | #22 | ![]() |
![]() Join Date: Feb 2015 Location: Cape Coma Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
| Not Ranked : 0 score You and me both, I got my S4 at the end of Nov and had no idea about an updated version being released. Here we are, the end of Jan and my car is still apart in the garage and S4 still boxed 😞. I wants V2!
__________________ 1 slow speed |
![]() | | #23 | ![]() |
| Not Ranked : 0 score I know! I tried emailing BNR to see if maybe they would offer a trade in or even send the v1 to be modified but got no response.
![]() | | #24 | ![]() |
| Not Ranked : 0 score Emailed Justin about a touch up tune and figured I'd ask about the v2, this was his response.
![]() | | #25 | ![]() |
| Yeah, no reason to sell or return them to just get an 3.5in inlet instead of the v1 3.0in inlet. Sent from my Pixel XL
![]() | | #26 | ![]() |
![]() Join Date: May 2016 Location: Sultan, WA
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score I emailed Bryan about this on 1/4/17. Sorry I'm late to answer, I just saw this post. This is the response I got from him. "Improving the compressor housing. Casting the extension in and it will look like a factory unit instead of having the offset outlet with the customizing. It will have antisurge port as well."
__________________ Engine/Exhaust/Intake Corksport:Injector Seals, OCC, EBCS, HPFP Internals, Long Catted DP||Magnaflow:CBE||HTP:3.5" Intake & 51r Tray||JBR:Boost Tubes, Recirc. Hose||CP-E:TMIC||Cobb:Accessport V3(Freektune)||Forge:V2 BPV(Blue Spring)||Damond Motorsports:Full EGR Delete||NGK 6510 Suspension/Chassis Corksport:Camber Plates, FSB/RSB, Endlinks, Short Shifter||JBR:Rear Camber Arms||CP-E:RMM||H&R:Street Performance Coilovers||Damond Motorsports:PMM, TMM |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Only cool kids surge their turbo.
| The Following User Says Thank You to Djohns For This Useful Post: | monkey.bones.007 (01-28-2017) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Are we talking a machined/cast in antisurge or the half-ass "drilled holes" around inlet approach?
![]() | | #29 | ![]() |
![]() Join Date: May 2014 Location: Broadalbin, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
| Not Ranked : 0 score It looks like its a proper cast / machined anti surge. Found this photo on their facebook page, the top is the revised s4 compressor cover according to BNR's comment, and the bottom is the s5 cover. I picked up an s4 and it has just been sitting since its too cold for an install. I am really hoping that we can simply unbolt the old compressor housing and bolt the anti surge cover on.
__________________ Cobb AP V3 - HTP 3" intake system - UR axleback - Depo catted downpipe - Forge Black BPV - ADD W1 oil catch can - JBR cylindrical shit knob - JBR shit plate - JBR solid shit bushings - JBR 88d RMM - JBR RSB |
| The Following User Says Thank You to Blk_pu For This Useful Post: | MoMS3 (01-27-2017) |
![]() | | #30 | ![]() |
| Not Ranked : 0 score @Djohnsso they replied to their post..... he said to wait about 2 or 3 months to fill preorders! Sounds like he will be selling the anti surge covers if you ask. So much boner...
![]() | | #31 | ![]() |
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor | |
![]() | | #32 | ![]() |
| Not Ranked : 0 score I'm hoping for under 200$, the median price for compressor covers seems to be 150$
![]() | | #33 | ![]() |
Groans: 438
| Not Ranked : 0 score I want the S5 EWG setup, it shall go perfectly with the built motor.
![]() | | #34 | ![]() |
| Not Ranked : 0 score If you're gonna spend all that money on a built engine why stay on the shitty stock flange?
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | MS3Shadow (01-29-2017) |
![]() | | #35 | ![]() |
Groans: 438
I'd love to go tial hot side, twin scroll, etc. But BNR is in my price range, and as much as I love the s3 (and will even more on a built engine with meth), I know I'll eventually want more. Plus loud racecar noises, and the BNR setup will almost definitely be cheaper than a GT/GTX series equivalent EWG setup, especially adding in the cost of a new DP and manifold. Also, if I do have the money, the beautiful fender exit dump tubes you had. I might be stealing that idea lol.
__________________ All good things must come to an end... | |
| The Following User Says Thank You to g00s3y For This Useful Post: | Mazdazilla6 (01-29-2017) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score How far along is your car? I'm assembling my engine this week, finally got my new block. I'm doing an S4 build with ewg, shitty stock flange because I am out of money to upgrade the fuel system and too weary use methanol for fueling headroom. If I had the money to upgrade to port injection, I woulda went with a different hot side manifold setup, but were talking another $ 3-5k between manifolds, fuel and turbo
__________________ 1 slow speed Last edited by PearlySpeed; 01-29-2017 at 02:09 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #37 | ![]() |
Groans: 438
| Not Ranked : 0 score It's been a long road. Engine blew a hole through the front and back about 4 months ago. Bought a long block a couple months ago, got it all taken apart, cylinders scratched. Figure ok, can bore .020 over, 88mm pistons, all good. So take it to a machine shop last week, guy tells me it's not just scratched, but possibly a hairline crack in just one cylinder. So waste of a couple months and good amount of money. On the good side, found a short block on ebay for $300 couple days ago in Pompano Beach. My girl was already heading over there yesterday with her friend, so luckily she was able to stop by and pick that up. Already got it back and honed and all looks good for now. Just need to take it to a shop tomorrow and have everything checked out with proper tools, just to be sure everything is good to go. After confirmation of that, SP63 4032 pistons will be ordered, then when tax return comes, engine/gasket kit and act clutch/flywheel kit will be purchased.
![]() | | #38 | ![]() |
| Not Ranked : 0 score Do you have a shop? I've been using Lamont's off Hanson in fort Myers, they've been great. I've got a set of 88mm Manley 2618 Pistons sitting in my garage, just need new rings as I began assembling and noticed some cylinder distortion in cyl 3. So I picked up a new block from Mazda and went with stock bore manleys... I was gonna save them for my next rebuild but not sure., let me know how the 4032 work out. I was up in the air for the longest time between the two compounds, but have heard the Manley are one of the better 2618 for daily and wanted the extra piece of mind. Maybe we will run into eachother sometime. Mines been apart since Oct and I'm dying to get it done.
![]() | | #39 | ![]() |
![]() Join Date: Dec 2013 Location: Surprise, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 368
| Neutral : +1 score FYI. S4 V2 info up of BNR's FB page. ".70 ar 3.5" inlet with anti surge port on v2 vs. .60 ar 3" inlet on v1. V2 should spool faster and have improved mid range along with a louder sound. Same max output." -BNR
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD |
| The Following 2 Users Say Thank You to Atticaz For This Useful Post: | KiwiFlavor (01-30-2017), MoMS3 (01-30-2017) |
![]() | | #40 | ![]() |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
| Neutral : +1 score The ricer in me approves of this louder sound... Still can't make up my mind if I should go with BNR or GTX series when the time comes.
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
| The Following User Says Thank You to KiwiFlavor For This Useful Post: | MoMS3 (01-30-2017) |
