![]() Join Date: Aug 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 165
Groaned at 7 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score Ok so a little update... Smoking is still happening only at WOT but has improved a little bit. It's worse if the oil hasn't fully warmed up. Compression was checked and resulted in 180 psi across all 4 cylinders. I've removed oil return line and verified no blockage in the line, engine block, and turbo cartridge. Puffs of whitish blueish smoke occur more noticeably if I hit the throttle hard as opposed to gradually going WOT. It's also noticebly smokey if I hit the rev limiter (accidentally). It seems very much related to crankcase pressure as it only happens at WOT. If I rev the engine out to high rpm at part throttle to raise oil pressure, it doesn't smoke at all. Things that have helped but not fully cured the issue: 1. Gen 2 valve cover w/ Sp63 oil breather cap; VC breather still routed to turbo inlet for vacuum 2. DM stage 2 vented catch can with vent routed to turbo inlet for added vacuum 3. Oil restrictor bolt from BNR (smaller hole than JBR bolt) 4. Switching back to 5w30 (was running 5w40 Rotella T6) as it drains out of the turbo more efficiently as per Bryan. I really don't want to have to send it out to Bryan to get rebuilt. Has anyone had a similar issue with the S4? If so what was your solution? Thanks! Erik
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) Last edited by BuddySpeed3; 06-12-2018 at 09:42 AM. |
![]() Join Date: Mar 2011 Location: Cambridge, Ontario, Canada
Rep Power: 221 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
In my case, the burning oil issue was from the crankcase pressurizing and oil blowing past the rings. Also, since the crankcase was experiencing excessive pressure, my turbo wasn't draining properly, and this cause it to seep into the compressor housing.
__________________ 2011 MAZDASPEED3 Hypnotic Tuned - Rob CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) - | |
The reason I ask is because my engine consumes virtually no oil or cause smoking when cruising around at part throttle. It's mainly at WOT, and has gotten much better since installing a vented catch can and the sp63 oil breather cap. FWIW we know oil pressure increases with rpm, and I can hold the rpm really high at part throttle to about 5000 rpm and see no smoke out the tail pipe. The smoking occurs only under load, which gives me a sense that my ringlands are not cracked ![]() Thanks!
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) Last edited by BuddySpeed3; 06-16-2018 at 06:10 AM. | |
| intermittent smoke | Savo1997 | Mazdaspeed3/6 General Discussion | 7 | 06-22-2015 07:51 PM |
| white smoke after e85 mix | bshotts422 | 2010 MS3 - Troubleshoot/Diagnostics | 123 | 04-20-2014 08:44 PM |
| white smoke | Dslatch4 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 19 | 11-12-2013 10:06 AM |
| White smoke | aldekei | 2010 MS3 - Troubleshoot/Diagnostics | 7 | 07-22-2013 12:26 PM |
| White smoke? PLEASE HELP | Fallenvoices | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 01-06-2010 03:39 PM |
