 Old 12-23-2009, 09:03 AM   #1
speedms6's Avatar
Posts: 825   (View Stats)
speedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the world
Default Blowoff valve
so i am running an hks ssqv in recirc. at lower boost there is a flutter, and i know that the flutter sounds i associated with compressor surge. i have read a lot of places that sometimes the hks valve makes this sound. just wanted to know if anybody else gets this flutter? is running recirculation what makes this sound?
2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge
speedms6 is offline   Reply With Quote
 Old 12-23-2009, 09:09 AM   #2
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
I just installed mine, my recirc hose collapsed due to it bending too far. so i had to cut it and put a 45* fitting in it. helped but the valve still flutters. I called hks directly and they said that is the sound the valve makes. it sounds like this: @ 20 & 35 secs or so
sounds like the valve opens 2 or 3 times. The way hks explained it to me was the primary valve opens, then the main valve hence the double or triple sound. real surge sounds the same but lasts a lot longer (few seconds)
The Following User Says Thank You to 8.5MS3 For This Useful Post:
speedms6 (12-23-2009)
 Old 12-23-2009, 09:15 AM   #3
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Blackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the world
Groans: 166
Valve flutter isnt the greatest, but it wont hurt anything. The valve just opens and closes a few times.
for HKS to say that this is "just a sound" that the valve makes is BS. Whoever you talked to doesnt know shit.
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
Blackspeed is offline   Reply With Quote
 Old 12-23-2009, 09:16 AM   #4
rmgedon69's Avatar
Posts: 30   (View Stats)
rmgedon69 is a glorious beacon of lightrmgedon69 is a glorious beacon of lightrmgedon69 is a glorious beacon of lightrmgedon69 is a glorious beacon of lightrmgedon69 is a glorious beacon of light
have you tried to adjust it?
you might wanna try to loosen the adjustment up a bit 'till you don't get the flutter sound. and make sure there's no kinks @ the recir hose.
rmgedon69 is offline   Reply With Quote
 Old 12-23-2009, 09:16 AM   #5
8.5MS3's Avatar
Groans: 326
hks isnt adjustable
 Old 12-23-2009, 09:17 AM   #6
DaleNixon's Avatar
Posts: 2,079   (View Stats)
Groans: 91
HKS USA usually doesn't have much useful to say in the way of HKS products. They couldn't tell me dick about their intake.
DaleNixon is offline   Reply With Quote
 Old 12-23-2009, 09:18 AM   #7
8.5MS3's Avatar
Groans: 326
well it was a woman in hks tech support......oxymoron????
 Old 12-23-2009, 09:28 AM   #8
KR....i haz it
Blackspeed's Avatar
Groans: 166
well, since i now know that the HKS isnt adjustable, that could also mean that she was blowing smoke up your ass.
 Old 12-23-2009, 09:35 AM   #9
8.5MS3's Avatar
Groans: 326
this may help
 Old 12-23-2009, 09:36 AM   #10
speedms6's Avatar
BLACKSPEED, a question i have similiar mods as you and i am looking to get a test pipe and an ets tmic, have you had any fuel problems, running lean, or any other things like that that you might have picked up on the dh. i was hoping to get these two mod's without having to worry about fuel pump internals.
 Old 12-23-2009, 09:49 AM   #11
KR....i haz it
Blackspeed's Avatar
Groans: 166
Absolutely no fuel problems whatsoever. After the TMIC and TP my a/f is now a little leaner than stock (which is pig rich). look at my dyno graphs here:
Third Dyno!
The problem of the fuel pump only seems to happen when running the AP, which is why its been sitting in my room for a few months now while I decide what to do. I really dont have the money for a fuel pump right now.
 Old 12-23-2009, 09:58 AM   #12
speedms6's Avatar
i hear ya with the money thing, these mods wont come for a couple paychecks after xmas, after that time to save for a fuel pump and some sort of tuning. thanks for the info, one last thing though did you go step colder plugs?
 Old 12-23-2009, 01:50 PM   #13
KR....i haz it
Blackspeed's Avatar
Groans: 166
I have them in my glove box for when I do the ap, but I actually might try them now since I get some knock on WOT. I didnt mention that before because ive been getting the knock since day one and had nothing to do with the intercooler or test pipe.
The Following User Says Thank You to Blackspeed For This Useful Post:
speedms6 (12-24-2009)
 Old 02-02-2010, 10:33 PM   #14
Lowbrid's Avatar
Posts: 7   (View Stats)
Lowbrid will become famous soon enough
aint the first gen SSQVs BOV's adjustable?
Lowbrid is offline   Reply With Quote
 Old 02-02-2010, 11:03 PM   #15
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
flutter will destroy your turbo ng push/ pulls on the cold side of the turbo, but it sound's cool!! is it held closed by boost? if so lighten spring pressure till it goes away also it slows the turbo spool down cause of the back pressure on the cold side just my .02
their is a great article around here on it
at 104000 2 bent rods
tuned by nishan
 Old 02-03-2010, 06:12 PM   #16
ZoomZoomVT's Avatar
Posts: 122   (View Stats)
ZoomZoomVT is a splendid one to beholdZoomZoomVT is a splendid one to beholdZoomZoomVT is a splendid one to beholdZoomZoomVT is a splendid one to beholdZoomZoomVT is a splendid one to beholdZoomZoomVT is a splendid one to beholdZoomZoomVT is a splendid one to behold
at 35 seconds it sounds like a turkey.
ZoomZoomVT is offline   Reply With Quote
blow off valve speed3po MazdaSpeed 3/6 - Turbo Induction 16 01-16-2010 10:39 AM
Blowoff for stock MS3 MS3Turion MazdaSpeed 3/6 - Turbo Induction 38 12-10-2009 06:38 AM
Page generated in 0.36069 seconds with 27 queries
