big turbo stock block thread Resource thread for big turbo STOCK blocks This is not meant to be a cut and dry this is what's ok thread. Its a guideline/ball park figures other people are running on stock blocks. If you blow your engine because you copyed what smeone else is running then lawls. What you guys pushing? I.e timing/boost/fuel on the stock block 91 + 2.5 gal e85 Do7 pre tb / Do1 pre turbo 100 percent meth 17 deg to RL 6031@27psi 400 g/s RL chinacharger bt@ 50k miles 6031 bt @ 61k miles current mileage 64k Running strong =) |
92/2.5 gallons E85 t3 3076r 16* up top 20k+ miles on BT 75k on the car Car pulls like a freight train |
What psi eric? |
Quote:
that thread sucks and is old |
c'mon needz moar info, where's everyone at? @Daddy Chinkus How many miles have you been BT? Ebay turbo and all. When/if there is enough info in here this thread should be made a sticky. |
Before I was BT I ran reworked for 30k fully bolted. 330whp&374wtq my car is abused lol |
Before building I ran superstocker 24psi 16* @ rl 70/30 meth do7 aprox 10k made about 320/380 then t3 3076 .82 (22psi) do7 70/30 16* @ rl aprx 5k miles made 420whp |
Good shit guys! |
93/2 gallons E85 ATP(:thumbsdown:) GTX76 20.5* up top 23-25psi 15k+ miles on BT 55k on the car ~430whp |
What if you have a lil turbo? :) |
Quote:
Quote:
EDIT: Im loving this thread :headbang: |
Quote:
Quote:
Currently have 1k on turbo 22k on car. 93/2g E85 + Do7 in cold pipe 80/20 mix 17 deg at RL GTX3071r@24.5psi 370g/s @ Redline. VD shows 409hp 408tq w/ 1.01 CF |
Quote:
Running GTX3071r at 24psi 200 on turbo, 51k on car Will be running 91/E85 2.5gal mix Tune still in progress |
ATP 3076 93 for 18k @16* 5050/100 meth D07 93/E30 3k @19.5* 100 meth D10 26psi on the regular 430/464 |
@superskaterxes what did your egts look like on that atp hotside at that psi? |
i never broke ~1700 |
2009- 32k miles with 500 on the turbo GT3076 ATP hotside 21psi and 13 degrees currently 91/ 2.5g E85 Still tuning....will update once done |
93 with 4 gal E M10 meth nozzle with 100% VP Racing M1 ATP GTX3071 Boost Targets from 2500-7000: Code: 16.00 19.00 21.00 22.00 23.00 23.50 24.00 25.00 25.00 25.00Code: 0.00 4.00 6.00 8.00 9.00 10.50 12.00 14.00 16.50 17.50EGT ~1630°F peak on 4th gear pull from 2k to RL http://i77.photobucket.com/albums/j6...031412-1VD.jpg Need to get to a dyno soon... |
.5557 with billet wheel 4''inlet .63 hotside 93 octane recently switched from sandback to ap ( huge difference!) so currently tuning only at 21 psi, should be back to 26psi after fifth port going with 5th port injection soon been bt 15000 miles no problems |
@dturboman spill the beans |
Quote:
:( so what are your plains with it now? |
Quote:
Quote:
was not even in power when it happen, was doing 50 through a construction zone and it let go. Looks like its going to be built now. |
Sad to see it give....you pushed that little 3071 hard. Any thing seem off before it went. |
Quote:
so it looks like there was no way to prevent it... it was just its time. |
Quote:
Quote:
the miles and the power took its toll on her, now we know 160k and high boost(28-32psi) will last just not forever. going to do rods, pistons and new bearings, hopefully total with machine will be under 3k |
Damn sucks, then again your car was a trooper 160kmi and at 30 psi lol beast. Sent from my DROID4 using Tapatalk 2 |
Quote:
GL with the build |
Quote:
Well here are the specs when it was running Gt3071r with back half ported and coated. 22.5* max timing 625ML & 375ML nozzle running 100% meth c16/93 mix 31-32.5PSI 518 whp 497tq ran 11.9@ 123.4 on 26psi and 450whp |
dude wtf is this shit? take your chit chat outa here, cleaning up in 1 day |
FYI, Here is my BT with stock block dyno thread: http://www.mazdaspeedforum.org/forum/foru...7-9wtq-110833/ |
Just Installed... GTX3076 / IWG 24psi 17* at RL 50/50 E85 100% Meth, D05 About 500 miles on current setup. 39k on Motor, And Beat the Shit out of it Daily!! http://i1217.photobucket.com/albums/...73gz/24psi.jpg |
| All times are GMT -7. The time now is 02:00 PM. |
