Like Tree4Likes
  • 4 Post By phate
 Old 10-10-2011, 07:31 PM   #1
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Default For the big BIG turbo guys who complain about spool time...
Motovative Performance is making these, now for T4 and T6 split tang turbines:
Here's there thread about it on LS1tech: Motovative Insta-Boost Quick Spool valve - LS1TECH
If you want a little bit of history and info about why this is awesome, I pulled this out of the archives from theturboforums (which I was a part of way back when): Faster spool and more boost
Six years ago when we were talking about this, the design wasn't feasible due to reliability...apparently that's been fixed.
Hopefully this isn't a repost!!! @silvapain - this is the type of stuff I was talking about with blocking one side off to increase spool time!!!
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 7 Users Say Thank You to phate For This Useful Post:
kmac (10-12-2011), rfinkle2 (10-14-2011), silvapain (10-11-2011), TexasSpeed3 (10-14-2011), Tomas (12-23-2014), torquemaniac (01-05-2015), WetzMS3 (12-22-2014)
 Old 10-10-2011, 07:34 PM   #2
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
quick spool valves are teh shit
 Old 10-10-2011, 07:37 PM   #3
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
the RDX turbo comes with this stock.
my buddy also hand fabbed one of these for his 325i turbo cause it was so big. i dunno how much effect it had but the concept certainly works.
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 10-10-2011, 08:03 PM   #4
sLow6's Avatar
Posts: 503   (View Stats)
sLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the worldsLow6 is the leader of the world
Groans: 34
wow, i'm still kinda new to the whole turbo thing, but that really sounds like it could be worth the money...
BT Build in process, should have engine running in a couple days.....knock on wood.
sLow6 is offline   Reply With Quote
 Old 10-11-2011, 05:54 PM   #5
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Now I understand what you were trying to say Clint.
That's the same principle used in the VCTS system. Reducing cross-sectional area increases flow velocity.
Imma hafta getme ona dose when Iz go beeg turba
phate (10-11-2011)
 Old 10-11-2011, 06:07 PM   #6
DigitalAssassin's Avatar
Posts: 7   (View Stats)
DigitalAssassin will become famous soon enough
in my field of work (DIESEL MECHANIC) a very similar system is used on the turbos it is a great add-on my only problem with this is if it fails so will your turbo. it happens alot in the diesel field. but one thing is for sure those diesel engines wont run right with out it.
DigitalAssassin is offline   Reply With Quote
 Old 10-11-2011, 07:07 PM   #7
Eth Fiend
phate's Avatar
If it fails, the engine and turbo will be just fine for quite a while. Back in the day, when we were first discussing these and some testing was being done, simple blanks were being made that completely closed off one side of the turbine housing, lol. No serious problems ever arose, except that EGT's went up a bit.
-06 MS6
 Old 10-11-2011, 07:44 PM   #8
Eth Fiend
phate's Avatar
Video showing results on a supra:
-06 MS6
The Following 6 Users Say Thank You to phate For This Useful Post:
chuckms6 (10-11-2011), cshunter (12-22-2014), Dralphy (12-31-2014), rfinkle2 (10-14-2011), spals (12-23-2014), TexasSpeed3 (10-14-2011)
 Old 10-11-2011, 09:41 PM   #9
Interesting - so what failed on these? The hinge mechanism due to the heat? Or was it warping and had too much plate expansion?
 Old 10-11-2011, 09:56 PM   #10
Eth Fiend
phate's Avatar
Back in the day, no one could make a seal for the hinges that would work at gasoline EGT's...apparently they have this solved, now.
-06 MS6
Lex (10-12-2011), TexasSpeed3 (10-14-2011)
 Old 10-11-2011, 10:15 PM   #11
chuckms6's Avatar
Posts: 1,618   (View Stats)
for some reason, i was thinking this would have marginal results. but wow that video removed all doubt from my mind lol
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
The Following User Says Thank You to chuckms6 For This Useful Post:
phate (10-12-2011)
 Old 10-12-2011, 04:15 AM   #12
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Ive thought about the SP one for quite some time, theirs is very well proven.
2006 Mazdaspeed 6
phate (10-12-2011)
 Old 10-12-2011, 05:12 AM   #13
Must Have Teh 10's!
what would this do for backpressure in the 2 blocked cylinders? the RDX turbo uses a flapper to divert ALL exhaust gas to a single side of a TS housing and then as RPM climbs it opens both channels to full airflow.
 Old 10-12-2011, 10:12 AM   #14
Eth Fiend
phate's Avatar
wweeeeeeelllllllll, you couldn't really run this if you had a split header...meaning two cylinders running to one side of the turbine housing, and the other two going to the other side.
This would only work with an exhaust manifold where all runners merge into one before the turbo.
-06 MS6
Enki (10-12-2011)
 Old 10-12-2011, 10:39 AM   #15
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
If you already have a twin scroll, this is pretty useless.
But, what if you have a twin scroll turbo, but a single outlet manifold?
Would that increase spool even further?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 10-12-2011, 11:28 AM   #16
Eth Fiend
phate's Avatar
That's what this is designed for.
-06 MS6
Enki (10-12-2011)
 Old 10-12-2011, 10:56 AM   #17
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
My buddy was going to run one of these on a r33 gtr with a gt42r. He'd sure as hell need it to get any spool before 4500rpm, lol.
07 MS3
The original Genpoo Hater
 Old 10-12-2011, 11:39 AM   #18
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
The only way to really leverage this is with a single collector/scroll manifold mated to a twin scroll turbo.
Just so we're clear, any other combination will at best be ineffective, or potentially harmful to your engine (in the case of twin scroll mani, for instance).
 Old 10-12-2011, 11:42 AM   #19
Scribbles's Avatar
Posts: 861   (View Stats)
Scribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the world
So pretty much a twin scroll gtx42, this instahellaquickspool, and steedspeed would make us gods?
07 MS3
Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel
Perm
Scribbles is offline   Reply With Quote
 Old 10-13-2011, 06:56 PM   #20
Eth Fiend
phate's Avatar
So this guy wanted to eat his cake too:
divided exhaust, going into each side of turbine scroll...with a quick spool valve....sweet ass setup.
-06 MS6
Realgib3 (10-13-2011)
 Old 10-14-2011, 04:03 AM   #21
Tokay444's Avatar
Groans: 793
Is that valve a legit $500?!?
Demodded.
The Seals
 Old 10-14-2011, 07:32 AM   #22
LOL. A legit $500 or a legit valve in general?
 Old 10-14-2011, 07:35 AM   #23
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
well, if they solved the high egt problem from gasoline engines then, they need to start pumping out vane turbos
 Old 10-14-2011, 10:21 AM   #24
Enki's Avatar
Umm.... Some people already use them.
I have one of these turbos in my garage right now; considered it, but it is kind of a big turbo and REALLY REALLY heavy to sling from the side of the 'Speed.
 Old 12-21-2014, 06:25 PM   #25
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
Apologies for the thread revival, but theres been some good discussion in here and I dont want to create a new thread unnecessarily.
I wanted to hear if anyone has gone down this route since early 2011 when this was first discussed?
I'm picking up a Borg Warner S200SX 7670 with a T4 TwinScroll AR1.00 hotside and if this quick spool valve is any good it would save me a lot of hassle as i could then just make up an openscroll T4 mani instead of twinscroll.
My main fear is that plate coming loose and grenading the turbo and motor.
Keen to hear the views on this.
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
 Old 12-23-2014, 08:08 AM   #26
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
I wouldn't worry about the plate coming loose. Seems it's welded on the shaft. Not bolted on.
Even if it dislodged from the shaft, it would probably just get caught in the volute of the turbine housing and not damage the turbine.
Damage to the engine is impossible as it sits downstream of the exhaust valves.
Do it.
Rich990 (12-26-2014)
 Old 12-31-2014, 08:35 AM   #27
Rich990's Avatar
I decided to rather get a twinscroll Mani built, should make more power up top than an openscroll Mani.
MSF in South Africa
Trouble shooting big turbo slow spool time Ckmazdaspeed3 2010 MS3 - Troubleshoot/Diagnostics 87 06-18-2011 10:58 AM
Gt3076 spool time pearl_ms3 MazdaSpeed 3/6 - Big Turbo Builds 27 01-29-2011 11:55 PM
European Union may complain to WTO over Detroit bailout Haltech Automotive News 0 11-14-2008 04:20 PM
Page generated in 0.49293 seconds with 36 queries
