![]() | | #81 | ![]() |
![]() Join Date: Dec 2008
Rep Power: 154 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score
__________________ 2007 MS3: HKS Hi-Power CBE with muffler cut-out, HKS CAI, TurboXS RP, Forge BPV, PTP Air Straightener, OCC, MBC(not hooked up der), Cobb AP, Denso Iridium ITV22 Spark Plugs, PG Turbo Inlet | |
![]() | | #82 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Kent, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,649
Groaned at 32 Times in 14 Posts
Where's your proof? You keep trashing this like it's a pile a crap, why are there logs and people saying it DOES work? If you don't like it, leave. Either prove that it's snake oil, or find another thread to troll. | |
![]() | | #83 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Neutral : +1 score
What I'm saying in is don't be a mindless fool and buy into everything. You have to question things, let tuners listen to you and what you want. You should want something with R&D not looks like something you can buy yourself at home depot. I'm not trying to scare people away. I'm not trying to say this product doesn't work. I'm trying to share my knowledge to other people, including ptperformance here. I'm glad you're butt dyno shows improvements, and I'm glad that testing shows this helps, but why settle for less when you can have more for cheaper. Yes you can pay 20 plus shipping and handling for a meager cut grate and epoxy, but wouldn't it be more worth while to pay less maybe do a little back of the napkin hand calculations and work to get better results. I thought that's what this site is.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold | |
| The Following 8 Users Say Thank You to 86AmishMs3 For This Useful Post: | dcphantom (05-14-2009), FenixTX717 (07-21-2010), flyrevs2 (07-19-2010), FreeFlyFreak (05-12-2009), J-villa (07-17-2010), kramer (05-21-2009), mguiles.jr (07-23-2010), TurboDreams (05-19-2009) |
![]() | | #84 | ![]() |
Groans: 338
| Neutral : +1 score Read carefully into my words I never said it doesn't work, just it's limited. Sorry for giving sharing my thoughts, opinions, and knowledge.
| The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post: | FenixTX717 (07-21-2010), FreeFlyFreak (05-12-2009) |
![]() | | #85 | ![]() |
| Not Ranked : 0 score I guess i misinterpreted your post earlier about it being turbulent after an inch. Alternate opinions are fine, I just read it as "it won't work, but this will" |
![]() | | #86 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45886 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
![]() | | #87 | ![]() |
![]() Join Date: Sep 2008 Location: Phoenix, AZ
Rep Power: 1352 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 813
| Not Ranked : 0 score So I picked this up without much faith thinking whatever, 20$, well see. Drove for a bit to get my butt dyno calibrated, but it took me a while to cut the screen and fit it on properly, drove for a bit and it felt smooth, but I chalked it up to placebo. Swapped it off again and drove a few minutes, immediatelly put it back on and went for a final spin. I think it really has made a difference at low throttle, which includes during shifts, and light tip in. At light tip in and letting the peddle off quickly was a bit jerky/hesitant before, where it now feels smooth. Possibly the current housing doesnt do much without heavy air? Still interested in hearing how this restricts power, though that would be something hard to do with how variable this car. Best mod ever? Hardly. Worth 20$? Seems that way so far..
__________________ Some things. |
| The Following User Says Thank You to evidence For This Useful Post: | Fobio (05-16-2009) |
![]() | | #88 | ![]() |
Groans: 338
| Neutral : +1 score Sorry, that was a little hasty and out of context on my part. The screen WILL work, but like i stated to a limited effect compared to a better engineering honeycomb design with a eighth inch ior fourth inch thickness instead of the thickness of the wires. The wire mesh will make flow more laminar but not fully laminar and a turbulent flow will soon develop. So If you're using the wire mesh, the closer you can get it to the maf the better (don't obstruct sampling portion of it) . But a honeycomb design like the picture i posted has more depth to it which will create more laminar flow and will also allow flow to stay turbulent for longer allowing a little more leeway in where you put the air flow staightener at in your intake tube. Basically I'm saying is that there is room for improvement and I'm saying that why not just pick up some easily sourced honeycomb mesh, cut it and fit it when it will create better air flow then just wire mesh. I don't have hard numbers, because fluid dynamics sucks big hair balls due to intense partial differential equations. But maybe I'll get some heuristics to show some numbers. And I'm lazy. But in most instances what I see what works the best is something that has depth to it (the longer helps develop more laminar flow) and not a wire mesh. I applaud ptperformance in the modification, but I also want to challange them to make a better product for the money. I want to see something more legit and more along the lines of this APR stage III air straightener or Halltech air straightener for corvettes http://www.halltechsystems.com/Photo...uctCode=HC.125
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold Last edited by 86AmishMs3; 05-13-2009 at 02:57 AM. |
![]() | | #89 | ![]() |
![]() Join Date: Oct 2008 Location: Houston,Tx
Rep Power: 429 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
Groaned at 16 Times in 14 Posts
| Not Ranked : 0 score Im not an engineer by any stretch but It makes sense to me .. since I am little slow I looked it up .... nice post Mr... ![]() Laminar flow, sometimes known as streamline flow, occurs when a fluid flows in parallel layers, with no disruption between the layers. In fluid dynamics, laminar flow is a flow regime characterized by high momentum diffusion, low momentum convection, pressure and velocity independent from time. It is the opposite of turbulent flow. In nonscientific terms laminar flow is "smooth," while turbulent flow is "rough."
__________________ 2008 HG Bullitt Mustang. Long Tube headers, SCT tuner,MGW short throw, FRPP hot rod cams high flow cats, charge motion plate delete |
![]() | | #90 | ![]() |
| Thermonuclear Skeet ![]() Join Date: Jul 2008 Location: Triad N.C.
Rep Power: 3875 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,765
Groans: 188
Groaned at 333 Times in 222 Posts
__________________ El Fantasmo Del Negro Helicopter Cat LIVES ![]() | |
![]() | | #91 | ![]() |
| Not Ranked : 0 score Well sir .. I installed it on my fujita CAI .... seemed like it had a "smoothing" effect to the car ... biggest diff. I saw was the lack of low rpm higher gear hesitation .. and by that I mean 3k rpm in 3rd with a little push on the petal doesnt have that slight jerk or bump to it .. Its by no means a miracle cure for the car but it actually did seem to smooth things out a little better .. and again .. no engineer but I think its worth the time to try it out .. if you do install it and dont like it take it out ... fck it, its only 20 bucks .. u dig?
![]() | | #92 | ![]() |
![]() Join Date: Mar 2008 Location: Canada
| Not Ranked : 0 score I'm sure the honeycomb is better at pure "laminar flow" but who says you need THAT in this application? In other words, how much better is the honeycomb going to be over the screen being used here by PTP and being used by OEM's the world over? The term "diminishing returns" comes to mind here. Plus you'd have to fab up something like the Corvette guys did to insert into the airstream somehow 'cause you ain't gonna be able to bend the honeycomb over an intake lip and clamp that down like you can with the screen material. I don't have any of these products but I just wanted to point out the diminishing returns comment and the fact you can't easily retro-fit the honeycomb.
__________________ 2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual. |
![]() | | #93 | ![]() |
Groans: 188
| Not Ranked : 0 score All I am asking is that "Is throttle tip in worth possibly loosing a race?" I wanna see before and afer dynos yall. It may be smoother because you just brought the cars power output closer to its intended power levels. I E its closer to the power you were making when stock. I think it could work and will buy it if it doesn't cost more than 1-2 hp to have in there.
![]() | | #94 | ![]() |
![]() Join Date: Mar 2009 Location: Queens, NYC
Rep Power: 201 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 71
| Not Ranked : 0 score Here's an idea regarding the honeycomb air straightener: Cant we just stack up some of these screens to create a "thicker" screen? Of course the goal would be to align the mesh so you dont reduce the size of the openings. I apologize in advance if this is an absurd idea. |
![]() | | #95 | ![]() |
![]() Join Date: Oct 2008 Location: Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
Groans: 190
| Not Ranked : 0 score I believe the ideas behind this are a little backwards. The mesh doesn't create laminar flow resulting in a better reading, in fact it the opposite. Laminar flow is smooth and messes up the MAF reading (Don't flame keep reading). The mesh creates very small swirls making it easier if our hot wire MAF to read the air flow. I used to have a problem with my 300zx where if you pushed the clutch in at highway speeds the car would stall. (Greddy air filter). The reason for that is the air goes laminar (smooth wit little to no turbulence) and the MAF cannot read the flow properly. The simple fix for me was actually 1 strip of duct tape on the filter. It cause enough turbulence that the MAF could read the air flow. The cross section of the wires is round... round is not aerodynamic. Take a look at the link and you'll see what I'm talking about. http://www.daviddarling.info/images/air_flow.jpg You can see how a hundred little wires will create a lot of turbulence, albeit very uniform turbulence. This is what helps. I'm not trashing this idea, in fact I am doing this mod today. I just want people to understand why/how it works.
__________________ My mission is to go fast. ![]() Currently Designing: The golden girdle of the gods The CF "fuck your face" IM |
![]() | | #96 | ![]() |
![]() Join Date: Jul 2008 Location: Long Island
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 257
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score Im comming from a GM vehicle. My throttle body had the maf comb about 1 - 1.5 inches away from the Maf itself. When it was removed i noticed no difference at lower RPMs except a little better throttle response. BUT when high RPMs were hit the car definitly had a bit more power. Again, not saying it has a big difference in our mazdas. at WOT the comb was a hinderance to air flow, well of course when your going WOT you want as much air as possible almost to the point that a maf reading isnt going to mean to much because its probably the same if not higher than with a comb/screen. Under daily driving it should no doubtfully increase driveability because you dont have the same amount of air being sucked into the intake so you need to direct air over the maf evenly so it recieves a valid reading. i have no doubt that this product would work, after all its almost common sense but i would like to see a before scan @ WOT and an after with the screen @ WOT as well as normal driving conditions. Thats just my .02 |
![]() | | #97 | ![]() |
Groans: 190
| Not Ranked : 0 score The spacing and diameter of the wires is going to determine how much of a restriction the screen creates (obviously). That is why PTP said not to use window screening. Home Depot sells some coarse mesh that I'm going to pick up today and try ($10 CDN for a roll. not sure how big). If the mesh does cause a restriction at WOT i think people would notice... regardless a dyno could put this to rest.
| The Following User Says Thank You to phantom3 For This Useful Post: | 86AmishMs3 (05-13-2009) |
![]() | | #98 | ![]() |
| Team Überfrazn ![]() Join Date: Apr 2008 Location: Plymouth, MN
Rep Power: 324 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 661
| Neutral : +1 score fwiw turbulent flow is more effective at exchanging heat than laminar. in injection molds they try to get as much turbulence as possible to cool them. i wonder if the turbulent flow is making the maf read a different than actual reading by cooling the wires differently for x amount of air. kind of throwing off the calibration a bit for the maf.
__________________ "My car won't start!" "Well, maybe there's a killer after you."-Mitch Hedberg I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming. - Mitch Hedberg |
| The Following User Says Thank You to labikesrcool For This Useful Post: | phantom3 (05-13-2009) |
![]() | | #99 | ![]() |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() Thanks: 0
![]() | | #100 | ![]() |
| Not Ranked : 0 score You know what the funny thing is about all of this? The MAF sensor wire isn't even in the airstream! It's tucked up inside the sensor ... the IAT sensor wire is the only thing directly in the path of the airflow.
| The Following 2 Users Say Thank You to LBV For This Useful Post: | 86AmishMs3 (05-13-2009), FantasmoNegro (05-13-2009) |
![]() | | #101 | ![]() |
![]() Join Date: Jan 2009 Location: Fort Worth, TX
Rep Power: 794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 771
| Not Ranked : 0 score That's what I was about to type.
__________________ Meet a giant fish. Fuck his brains out. |
![]() | | #102 | ![]() |
![]() Join Date: Jul 2008 Location: West Des Moines, IA
Rep Power: 854 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
No gain in doing that unless you're running rich as it simply leans out by altering the effective load table. 2-3 HP or even 5 is within dyno error range from run to run, and not worth doing because of the tuning headaches it causes.
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall | |
![]() | | #103 | ![]() |
Groans: 338
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold Last edited by 86AmishMs3; 05-13-2009 at 02:06 PM. | |
![]() | | #104 | ![]() |
![]() Join Date: Apr 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score I emailed them to see what the specs on their unit is. Diameter etc. |
![]() | | #105 | ![]() |
![]() Join Date: Dec 2008 Location: Everett WA
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score I still say that I don't see any benefit of this piece over the air straightener that someone like JSCspeed sells for $6. I bought that and installed it last night. So far driving the 50 miles or so I've put on it, it does feel a little smoother in part throttle scenarios. Still waiting a few more miles to do some WOT logs.
__________________ |
![]() | | #106 | ![]() |
Groans: 188
Here is a thread about it on LS1 tech and its as confused and convoluted as this one is. But the grand agreement is that it doesn't hurt the car and it has helped some. http://www.ls1tech.com/forums/new-ls...-question.html
__________________ El Fantasmo Del Negro Helicopter Cat LIVES ![]() Last edited by FantasmoNegro; 05-13-2009 at 04:06 PM. | |
![]() | | #107 | ![]() |
Groans: 338
![]() | | #108 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score I am going to go out on a limb here so bare with me. One of the reasons I bought my CP-E CAI is the research that they put into it. If I remember correctly, they chose to restrict their piping to 2.5" around the air sensor to replicate stock conditions for the sensor. They found that 3" pipes were allowing too much unmetered air past the sensor. Is this screen just doing the same thing...(don't take this the wrong way)compensating for a poor 3" intake design? Anyone with a CP-E intake try this with any noticeable results? |
![]() | | #109 | ![]() |
![]() Join Date: Mar 2008 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,984
| Not Ranked : 0 score No, CPE stepped their intake down to 2.75" because at the time, there was no flash available to calebrate the MAF sensor to compensate for the larger diameter. This screen reduces the turbulance of the air, so that the MAF sensor gets a more steady and accurate reading. |
![]() | | #110 | ![]() |
Both had idle stumble problems, stalled while coasting, and generally ran like crap until the MAF voltage vs air tables were altered. I ended up giving up on tuning both of them and putting the stock MAF's back in because it would be fine one day, with no MAF error corrections, then crap the next day for no reason. Just got tired of always messing with them.
![]() | | #111 | ![]() |
Groans: 338
![]() | | #112 | ![]() |
Groans: 188
| Not Ranked : 0 score Not so easy without a tuning device when your running distributorless set up. Oh and most people do not see any drivbility problems from descreening the MAF. All I am saying is sticking something in the air path is counterintuitive for making power. Has no one done a before and after on the dyno yet? Or has it happened and no one posted up the results.
![]() | | #113 | ![]() |
Groaned at 33 Times in 22 Posts
| Neutral : +1 score I really don't mean to sound like a Dick here, but I will I guess. To me this type of fix should be something that is given for free to the community, not charged $20 for something I know damn good and well you paid $20 for a 20ft roll probably. This is a Home Depot fix at best and I'm personally appalled that you charge money for this. Come on guys, are you serious? $20 PLUS Shipping, you have to be joking right. You didn't spend any money actually manufacturing anything here. At least the Plastic Air Straightener they had to actually make a mold and pour plastic! You simply went to Home Depot (or another hardware store) and purchased some screen. I could not sleep at night if it was me. How about just being cool. Post up the part number of the screen you purchased from Home Depot and let the community enjoy the benefits. Seriously guys, capitalism is a good thing, but sometimes companies go too far. Now don't get me wrong. If you actually did research, had a screen custom made to your specs etc. I would have no issue with the price. My issue is charging someone $20 for something you got at a local hardware store for maybe $1. This is DIY type of solution to me and not something that should be marketed as if you actually did some R&D. Last edited by Bravnik; 05-15-2009 at 09:53 AM. |
| The Following 2 Users Say Thank You to Bravnik For This Useful Post: | 86AmishMs3 (05-18-2009), J-villa (07-17-2010) |
| The Following User Says NO Thank You to Bravnik For This Un-useful Post: |
![]() | | #114 | ![]() |
Groans: 188
| Not Ranked : 0 score Look at all the shit we gave Cobb for selling parts with out the R&D behind it.
![]() | | #115 | ![]() |
![]() Join Date: Jul 2008 Location: PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
Groaned at 16 Times in 8 Posts
| Not Ranked : 0 score noone is forced to buy it, it's their choice. but i did make mine out of something i found at home depot. |
![]() | | #116 | ![]() |
| Neutral : +1 score
When it came in the mail it was about 20ft of string and 2 clothes like clips with instructions to run string between two trees/posts and clip clothes to line using the clips. Oh and it said to not use when raining! I shit you not. | |
![]() | | #117 | ![]() |
| Not Ranked : 0 score atleast it came with instructions lol |
![]() | | #118 | ![]() |
Now, that's not to say you can't go get something similar from a hardware store, but it will take some work trying different gauge screen wire as well as spacing between the wire, then logging MAF transfer voltage and a/f ratios to get the results achieved here. They've already take the guess work out of it for you.That's where the charge comes into play. Heck, I built my own air/water intercooler for less than $400 and it worked better than an air/air that people charge over $1,000 for, should they give us their hard work for free too??? Now, that being said, I took about 4 pieces of scrap screen from my local hardware store, matched them closely to what screen was in an extra Ford MAF I had laying around, and used that. This was long before John took the time to find his solution. John's just providing the easy way out for those who don't want to invest the time themselves. Nobody is saying it can't be done yourself... but don't think you can run to HD and buy a roll of screen and make it work right off the bat.
![]() | | #119 | ![]() |
| Neutral : +1 score
My point is that this is a Home Depot fix. Simply post up the part number and let the community enjoy such a simple fix (if it does indeed fix something). This is not something that is complicated like your Air/Water cooler. It's a small bit of screen. You see, I see this as a community that is here to help each other out. Not so we can gouge them by selling them a part that may or may not work. Something like this should be given free as there is no proof that it works, no guarantee, no warranty no nothing. Simply a post saying it's the best mod they have ever done and a charge of $20 plus shipping. It's really cool that they found this, however it would have been a hell of a lot cooler if they said "Hey guys, we found this very cheap DIY fix" and posted it up with part numbers. Now that would have been cool. As for your Air/Water and Ford Screen solution. If I was you I would have done a How To: on each of them and posted it up so the community could benefit from them. However, that's just me. This is just my opinion. Others may vary of course and people are free to do as they wish and buy what they wish. I simply believe that this is a DIY fix and not something that should be charged for......but that's just me. | |
![]() | | #120 | ![]() |
| Not Ranked : 0 score No, if you buy from a gm supplier, they send you a roll. |
| The Following User Says Thank You to ATE BALLER For This Useful Post: | trancehead (08-24-2013) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/best-mod-i-have-ever-done-26160/ | ||||
| Wednesday It's a Grind Meet in Artesia | This thread | Refback | 05-14-2009 12:23 AM | |
