Groans: 433
| Not Ranked : 0 score Why would you go with a holset after hearing about the massive lag and poor transient response? Sent from my your mom's face on my junk
(Thread Starter) | Not Ranked : 0 score Because everyone that has used one hasnt matched it to the car, diesels have generally low egts and low exhaust flow and they spool them just fine. This isnt a hokset turbo thread though. I have now basically completely unshouded the wg flapper and smoothed everything out. My thinking is that if you can get the exhaust through the turbine efficiently and through the wg efficiently it shouldnt be able to back up and blow the wg open and make the boost uncontrollable. The turbine itself should be good for 550-600ish but this housing is really a pile.
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
__________________ | |
| The Following User Says Thank You to helmetface For This Useful Post: | 06Speed6 (10-28-2012) |
| Not Ranked : 0 score the problem is you cant port the flutes inside the housing. thats where the flow really gets choked. theres plenty of people making big power on the ATP hotsides.
| The Following User Says Thank You to superskaterxes For This Useful Post: | 06Speed6 (10-28-2012) |
Groans: 219
From his wording though, I'm guessing it's either IWG or EWG on the mani
(Thread Starter) | Not Ranked : 0 score Its IWG sorry. I looked at the flute and it *seems* ok. I took ALOT of material out of the EM flange/iwg area. In a couple spots im kinda worried about the strength now, but there is really alot of material in some areas that can be taken out with no worries.
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score I posted some pretty decent pics of the porting I had done to mine. I get no creep at all. 3071r build
__________________ '08 CWP MS3 w/ T3 3071r Last edited by 802MS3; 10-28-2012 at 05:15 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to 802MS3 For This Useful Post: | 06Speed6 (10-29-2012) |
(Thread Starter) | Not Ranked : 0 score Yours is ported just a little more and they smoothed everything out better than mine, maybe ill hit it with a burr again and see if I can make it prettier
| v8 convert ![]() Join Date: Sep 2009 Location: (actually in) Tampa, FL
Rep Power: 1203 ![]() Thanks: 2,634
Groans: 220
| Not Ranked : 0 score i never ported mine and get reverse creep... :S
Groans: 433
| Not Ranked : 0 score This is where extrude honing shines, my friend.
| The Following User Says Thank You to Chimmike For This Useful Post: | 06Speed6 (10-30-2012) |
(Thread Starter) | Not Ranked : 0 score So I figured out that if you port the wg hole enough the flapper gets stuck on it and may not close all the way.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | superskaterxes (11-06-2012) |
Groans: 221
| Not Ranked : 0 score ooooo....that sucks luckily a nice dude on here sold me his for $100 shipped, so I'm sure you can find another one.
__________________ '08 CWP MS3 w/ T3 3071r |
(Thread Starter) | Not Ranked : 0 score I figured it out, I put a bevel on the flapper itself and it seats fine now.
![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score Here is the porting that a buddy of mine did for me. I just picked it up from him on Monday. I also have the gtx3071r. Photos here. http://www.mazdaspeedforum.org/forum/foru...ml#post1729258
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package |
| The Following User Says Thank You to Matrix311 For This Useful Post: | 06Speed6 (11-09-2012) |
| Not Ranked : 0 score i ported mine a lot, just stuck some magnets on there to help with the shavings and went to town, no creep on initial set up: UR catted DP - HTP 3" intake - ETS TMIC. However switching to a front mount i did see boost drop a little, as is to be expected, but when i added a 4" intake i was creeping about 2 psi (8 psi wastegate spring but seeing 10-10.5 psi). intake side effects creep just as much as exhaust side it seems.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
| The Following User Says Thank You to Voltwings For This Useful Post: | 06Speed6 (11-09-2012) |
(Thread Starter) | Not Ranked : 0 score @Matrix311 that looks like a nice port job, looks like I need to take more metal out!
| HOW TO: Port turbine housing with IWG | Chimmike | MazdaSpeed 3/6 - Turbo Induction | 2 | 08-12-2011 06:50 PM |
| .64 or .82 turbine housing? | Jarods7920 | MazdaSpeed 3/6 - Turbo Induction | 12 | 05-02-2009 09:43 AM |
