![]() Join Date: Jun 2014 Location: Harrisburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
(Thread Starter) | Not Ranked : 0 score I have the AEM intake currently and the list of mods below as well. My goal is 350-380whp (no idea where I am at right now) and a few people on the chat here mentioned I should switch to a 3 inch ram air intake. I know there are serious benefits for running cold air over ram air and it confuses me why people consistently on this engine run ram air. Also I saw that JBR offers a 3 inch Cold Air Intake piping set-up. If I do upgrade from the AEM intake I would see myself going there before anything else. Any input is welcomed as always. And if anyone has any other advise please throw it out there. For those of you who do not know, I am currently deployed overseas and will be returning soonish and will be starting this work towards my goal soon after I get home. Freektune custom map is first step once I get home before any mod changes unless he has recommendations before I tune. My vehicle info: 2008 Mazdaspeed3 GT w/Tech 17x9 Enkei RPF1 Sumitomo HTR Z II 235/40ZR/17 (Summer) Blizzak LM-60 235/45/17 (Winter) cp-e FMIC w/ 2.5" stainless piping cp-e Stage 2 RMM cp-e Tow Plate Relocation Autotech HPFP Internals AEM Mazdaspeed CAI COBB Tuning Downpipe COBB Catback Exhaust COBB Turbo Inlet Hose COBB BPV COBB Accessport V2 COBB Front and Rear Swaybars COBB Sport Springs Bilstein Struts Mazda Motorsport Rear Camber Link |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
| Not Ranked : 0 score First, people run short ram intakes, not ram-air, unless they are running the CS ram-air intake + FMIC kit. Second, a few degrees difference in intake air temps is marginal once the turbocharger heats the air. There are a few threads that this is discussed in, but basically most of your heat comes from compressing the air not from the intake air temps.
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // |
| The Following 4 Users Say Thank You to nindoja For This Useful Post: |
![]() Join Date: Oct 2011 Location: Murrieta, CA
Rep Power: 2715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,575
| Not Ranked : 0 score The slightly cooler air from a CAI is for not when sucked through the turbo. No gain there. The "ram" air intake really shines when the size opened up. I like 3.5-4", only shitty thing is relocating the ecu, or small battery which adds cost. The larger intakes really make it shine though. *edit, damn beat me to it. |
![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 5050 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,143
Groans: 146
| Not Ranked : 0 score Cuz water AND Cost Only 2 things I could think of right now. oh, and read/search. Too much air isn't all what it's cracked up to be. |
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score @Lex; did an article about it, look up the stratified blog
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP |
| The Following User Says Thank You to SarcasticOne For This Useful Post: | Lex (07-21-2014) |
EDIT: Found the article I attached the link for anyone who wants to read through it as well... http://stratifiedauto.com/blog/a-tec...turbocharging/ | |
| The Following 2 Users Say Thank You to william.fletcher2 For This Useful Post: | DaUberSchwebel (08-03-2014), Lex (07-21-2014) |
| Not Ranked : 0 score If you want 350-380whp, you might want to add a new turbo to your list of mods. The risk of hydro locking the car in wet climates outweighs any possible minor reduction in intake temps. I'd imagine the OEM ducting through the front fascia provides just as cool of air where the typical short ram filter resides, but I can't say I've ever tested it.
| The Following User Says Thank You to JgamB For This Useful Post: | Vansquish (07-15-2014) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 45
| Not Ranked : 0 score I have come very close to hydrolocking many times with my injen cold air. Even bigger risk if you plan on lowering your car.
__________________ atp 2871r, cobb ap,front mount, devils own stage 2 meth,hks ssqv, pg exhaust manifold,port/polished intake mani,intake mani spacer,dnp exhaust electrical cutout,cobb dp, custom exhaust, cpe sri intake,cpe tip, cpe hdfp, turbosmart manual boost controller,itv 22,greddy occ,cpe injector seals, cobb front/rear sways,dominant E rear camber arms,awr endlinks,su front mount, tower bar, drilled slotted rotars/hawk pads |
| 3' htp intake questions | blackms3_71 | MazdaSpeed 3/6 - Turbo Induction | 12 | 02-18-2013 01:09 PM |
| Intake Manifold Questions | starscream | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 06-15-2011 07:14 AM |
| Intake Questions | harryclay | 2010 MS3 - Turbo Induction | 20 | 05-09-2010 11:40 AM |
| Cold Air Intake/BOV Questions, PLEASE HELP | MinnesotaJDM | MazdaSpeed 3 - Engine, Transmission & Driveline | 18 | 03-31-2010 03:11 PM |
