| v8 convert ![]() Join Date: Sep 2009 Location: (actually in) Tampa, FL
Rep Power: 1203 ![]() Thanks: 2,634
Groans: 220
(Thread Starter) | Not Ranked : 0 score Reason why is that I'm thinking it may be the root cause of not being able to stay at 23PSI. Currently, I hit that target and by redline it tapers off to about 20.5PSI WG spring is 14psi using an ATP 3071R. Alternately, this may be fixed by going EBCS too.... But I like the quick and easy setup of my MBC. :\
__________________ |
Groans: 433
| Not Ranked : 0 score nigga didn't I tell you how to do this? remove clip holding actuator onto turbo. use wrench to tighten actuator arm a few turns. Replace actuator onto turbo, replace clip.
| The Following User Says Thank You to Chimmike For This Useful Post: | 86AmishMs3 (11-02-2012) |
Groans: 220
__________________ | |
Groans: 433
| Not Ranked : 0 score no, that was kenny and john. I think they're right, in which case, just go EWG with a bigger turbo.
Groans: 220
Groans: 433
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Can do it by coming from underneath ![]() Sent from my Galaxy Nexus using Tapatalk 2
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP |
Groans: 220
![]() after i buy a used block and new rods/pistons, etc. ughhh.
__________________ Last edited by p057; 10-30-2012 at 06:28 AM. Reason: MSF Database - Automerged Doublepost | |
| Not Ranked : 0 score oh, you have a 6.... my bad
| Not Ranked : 0 score You can do it if you have small hands.
Groans: 220
(Thread Starter) | Not Ranked : 0 score They're pretty small, but I've tried working on the car from under and its extremely cramped, I'd rather keep cutting my hands and straining the hell out of my back.
| Adjusting APP tables | EmPeEs6 | MazdaSpeed 3/6 - ECU Computer Tuning | 8 | 10-11-2012 09:00 AM |
| pads: top spring clip or back spring plate | breakfasteatre | MSF KB - Mazdaspeed 3/6 - Suspension & Brakes | 5 | 09-19-2012 01:44 PM |
| pads: top spring clip or back spring plate | breakfasteatre | MazdaSpeed 3/6 - Suspension & Brakes | 4 | 11-05-2011 09:52 AM |
| Possible track spring spring setup for use with Koni yellows | stretch | MazdaSpeed 3/6 - Suspension & Brakes | 154 | 04-18-2011 12:18 PM |
| Adjusting boost ATR? | zx2man | MazdaSpeed 3/6 - ECU Computer Tuning | 13 | 08-04-2010 02:29 PM |
