![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 346
Groaned at 12 Times in 3 Posts
(Thread Starter) | Not Ranked : 0 score I have heard of loose connections between TIP and turbo, but will this really cause me to not hit my boost targets? Only thing I could think of was my BPV being a leaker, but wanted to know if anyone else had resolved this issue by scrapping the stocker... |
| Banned ![]() Join Date: Mar 2008 Location: Gaithersburg, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 335
| Not Ranked : 0 score So you spike to 18, then immediately drop to 14/12? Or do you spike to 18, hit 17/16, then slowly taper down to 13-14? |
Groans: 370
| Not Ranked : 0 score datarog prease |
![]() Join Date: Mar 2008 Location: In a house
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54
| Not Ranked : 0 score change your valve
__________________ 7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance |
I think i've smoken to many pots and cant friggin figuire out how to view the datalogs, i fail with computers.. Little help? That's what my brother told me also, but I wanted to see if anyone else had a similar problem and remedied it by switching to a better valve. I figuired it would at least hold stock boost levels, but I guess not | |
![]() Join Date: May 2009 Location: Ft Myers, FL
Rep Power: 133 ![]() ![]() Thanks: 1
| Not Ranked : 0 score I haven't loaded a log on this site yet, but this is how I've done it on other sites.. If you have your logs open up in Microsoft Excel, take a screenshot of what you have open (hit the print screen button on keyboard). Save picture, and host picture on a site (or just upload it). Walla, datarog, bery nice! |
| The Following User Says Thank You to slyter485 For This Useful Post: | TenaciousBoost (06-24-2009) |
![]() Join Date: Oct 2008 Location: Diamond Bar California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 560
| Not Ranked : 0 score Sounds like a boost leak since you cant even hold 17psi, I spike to 18 or 19 and taper the closer I get to readline. Maybe its time for HKS?
__________________ 2009 Crystal White Pearl MazdaSpeed 3: Cobb SF intake, HKS ver 2 BOV (Recirc), Cpe 70 Duro RMM (Removed), Hid Kit, 18 Inch Flat Blk, Tenzo Cuzco's... ver 2, Cobb Springs and the Cobb AP Stage 2... Coming Soon... Koni Yellows, 60 Duro, ?mm wheel spacers, FMIC, and im currently waiting for my FP to go out BEAST MODE 2007 Alabastar Silver Honda Civic SI: Injen SRI, Greddy Evo 2 CB, P2R Throttle Body Spacer, Buddy Club Race header. KIA I ![]() |
__________________ 7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance | |
So I view datalogs through MS Excel? I thought I was supposed to view them through the accessport manager or ATR.. Probably why I couldn't figuire out how to view them | ||
![]() Join Date: May 2009 Location: Toledo, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 121
| Not Ranked : 0 score Yeah, Excel is a good viewer to use. Go into the AP Manager while your AP is connected and choose the View|Advanced menu (or something like this). It will then pop a dialog where you can download the logs from the AP to your hard disk. Then, navigate to that folder and open the CSV files with Excel. For ATR it will log to a folder on your laptop. Mike
__________________ ToledoSpeed3 ![]() 09 MazdaSpeed3 GT, True Red |
| The Following User Says Thank You to ToledoSpeed3 For This Useful Post: | TenaciousBoost (06-25-2009) |
![]() Join Date: Sep 2008 Location: CT/NY
Groans: 35
| Not Ranked : 0 score Mine used to do the same and it was from a boost leak on the intercooler hoses.
__________________ ---------------------------------------------------------------------------- '06 Speed 6 Black MicaMazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe, 3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp Altered Customs fmic, Autotech fp internals Cobb AP, Stage 2+ 93 tweaked Centric blanks, EBC red pads Lotek center gauge pod: AEM wideband, Autometer boost and volts Tints, blacked emblems, spec-v front lip, Shark fin Redline MT-90, ITV-22s, Matt Damond OCC 13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap) DO Meth kit waiting on install |
| The Following User Says Thank You to Docnox For This Useful Post: | TenaciousBoost (06-25-2009) |
(Thread Starter) | Not Ranked : 0 score Dang, I'll go check those asap, that would be a super easy fix. There are a total of four clamps to check between the hot and cold pipe right? Was it obvious they were loose, I took a glance at them this weekend but nothing looked unsecured, maybe I should go tighten them all down anyway |
Groans: 35
__________________ ---------------------------------------------------------------------------- '06 Speed 6 Black MicaMazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe, 3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp Altered Customs fmic, Autotech fp internals Cobb AP, Stage 2+ 93 tweaked Centric blanks, EBC red pads Lotek center gauge pod: AEM wideband, Autometer boost and volts Tints, blacked emblems, spec-v front lip, Shark fin Redline MT-90, ITV-22s, Matt Damond OCC 13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap) DO Meth kit waiting on install | |
(Thread Starter) | Not Ranked : 0 score Well, I tightened down all of the clamps on intake, inlet and intercooler hoses and still no luck with my boost problem.. Maybe its the bpv afterall. Would watching wg duty cycle help to clue me in if I actually have a leak or if its possibly tune related? Would my wastegate be maxed trying to make up for the leak? I also remember hearing something about a loose connection on throttle body being a problem, wasn't sure what to look for when tightening the other clamps. How do I find the throttle body, is it near the intake manifold? |
| The Following User Says Thank You to clos561 For This Useful Post: | TenaciousBoost (06-27-2009) |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| Not Ranked : 0 score TenaciousBoost hey bro im haven the same issue maybe we can figure this out. I did a boost leak test with an air compressor and I do not have a leak.
__________________ |
I might try switching back to the stock map on my accessport to see if the boost levels change at all.. Not really sure what else to try | |
Groans: 102
__________________ | |
![]() | | #19 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Winter springs
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,251
Groans: 974
Groaned at 738 Times in 373 Posts
| Not Ranked : 0 score Shit I'm stock and my 2nd gear holds 12-12.5 PSI from 3000-5800. |
![]() | | #20 | ![]() |
Groans: 102
| Not Ranked : 0 score where u at? whats the temp?
![]() | | #21 | ![]() |
Groans: 974
![]() | | #22 | ![]() |
Groans: 102
| Not Ranked : 0 score yeah see 80 is diff then 105 here. your prob still high boost just sayen,
![]() | | #23 | ![]() |
Groans: 974
| Radio Reception sucks | acehigh | MazdaSpeed 3/6 - Car Audio & Electronics | 1 | 02-26-2009 09:49 AM |
| Boom this shit sucks | speed_3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 124 | 02-04-2009 12:54 PM |
| OMG, this sucks for all of us. | ptperformance | MazdaSpeed 3 - Engine, Transmission & Driveline | 59 | 06-13-2008 01:14 AM |
