![]() Join Date: Sep 2009 Location: salem oregon
Rep Power: 187 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
__________________ Boobs.....because you can't motorboat a personality. |
![]() Join Date: Feb 2011 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
Groans: 46
| Not Ranked : 0 score Does it happen with only one map? or all of them? Edit: Dude, there is no RPM column on your log. Makes it hard to determine stuffs.
__________________ Current Build: Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR Chome Molly JBR SSP, ProSport Premium Boost Gauge, 25% e85 Tune PTP HPFP Internals, CorkSport Intake/TIP, Cobb Sport Springs Sold: 2008.5 Black Mica GenWon - Fully Bolted |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score yikes. Practice datalogging and do a MAF Cal. HOW TO CALIBRATE YOUR MAF! With An Example select default logging preferences or whatever it says on your AP and it should set you up decent.
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER Last edited by SofaKingAwesome; 02-24-2012 at 01:53 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to SofaKingAwesome For This Useful Post: | rfinkle2 (02-24-2012) |
(Thread Starter) | Not Ranked : 0 score I was trying different maps sorry i will do another log later today. I haven't calibrated the MAF on the new map yet bc of the boost problems.
| Not Ranked : 0 score You have either a bad boost control solenoid, or a wastegate actuator problem. If you look @ the logs, your car is running 0 wgdc for some reason. Edit: Actually I cannot tell from your logs that the above is your problem for sure. (I looked @ it too quickly the first time) Most of your log is not WOT operation. Can you catch a log from 2500 rpm - redline? As Sofaking said, reset the default logging parameters on your AP when you get a chance, and hit us with that log. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | SofaKingAwesome (02-24-2012) |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
| Not Ranked : 0 score yellow no shims.
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
| POWERED BY POLSKA ![]() Join Date: Apr 2010 Location: Eagle, WI
Rep Power: 389 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 948
Groans: 38
| Not Ranked : 0 score maf=first
__________________ BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB 25%E85FREEKPERMED |
(Thread Starter) | Not Ranked : 0 score Ok i took another log 3rd thru 4th. I did turn on my logging options for a better log. If i need to add something else let me know ill try again thanks guys! ops wrong log ap didnt catch one of my log but this one should work.
Groans: 890
| Not Ranked : 0 score ya gonna post the damn thing?
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
Rep Power: 3746 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
Your log shows NOTHING useful. If you're doing a MAF calibration log, you should be using low throttle, basically staying out of boost and running from about 3k RPM to redline. If you're doing a WOT log, you actually have to log from about 3k RPM to redline while you've got the pedal to the floor. The log you gave us shows nothing of the sort. The only thing I can say conclusively is that your MAF is not calibrated well, as you're definitely not within (abs)2 of 0 for your LTFTs.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| The Following User Says Thank You to Vansquish For This Useful Post: | SofaKingAwesome (02-24-2012) |
(Thread Starter) | Not Ranked : 0 score changed sorry posted wrong log. The previous log i started then i saw a cop and had to try somewhere else sorry again.
| OK...so here's my own experience with the latest (Boost-tuning) OTS maps from Cobb. I should preface this by saying that my car is a 2006 MS6. Because they were the newest thing from Cobb, I downloaded and installed a Boost-Tuning OTS map when Cobb made them available. I noticed that I was hitting lower boost than stock levels and that the car felt significantly down on power relative to my previous Load-Tuning map. I fiddled with everything from load targets to boost targets to WGDC to Ignition and even dabbled a little in VVT. No matter what I did (granted, I was making small adjustments), I couldn't get back to the 17.5-18psi of boost that I'd been running on my previous Load-map, and the car was noticeably more sluggish (VD said I'd lost about 30hp and 40tq on the Boost map). On the Boost map, I was only hitting about 13.5-14.5psi, and was unable to do any better despite the map's target of 17.5psi. I switched back, revised my most recent Load map with some things that I'd learned, and the car is back to its old self...but even faster (tweaked a few things).
| The Following 2 Users Say Thank You to Vansquish For This Useful Post: | rfinkle2 (02-24-2012), YokiMazoku (03-01-2012) |
(Thread Starter) | Not Ranked : 0 score I still have my old map that worked great i will try switching back to that later today and give it a try.
Groans: 46
| Not Ranked : 0 score Looks like you can't pass 14 psi. That is the wastegate spring pressure. Might be your solenoid or your wastegate that is messed up.
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score Your WGDC is very low
__________________ |
| The Following User Says Thank You to silvapain For This Useful Post: | rfinkle2 (02-24-2012) |
| Not Ranked : 0 score Are you on the stock turbo? Your MAF is reading very high for a stock turbo and 13psi. The high reading of the MAF means your calculated load is high - so the ECU is running all the boost it needs to hit those load targets. I am suspecting a leak between the turbo outlet and the motor. The turbo is pulling the air through the MAF causing it to read high but the boost pressure is lost before it gets to the manifold. If you are on a larger turbo then indeed you might be flowing that much air in which case you have to target higher load values to increase boost.
| The Following 2 Users Say Thank You to Lex For This Useful Post: | rfinkle2 (02-24-2012), YokiMazoku (03-02-2012) |
(Thread Starter) | Not Ranked : 0 score Thanks everyone for all the help! I did another boost leak test it seems my TIP is messed up like i originally thought. Looks like it has just gotten worse. Managed to get a hold of Mark at street unit everyone seems to love this guy now i know why he hooked me up after the huge ordeal i had a few weeks back. I should have it wednesday or thursday this week. Thanks Mark!
| The Following User Says Thank You to YokiMazoku For This Useful Post: | rfinkle2 (02-26-2012) |
(Thread Starter) | Not Ranked : 0 score So i ran another boot leak test since lex suspected i had another leak after the TIP. Which he was correct. However im still stuck at 12psi. So i finally got a chance to load up my old map "load base tuning" and now 16-17 psi boost. WTF is going on why is that? I tried different new boost base tuning maps and they all get me stuck at about 12-13 psi.
![]() | | #19 | ![]() |
Groans: 433
| Not Ranked : 0 score Leak after the TIP? dude, the TIP doesn't EVER see boost. it sounds like you're not checking the box for boost based tuning or something
| The Following User Says Thank You to Chimmike For This Useful Post: | rfinkle2 (03-02-2012) |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score box is checked. Thats not it.
![]() | | #21 | ![]() |
Groans: 46
| Not Ranked : 0 score Odd, I'm having a similar problem. Can you post one of your load based maps so I can try and see what happens? Sent from my HTC Evo 3D using Tapatalk
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ok so i did a quick pull in fourth gear and noticed some kr so i got off of it can anyone shine some light on this? The maps i have are the 1.08 but they are modified some. Ill post one later. This i the new log i just did.
![]() | | #23 | ![]() |
Groans: 46
| Not Ranked : 0 score Please post the map when you can, I'd like to try it. Thanks!
![]() | | #24 | ![]() |
| Miembro ![]() Join Date: Jun 2008 Location: Puerto Rico
Rep Power: 420 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,095
Groans: 27
| Not Ranked : 0 score what box do you have to check?
__________________ 2008.5 MS3 Metro Gray...slow |
![]() | | #25 | ![]() |
Groans: 890
![]() | | #26 | ![]() |
![]() Join Date: Sep 2011 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
| Not Ranked : 0 score When I first flashed to one of Cobb's stage 1 OTS maps..I had the 12 psi/ 0% WGDC issue too. Reflashed to stock, and flashed it AGAIN to the stage 1 map and it was fine. I have NOOO idea what changed from the first try to the second. |
![]() | | #27 | ![]() |
Groans: 890
| Not Ranked : 0 score You can try the "Open map in ATR, save in ATR, push to AP, and reflash car trick" Can't hurt.
![]() | | #28 | ![]() |
![]() Join Date: Oct 2009 Location: DFW - TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,477
| Not Ranked : 0 score ^^^ totally agree, also double check AP firmware and ATR version have you tried to contact anyone at Cobb? could be some kind of known issue???
__________________ 2016 - WRX -Cobb AP - Perrin Shift Stop - Perrin Trans Mount - Whiteline Positive Shift Bushings 2006 - MS6 - Dead RIP [SIGPIC][/SIGPIC] |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/12psi-boost-106167/ | ||||
| MazdaSpeed Forums | This thread | Refback | 02-26-2012 03:01 AM | |
| Only running 12psi- spring pressure | speed23 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 21 | 02-25-2012 06:52 AM |
| wont boost past 12psi | kachow22 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 12 | 07-23-2009 05:45 PM |
| Stand Back only boosting 12psi? | steven88 | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 07-18-2009 08:24 AM |
