| The Following 8 Users Say Thank You to Lex For This Useful Post: | 06Speed6 (07-15-2011), 802MS3 (07-14-2011), Fobio (07-14-2011), karl-hungus (07-15-2011), kmac (07-14-2011), labikesrcool (07-15-2011), MPSdriver (07-15-2011), rfinkle2 (07-14-2011) |
![]() Join Date: Jun 2010 Location: li, merrick, new york
Rep Power: 2273 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,757
| Not Ranked : 0 score I use ky in mine so I think I'll be ok. |
| The Following 5 Users Say Thank You to kmac For This Useful Post: | karl-hungus (07-14-2011), manelscout4life (07-14-2011), ScarMS3 (07-14-2011), tddvrrn (07-14-2011), trf5000 (08-21-2011) |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
| The Following User Says Thank You to karl-hungus For This Useful Post: | kmac (07-14-2011) |
| Not Ranked : 0 score I'm pretty sure I read this is the chemical reduced in Mobil 1 (US spec) recently. This is exactly why I pm'd you so you could recommend oil to me Lex. |
Groans: 74
| Pennzoil Ultra...
| The Following 5 Users Say Thank You to Haltech For This Useful Post: | Fobio (07-14-2011), jonlax (08-21-2011), kmac (07-14-2011), labikesrcool (07-15-2011), the_caruch (07-15-2011) |
Groans: 74
| Not Ranked : 0 score Pennzoil Ultra Q&A - Bob is the Oil Guy As you might expect we are not able to disclose our formulation secrets. What we can tell you is that Pennzoil Ultra™ contains a unique anti-wear system that is a variant of (ZDDP or ZDTP) Zinc DiThioPhosphate and is designed to protect the engine from wear in different ways under different operating conditions. However, this is only part of our anti-wear componentry.
| The Following 4 Users Say Thank You to karl-hungus For This Useful Post: |
Groans: 74
| Not Ranked : 0 score so are we supposed to use a zddp additive? mongo confused.
| The Following 2 Users Say Thank You to karl-hungus For This Useful Post: | kmac (07-14-2011), manelscout4life (07-14-2011) |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
| Not Ranked : 0 score Penz has it, as pointed out above...
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot |
Groans: 74
| Not Ranked : 0 score penz ultra has something 'similar' but it's not zddp.
Groans: 451
| Not Ranked : 0 score I think the concept is that it functions the same. I am fairly certain the engine was manufactured knowing that people were going to use the available lubricants in their market. Also of note, this engine has been out for a few years now and people have 100k+ mile motors with many different oils in them.
![]() Join Date: Dec 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
| Not Ranked : 0 score Lol who gives a shit?? How many of you know someone or yourself have experienced an engine failure directly related to the brand of oil you use???? Probably none! As long as you use the right viscosity you are fine, modern oils are legit. Thats why we have ratings and certifications
__________________ 2010 MS3 Liquid Silver: TRZ Poly RMM, Cobb AP, PERM (Load-Based FTW), CP-E HPFP, SURE Aeros, HTP TIP, Corksport TMIC, SURE Boost Tubes, Magnaflow CBE, Corksport T/P, JBR LE Shift Knob & Weight, Redline MTL, Swift Spec-R, TSW Nurburgring 18x8.5, Nitto NT555 235/40/18. If You Don't Like The Pu, Don't Play In The Pu. |
Groans: 74
| Not Ranked : 0 score i hear you, bucker, but i'm worried i have subjected my engine to premature cam/valvetrain failure. i've only used pp and rotella. is my engine okay? Reduced ZDDP oils have been cited as causing damage to, or failure of, classic/collector car camshafts and lifters with flat tappets which undergo very high boundary layer pressures and/or shear forces at their contact faces, and in other regions such as big-end/main bearings, and piston rings and pins.
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score I recently saw a white sheet put out about this by forced performance basically saying modified motors shouldn't use oils without this stuff. To prove their point they tore down the motor on their shop Evo, took pics,switched thier oil from a 20w-50 racing oil with zzdp to 10w-30 synthetic (I forgot the brand), did a bunch of dyno pulls, tore it back down and took pictures of significant thrust bearing wear. Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
| The Following 4 Users Say Thank You to Ziggo For This Useful Post: |
Groans: 74
| Not Ranked : 0 score finding the perfect dog shit avatar is distracting me from my zddp anxiety.
(Thread Starter) | Not Ranked : 0 score The interesting thing is that the new certifications for oil call for very little to no ZDDP because it messes with emissions equipment. I have looked quite a bit and I haven't found anything else that coats metal parts inside the engine as well as ZDDP in spite of what Pennzoil claim. High output engines such as ours see lots of piston ring loading, lots of bearing load, and we have a CDFP running fairly high pressures. Quite a few people here have compression loss. We also know that our motors are hard on the oil and wash it off the cylinder walls. ZDDP seems like a good idea to have in vehicles such as ours. |
![]() Join Date: Nov 2010 Location: windsor ontario canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score I use acdelco EOS with every oil change in my cars. I stopped buying synthetic for the malibu,civic and sunfire and went with semi-synthetic with the EOS and all three are running WAY smoother then with full synthetic. It actually is shocking how much quieter the motors get with ZPPD in there. |
| The Following User Says Thank You to troubled81 For This Useful Post: | rfinkle2 (07-15-2011) |
![]() | | #19 | ![]() |
![]() Join Date: Mar 2009 Location: Portlandia, Oregano
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,295
Groans: 196
__________________ |
| The Following 2 Users Say Thank You to triplejumper18 For This Useful Post: | karl-hungus (07-15-2011), rfinkle2 (07-15-2011) |
![]() | | #20 | ![]() |
Groans: 74
| Not Ranked : 0 score sounds like rotella has a high phosphorous content, but i'm going to pick up some zddp for peace of mind. no cats = no worries. good work, lex. I say go with the oils that have high zddp. It is easier and cheaper to replace cats than it is to rebuild an engine. Since it is a pre-OBD engine, you won't get a fault code even if the cats are bad, which they could be already. Since your car is a 1994, it was designed to work with SH oils, which allowed up to 1200ppm of Phosphorous in 30-weights, and had no limit for 40-weights. It would be good if you could stay close to the 1200 number. Mobil 1 0w40 has 1000ppm of Phosphorous. M1 TDT 5w40 has 1100ppm. M1 15w50 has 1200. Shell Rotella T6 5w40 has 1200.
![]() | | #21 | ![]() |
| Not Ranked : 0 score So, considering ZDDP is beneficial for our cars (without regard to the emission system), would the additive + an oil with good fuel dilution resistance be best? What are you guys thinking of using / switching to? Like many people, I'm currently using Pennzoil Platinum. |
![]() | | #22 | ![]() |
Groans: 74
| Not Ranked : 0 score i'm sticking with rotella and will likely buy this snake oil ---> ZDDPlus Classic Car Engine Oil Additive - Flat-tappet and High-performance engines i don't want to add the crap advance is selling. 1 qt is too much.
![]() | | #23 | ![]() |
| Fuck sushi rolls ![]() Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,168
Groans: 356
| Not Ranked : 0 score wut?
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE |
![]() | | #24 | ![]() |
Groans: 74
| Not Ranked : 0 score i'm picking some up on ebay ---> zddp | eBay
| The Following User Says Thank You to karl-hungus For This Useful Post: | rfinkle2 (07-15-2011) |
![]() | | #25 | ![]() |
![]() Join Date: Nov 2010 Location: Rutherfordton, NC
Rep Power: 312 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
Groans: 31
Groaned at 28 Times in 15 Posts
| Not Ranked : 0 score Yeesh |
![]() | | #26 | ![]() |
| The Following 2 Users Say Thank You to Ziggo For This Useful Post: | karl-hungus (07-15-2011), rfinkle2 (07-15-2011) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score That is where I got that Mobil 1 reference, but couldn't find it again. Thanks Ziggo. | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | karl-hungus (07-15-2011) |
![]() | | #28 | ![]() |
Groans: 74
| Not Ranked : 0 score i bet the '5w40 turbo diesel' with the high zinc and phosphorus content in the white paper is rotella. regardless, i picked up some zddp 2 oz bottles on ebay for my next oil change.
| The Following User Says Thank You to karl-hungus For This Useful Post: | laxplayermjd (07-15-2011) |
![]() | | #29 | ![]() |
![]() Join Date: Jul 2009 Location: Vancouver, BC
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score Fuck dudes, this is alot of mythology from back in the day when people didn't know how to design in the first place or, modify engines. This stuff mattered in an old school SBC which took 40 pounds of torque to turn over its stock shitty valvetrain design. Chuck a high lift cam in there and bam, wiped lobes. Modern engines run closer tolerances and better designs. You can't in a million years compare our "flat tappets" being directly actuated by the cams to the crap pushrod setup in an old SBC. There's just nowhere near the drag. My fuckin' bike has "flat tappets" too, I guess, (caps and shims) and it hits its limiter at 13,750 out of 1 litre. What's "hard on the oil" in this engine is running it past a bearing journal in the turbo at 1300+ degrees. That goes for any turbo car and ZDDP won't help you there. Just change the oil more frequently and get on with life. |
![]() | | #30 | ![]() |
Specifically, this paragraph (thanks again Ziggo): There were two things different in this test. The first thing was that we changed to Mobil 1 10 the second thing was the result, thrust bearing damage. The thrust bearing was starting to burn around the edges. The edges of the steel thrust collar and the tips of the steel thrust ramps had both turned blue from heat and started to smear the metal. Datalogs of the oil temp and pressure showed that both temp and pressure were virtually the same as with the Brad Penn oil, but the result Mobil 1 10W-30 engine oil. | |
![]() | | #31 | ![]() |
Groans: 451
| Not Ranked : 0 score This was one of FP's "approved" oils.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot Last edited by Bucker; 07-15-2011 at 09:36 AM. |
| The Following User Says Thank You to Bucker For This Useful Post: | rfinkle2 (07-15-2011) |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Another very strong consideration in our motors are valve deposits which are heavily dependent on oil choice as it's circulated through the PCV and over the intake valves. For VW it was such an issue that they have a spec that oils must comply with to be used in their DI engines. 502.00 was their old spec and I believe it was replaced by 504.00. There are lists of approved oils for their DI application to prevent deposits. Modern oils are much better. However in the compromise with emissions we know that some things are sacrificed and I wanted a conversation around that. Even though our tappets don't see the loads old motors did, there are other metal surfaces that see high loading. Something I have yet to find is a writeup showing the wear protection from whatever the manufacturers have replaced ZDDP with. Then it would be settled. Quote from BTOG forum:
| The Following User Says Thank You to Lex For This Useful Post: | rfinkle2 (07-15-2011) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Ahh i can see it now.... All of our cars are running excellent now but once this ZDDP business catches on its gonna be like the "fuel pump internal craze" that swept the forum and everyone is going to NEED it. Remember how many genpu's blew-up becuz they didnt upgrade their pumps... I love this forum but sometimes it seems like it breeds paranoia lol.
![]() | | #34 | ![]() |
| Not Ranked : 0 score I'm still looking to see if the Valvoline oil above is vw 504.00 approved. Has anyone been able to find that out yet? |
![]() | | #35 | ![]() |
Groans: 196
| Not Ranked : 0 score https://erwin.volkswagen.de/erwin/vo...0400_50700.pdf Volkswagen Oil Standard 504.00 / 507.00 Approved Oils | my-gti.com
__________________ Last edited by triplejumper18; 07-15-2011 at 11:10 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to triplejumper18 For This Useful Post: | rfinkle2 (07-15-2011) |
![]() | | #36 | ![]() |
Groans: 451
![]() | | #37 | ![]() |
This is not about paranoia. This is about becoming educated. There's a difference. | |
![]() | | #38 | ![]() |
Groans: 74
| Not Ranked : 0 score the good news is zddp is cheaper than internals.
| The Following User Says Thank You to karl-hungus For This Useful Post: | Angr-E1 (07-15-2011) |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Thanks for the links guys. I guess my confusion is more related to most of the oils on the forced performance site being "race" oils, whereas VW's recommendations are "street" oils. The key must be to find a vw504.00 approved oil with high zddp content. |
![]() | | #40 | ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/zddp-lacking-modern-oil-85945/ | ||||
| Volkswagen Oil Standard 504.00 / 507.00 Approved Oils | my-gti.com | This thread | Refback | 03-07-2013 03:12 PM | |
| Why Are Modern Cars So Expensive? | Haltech | Automotive News | 0 | 11-10-2010 12:50 PM |
| The pop-up tent goes post-modern | Haltech | Automotive News | 0 | 04-09-2009 04:40 PM |
| Hello, our name is Modern Automotive Performance. We're new here ;) | maperformance | Modern Automotive Performance | 20 | 12-22-2008 11:26 AM |
