![]() Join Date: Jan 2009 Location: The Woodlands, TX
Rep Power: 0 ![]() ![]() Thanks: 2
![]() Join Date: Nov 2008 Location: Roanoke, Va
Rep Power: 0 ![]() Thanks: 26
| Not Ranked : 0 score Royal Purple is great oil. Some say the best. I run Mobil One, which is some good stuff, but mainly because I get a pretty good discount on it where I work. All previous cars I have run Castrol Syn-tec with no complaints. |
![]() Join Date: Oct 2008 Location: Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
Groans: 190
| Not Ranked : 0 score Mobil 1, full syn. here. Royal purple syncromax in the tranny |
![]() Join Date: Nov 2008 Location: Raleigh NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
Groaned at 16 Times in 3 Posts
| aspiring turbo guru ![]() Join Date: Dec 2008 Location: Minnesota
Rep Power: 241 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 245
| Not Ranked : 0 score Amsoil FTW. Paying $10 to become a 'preferred customer' yields decent prices, too. I've got their 5W-30 synthetic in my MS3. I used it in my 1.8T and the stuff WORKS - I had like-new compression at 81k miles, nearly half of which were Stage2+ fun. |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| Not Ranked : 0 score I heard Amsoil is good and mobile one and penzoil. I use Royal Purple car runs real good on it!
__________________ |
![]() Join Date: Nov 2008 Location: Dallas, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 179
| Not Ranked : 0 score purple fluids FTW i switched at 10,000 and works great |
| ive used Royal Purple in all my vehicles since 1997. I had it in the MS3 from 500 miles, but recently switched to Pennzoil Platinum based on the great oil analyst received with it at 26K. Another issue was with the 5/30 RP i was getting a huge amount of smoking out the tailpipe. When i switched over to the PP 5/40 Euro Formulation, all of my smoking disappeared. The Royal Purple 5/40 is $10 a qt and reality is, if im going to spend $10/qt on their oil, i will buy Amsoil or Redline as its formulation is far some superior and true synthetic. I can find the PP 5/40 for $5/qt online or even hit a Jiffy Lube that also carries it since finding it locally is a rare. So to sum it up, majority of us need 5/40 and PP is a great oil for the $$. RP 5/40 is expensive and not worth it at that price point.
Groans: 102
__________________ | |
![]() Join Date: Mar 2008 Location: Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,050
| Not Ranked : 0 score Pennzoil Platinum, I've gotten some really good oil analyses with it.
__________________ 2007 Sunlight Silver MS3 Graphite RX8 Rims · 235/40R18 Kumho SPTs BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 225
Groaned at 70 Times in 44 Posts
| Not Ranked : 0 score Crossbow put a bunch of UOAs up that showed pennzoil platinum had the best results in these cars. It resists sheer due to fuel dilution better than all others. IIRC, M1 was one of the worst. |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
__________________ '08 CWP MS3 w/ T3 3071r | |
| Not Ranked : 0 score If anyone is bored, do a google search on streetcommodores Oils Ain't Oils. It's like a 6 MB PDF download that has some decent comparisons on quite a few oils. I think it was back in 2004-2005 when they did this so there could be some differences at this point. I still like RP and will stick with it through the life of my speed. My motor hasn't popped yet at lease ![]() -GG |
| Unless you are using the Racing fornula of RP, Amsoil is a better oil.. I buy my PP from... Pennzoil Synthetics & Blends
| The Following User Says Thank You to Haltech For This Useful Post: | 802MS3 (01-02-2009) |
Is there some analysis related data that you can share that shows PP out performing RP, I will be more than willing to review it with an open mind as I would certainly like to put the best oil possible in my vehicle - besides from what you are stating above I could be saving money. I like that idea. Other than personal use and comparison, I found the Oils ain't Oils article useful to determine that RP was pretty damn good stuff - even the non race. Thanks, -GG Last edited by gdg; 01-02-2009 at 11:53 AM. Reason: type-o | |
Shell is who made this oil and stopped selling it under their label. Pennzoil got the formulation from them and theres good info on that site as to why pennzoil ended up with it.
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
| The Following User Says Thank You to Haltech For This Useful Post: | gdg (01-02-2009) |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score I was a loyal M1 fan until this car...made the switch over to PP...on sale this week for $25CDN for 4.4L...haven't smoked since... was tracking hard on M1 once in the MS3 and had smoke...
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
Thanks much, -GG | |
![]() | | #19 | ![]() |
![]() Join Date: May 2008 Location: Long Island, NY
| Not Ranked : 0 score What do you guys think about conventional Penzoil? I haven't done a UOA yet, but I change my oil every 3k. Is it worth spending the extra money on synthetic Penzoil if you change your oil frequently? |
![]() | | #20 | ![]() |
| Not much of a conventional pennzoil guy. also, for those who cant find the PP, the same oil is a available under Quaker State but i havent been able to locate it yet.
![]() | | #21 | ![]() |
![]() Join Date: Mar 2008 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,984
| Not Ranked : 0 score Considering that whatever you put in is going to be mixed with ~1qt of whatever you had in there before, I wouldn't use any synthetic oil until the balance shaft assembly is out of there. |
![]() | | #22 | ![]() |
Groans: 221
| Not Ranked : 0 score hmmm, good thought. What is the total oil capacity once the BS is removed?
![]() | | #23 | ![]() |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score i heard rotella t 5w40 is good too. my dealer does my changes with the oil i give them but i only give them 5.5qt to put it or a little less then i'll top it off if necessary. i still have the balance shaft. |
![]() | | #24 | ![]() |
| Not Ranked : 0 score ~6.8qts after the BS is out. |
![]() | | #25 | ![]() |
Groans: 44
| Not Ranked : 0 score that'd be 6.5 litres for us metric folks.
![]() | | #26 | ![]() |
![]() Join Date: Sep 2008 Location: North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 92
Groaned at 9 Times in 6 Posts
| Not Ranked : 0 score I've used PP since my first oil change. Generally I can find it on sale at one of the local places (Auto Zone, Advance, O'Reilly's, etc.) at a pretty decent price. They'll sometimes include a filter as well and I get that free filter for the CX-9 as I like using WIX filters. |
![]() | | #27 | ![]() |
![]() | | #28 | ![]() |
Groans: 44
| Not Ranked : 0 score why do you prefer 5w40 over the 5w30 that is so widely available? I used to hunt for oil myself but couldn't bother anymore...my friends hunt down German Castrol Syntec too...
![]() | | #29 | ![]() |
| Stopped all of my smoking issues Fob
![]() | | #30 | ![]() |
![]() Join Date: Mar 2008 Location: North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
| Not Ranked : 0 score I have been a loyal M1 user for over 30 years with no complaints. I have switched to PP after studying up on BITOG, the analyses do not lie. I use 10W-30, not 5W-30 because I live in NC where the weather is mild and I am usually parked in a heated garage. 10W-30 is also more stable than 5W-30, resisting viscosity reduction from shear better Personally, I think 40 weight is a little thick for this engine in most areas but I can't back this up with any real data. When an engineer specifies an oil, the upper viscosity is usually related to the operating clearances at full operating temperature. The lower viscosity is related to the same clearances at the coldest operating temperature. To those using 40W, I would just recommend that you make sure the oil is thoroughly warmed before using the engine hard. If I lived in Phoenix, I would probably be using 20W-50! -enganear |
![]() | | #31 | ![]() |
| Not Ranked : 0 score I've gone from Mobil 1 to Royal Purple to PP and now I'm at Eneos. Perhaps I'll go back to PP, but I got a good deal on the Eneos so why not try? |
![]() | | #32 | ![]() |
![]() Join Date: May 2008 Location: Central California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score I only use Amsoil. Currently using 5w-30 and got a great oil analysis after 8k miles. Blackstone labs recommended I go 9k and get another analysis done. On all my cars, I usually change the filter at 5k and oil every 10k. I'm gonna try the Amsoil European 5w-40 next. Alot have had excellent results with that oil. The $10 preferred customer deal is the way to go. Saves money if you order more than $80 worth of stuff. Amsoil has been in Automotive Synthetic Lubricant business longer than anyone. I've personally used them since 1987. |
![]() | | #33 | ![]() |
![]() Join Date: Mar 2008 Location: Victoria TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 405
Groans: 70
| Not Ranked : 0 score Thats what i use,ive got no smoking problems
__________________ Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW! |
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
![]() | | #36 | ![]() |
Groans: 45
| Not Ranked : 0 score now i was doing some reading and see that "Shell Rotella T Syn" is a group III synthetic? i'm trying to read up on all the groupings but cant' find a good read. because its a group III does that make it not as good as other synthetics? |
![]() | | #37 | ![]() |
![]() | | #38 | ![]() |
| Lurkers
Posts: n/a
| Amsoil really is the best |
![]() | | #39 | ![]() |
![]() Join Date: Jun 2008 Location: Lynchburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
Would that be the QS Ultra Premium full synthetic? | |
![]() | | #40 | ![]() |
![]() Join Date: Apr 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 247
| Not Ranked : 0 score IMO changing your oil more frequently with this car is more important than what oil....but was recommended from my MAZDA dealer from day 1 to use Mobil1(thats what they use at the dealership)....i have from 600 miles and no issues and NEVER smoked....i think any good synth would be fine and for that matter probably Castrol GTX as well, my normal oil of choice all years prior ...but i do believe that synth is better for a turbo car.
__________________ Current.. 2009 BMW 135i Twin Turbo, Sedonna Red Metallic, M Sport Pkg, Premium Pkg, Cold Weather Pkg with heated seats, Xenons,M Sport steering wheel, BMW Factory Sport Exhaust..300hp, 300 Tq.. in reality..320 hp 320 tq stock SOON: BMS JB3....tune, ICarbon rear diffuser, ....all under warranty... . Past/Sold...2007 MazdaSpeed3,CP-E TBE, CAI, Advan Rs Gunmetal, TWM STS with bushings TWM Desert Eagle shift knob,, Defi Amber boost gauge, HKS BOV with CP-E flange..also tried CP-E Nano SRI (MazdaSpeed CAI, Rota TQ Hyperblack, are FOR SALE 4 months old) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/what-synthetic-oil-works-best-mazdaspeed-3-a-18303/ | ||||
| Free PSP ISO Downloads EUR PSP ISO & CSO Downloads | This thread | Refback | 05-02-2012 07:56 AM | |
| Street Performance - Page 70 | This thread | Refback | 02-11-2012 10:12 PM | |
| Oil Information Thread - TorontoMazda3 | This thread | Refback | 04-28-2009 05:14 PM | |
| Oil Information Thread - TorontoMazda3 | This thread | Refback | 03-26-2009 11:55 PM | |
| Free oil changes for 2 years, should I switch to synth? - TorontoMazda3 | This thread | Refback | 01-04-2009 12:43 PM | |
| From Cow to Crankcase: Synthetic oil from animal fat | Haltech | Automotive News | 0 | 12-03-2008 03:50 PM |
| Synthetic oil really needed? | gsrtype1 | MazdaSpeed 3 - Engine, Transmission & Driveline | 61 | 11-13-2008 07:05 AM |
| Two More 'Gas Savers', Synthetic Oil, Greasing Universal Joints: Mike Allen's Weekly Online Auto Clinic | Haltech | Automotive News | 0 | 07-10-2008 11:10 AM |
| Two More 'Gas Savers', Synthetic Oil, Greasing Universal Joints: Mike Allen's Weekly Online Auto Clinic | Haltech | Automotive News | 0 | 06-10-2008 02:12 AM |
