(Thread Starter) | Not Ranked : 0 score Spare block ~ $1,000 (note: this is optional, and you can get the $$ back when you sell your stocker) Pistons, Rods, Bearings, gaskets, studs ~ ??? Machine Costs: Machine Shop #1 - $35 to clean the block - $60 to hone the cylinders - $120 to bore & hone the cylinders - $225 for basic 3 angle valve job - $35 for micro-polish on the crank bearings - $85 for grind + micro-polish on crank (if a grind is needed) Machine Shop #2 - $50 to clean the block - $20 / cyl to just hone cylinders - $25 / cyl to bore & hone cylinders - $250 for basic 3 angle valve job - $25 for micro-polish on the crank bearings - $90 for grind + micro-polish on crank (if a grind is needed) So looks like mine will be around $355 - $465 (best case - worst case) *** Hardware Choices *** Pistons: CP, $525 Wiseco, $499 Rods: Pauter, $799 Carillo, $??? Carillo only come with 20mm wrist pin size, and have may have to be honed out to 20.5mm to mate with some pistons (like the wiseco). I believe CP makes a piston that fits them without any modifications. I'm going with Wiseco pistons & Pauter rods. I'd prefer to go with the Carillo's but don't want to bother with the pin mis match, and to be quite honest, the Pauter's are going to be more than i'll ever need. *** Preparing the block for Machine work *** SU Mark did a great job chronicling the break down of the MZR: http://www.mazdaspeedforum.org/forum/foru...-no-56k-19727/ I pretty much just followed what he did exactly, and though some of his instructions are "brief", it's only cause there is no real difficulty in removing the parts. It's actually very relaxing and fun! Some additional tips: - Use 3 hardend M10 - 1.5 x 75mm bolts to attach the motor to the engine stand. There are other non-threaded holes you can use for bolts with a nut if you want to use the 4th arm, but be sure not use the holes that are part of the oil pan cause that has to come off anyway. - Take this plate off before you mount the motor to the engine stand, cause you have to remove it when you take the crank off last, and it's a pain to take off after the fact: - Take lots of pictures of assemblies before you remove parts, so you know how to put them back on lol. If anybody needs any pics or wants me to take some of a certain part just pm me. I literally have everything in my garage. - Some odd tools you'll need: * You need a Torx for fuel injector holders (i'm not exact size, was just in a kit i had) * A breaker bar will be your best friend for several things. I used it while taking off the clutch and pressure plate (put 2 bolts back in make sure breaker bar is only against the bolt head, not the threads): Also used the breaker for the head & main studs. Seriously those things were torqued to like 300 ftlbs lol. Mark mentioned how tough they were, so i went ahead and just brought out the big guns: * The head studs use a 12mm 12 point socket. Don't try to use a 6 point you'll round the head. - When you turn the motor over to work on the oil pan and crank etc, watch out for left over coolant and oil that will spill out of the block. I had my gf put a trash bag under the top of the block as i turned it over to catch all the left over stuff. Worked great. - Pressing out the pistons took a lot more force that i was expecting. On the last one i had my gf catch the piston as i tapped the rod end with a plastic screw driver handle & a hammer. Didn't have to tap hard at all. - Lastly, don't lay the crank down on it's side. Either stand it up on end, somewhere where you won't trip over it, or lay it back in the main bearings, so that it's supported on each bearing. Otherwise it could warp. That's pretty much it for tearing down the long block. It's alot of fun really, and a breeze to do on motor stand. I highly suggest anyone who's "into the motor" should do this. You learn how everything works and get to see things first hand like the PCV baffling, coolant fan, oil pump, chain tensioners etc etc etc. It was awesome! *** Sending the block off for Machine work *** Specs: *** Other things to consider doing while block is out of car *** Clutch: Port work (head, int mani, etc): 3 or 5 angle valve job: Cams: BSD: *** Reassembly of the long block *** Timing: - Do not leave the cam-alignment tool on while loosening the crank pulley bolt. It can fall off and damage the exhaust cam. - Mark's thread will come in handy for sure ![]() - Torquing the hardware is VERY VERY IMPORTANT. Here is a quote from our own brain child Lex that explains the proper method:
*** Installing the new motor *** Through the front, top or bottom? I have never done this before, so any tips and tricks anyone has would be MUCH much appreciated, not just for me, but for everyone else down the road who builds. So if you guys want, just start posting up tips & opinions on hardware. Right now i'm leaning towards Wiseco pistons and Pauter rods. I've heard that the Wiseco pistons handle higher temps much better than the competition, and the Pauters are the only rod that accommodates the larger wrist pin size. *** up next, hardware selection and machining specs ***
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com Last edited by djuosnteisn; 01-21-2010 at 11:27 AM. | |
| The Following 48 Users Say Thank You to djuosnteisn For This Useful Post: | 06Speed6 (12-23-2009), 11cruzito11 (12-21-2009), 6-Speed-6 (12-26-2009), 8.5MS3 (12-22-2009), 802MS3 (12-21-2009), aaronc7 (12-21-2009), AmillieMS6 (12-21-2009), Andrew85 (12-22-2009), AndyMS3 (01-26-2010), aviator79 (12-21-2009), bioevolve (12-22-2009), BudUMfan (12-21-2009), cld12pk2go (07-15-2010), DaleNixon (12-23-2009), danesti (12-21-2009), Deadman (12-27-2009), DSIT995 (01-22-2010), flyrevs2 (12-21-2009), GQ_WhiteMS3 (12-21-2009), gsrtype1 (12-21-2009), holeinmypocket (12-24-2009), IshiKage (12-23-2009), JacksonMS30 (07-15-2010), jracer (04-28-2012), kgb (12-22-2009), madvillain (12-21-2009), masskaos (01-15-2010), meatball18 (12-23-2009), memin (07-25-2010), mexicant (12-21-2009), MKTMS3 (12-22-2009), mpsanger6 (12-22-2009), MPSdriver (12-24-2009), ms3077 (01-12-2010), NJSPEED3 (12-28-2009), OMGWTFHAX (01-19-2010), RayRayBauder (12-22-2009), sleeper329 (01-14-2010), Smoker6 (12-21-2009), SoyBean (12-21-2009), speed23 (12-21-2009), SpeedSixxx (01-22-2010), the_caruch (07-15-2010), tmtbiker (12-27-2009), toprock (12-22-2009), Vinnie (01-21-2010), wakeboarddude (12-27-2009), xSP33Dx3x (01-15-2010) |
Rep Power: 414 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score Sounds like fun. I enjoy keeping up with your adventures
__________________ ![]() |
| The Following User Says Thank You to fjames For This Useful Post: | djuosnteisn (12-21-2009) |
| Not Ranked : 0 score i would do the carillo rods like yochi. you can have the pistons and or rods machined for any wrist pin size. but +1 for the wiseco pistons
| The Following User Says Thank You to superskaterxes For This Useful Post: | djuosnteisn (12-21-2009) |
Groans: 370
| Not Ranked : 0 score do it, would be epic |
| The Following User Says Thank You to aaronc7 For This Useful Post: | djuosnteisn (12-21-2009) |
| WOT @1k RPM! ![]() Join Date: Jul 2009 Location: SoCal
Rep Power: 7299 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,432
Groaned at 50 Times in 33 Posts
| Not Ranked : 0 score If you plan on doing a complete how to on a full engine rebuild I would start a thread and reserve.... oh like the first 5 posts to your own thread. That way once you hit the message limit on the first post you can continue it in the next until you are complete. Then use your last post as a QA for all the good questions that come up and get answered. That way all the good info is all up in the first 5 (or so) posts.
__________________ MazdaSPEED3 2009 - Mica Black http://www.mazdaspeedforum.org/forum/forum/f8/setting-avatar-new-users-other-noobs-43712/ http://www.mazdaspeedforum.org/forum/forum/f8/uploading-adding-images-your-post-43704/ No BB URL code = sux |
| The Following 2 Users Say Thank You to NRSpeed For This Useful Post: | djuosnteisn (12-21-2009), holeinmypocket (12-24-2009) |
![]() Join Date: Mar 2008 Location: orange county
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,807
Groans: 137
| Not Ranked : 0 score ya buddy... do it. that would be great.
__________________ 2008 STi Intake Turboback AP |
| The Following User Says Thank You to danesti For This Useful Post: | djuosnteisn (12-21-2009) |
QA is a great idea. Right now i have alot more Q's than A's though.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | NRSpeed (12-22-2009) |
![]() Join Date: Sep 2009
| Not Ranked : 0 score Woohoo!!! Can't wait to see it! |
| The Following User Says Thank You to jus10 For This Useful Post: | djuosnteisn (12-21-2009) |
![]() Join Date: Oct 2008 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,083
Groans: 365
Groaned at 594 Times in 575 Posts
__________________ Mazdaspeed |
| The Following User Says NO Thank You to AmillieMS6 For This Un-useful Post: |
![]() Join Date: Jul 2009 Location: Baltimore, MD
Rep Power: 253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 157
| Not Ranked : 0 score This is a great idea. Could you also keep track of all your costs so we can get an idea of what budget is needed to tackle this project.
__________________ 2009 MazdaSpeed3 | True Red 35% Tint CP-E Engine Mount - CP-E XCel Intake - COBB AP - CP-E TMIC |
| The Following User Says Thank You to FearUndersteer For This Useful Post: | djuosnteisn (12-21-2009) |
![]() Join Date: Jul 2008
Rep Power: 1790 ![]() Thanks: 2,239
Groans: 62
| Not Ranked : 0 score Do it Dustin You can never have enough of something like that. Even, with mine there already. |
| The Following User Says Thank You to MarkyMark For This Useful Post: | djuosnteisn (12-21-2009) |
![]() Join Date: Jan 2009 Location: Columbus Ohio
Rep Power: 1087 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,958
Groans: 27
| Not Ranked : 0 score Don't forget what J Jackson just taught us on the cdfp
__________________ 08 CB MS3 Sport Sold 01 MX-5 (Project) 03 P5 (DD) |
| The Following 2 Users Say Thank You to cpolly69 For This Useful Post: | danesti (12-21-2009), djuosnteisn (12-21-2009) |
![]() Join Date: Jul 2008 Location: Forest Hills, NY
Rep Power: 352 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 104
| Not Ranked : 0 score Great Idea
__________________ ![]() 2003 E39 ///M5 |
| The Following User Says Thank You to yoichi For This Useful Post: | djuosnteisn (12-21-2009) |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
| Not Ranked : 0 score doit
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB |
| The Following User Says Thank You to aviator79 For This Useful Post: | djuosnteisn (12-21-2009) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score I would love to have a spare to build! No limitations on time or sacrificing my DD I would be in for this as well. +1 on the build write-up! |
| The Following User Says Thank You to ATAZ For This Useful Post: | djuosnteisn (12-21-2009) |
(Thread Starter) | Not Ranked : 0 score I guess for starters, it's time to strip down the long block. I've got two 3-day weekends coming up, so i'll prob start in a couple days. Lot's of pictures will be taken, and i already have a few questions, but i'll wait till i get there.
![]() Join Date: Sep 2008 Location: Soledad, CA
Rep Power: 446 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 393
Groaned at 5 Times in 2 Posts
| Not Ranked : 0 score do it man. |
![]() Join Date: May 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 50
Groaned at 30 Times in 15 Posts
| Not Ranked : 0 score Yes |
![]() | | #19 | ![]() |
![]() Join Date: Mar 2009 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
Groaned at 34 Times in 12 Posts
| Not Ranked : 0 score ive been waiting for this becuase i really want to do this and i need a true idea of what it all costs and what exactly needs to be done to make a successful build. Great idea!
__________________ 2008.5 Red Mazdaspeed 3 Performance Mods: OBX RP | SURE Intake | SU-TMIC | Cobb TIH | Turbosmart Hybrid BOV | JBR 80 Duro RMM | Hypertech Appearance Mods: 15% tint | Blacked-out Emblems, Side Markers and Side Reflectors Monitoring: Dashhawk |
![]() | | #20 | ![]() |
![]() Join Date: Mar 2008 Location: Virginia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 456
| Not Ranked : 0 score Yes please. Make sure to keep an exact tally of all the costs so that no one gets caught surprised mid build.
__________________ '06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s | CPE CAI, SU MM, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3 (not installed), GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler, DMH 3" exhaust cutout. |
![]() | | #21 | ![]() |
| Miembro ![]() Join Date: Jun 2008 Location: Puerto Rico
Rep Power: 420 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,095
Groans: 27
| Not Ranked : 0 score why wiseco over cp pistons? just curious
__________________ 2008.5 MS3 Metro Gray...slow |
![]() | | #22 | ![]() |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
| Not Ranked : 0 score If you want to be a sticky in the "how to section" then DO IT. Otherwise fade into obscurity, like all the others that think about doing something but decide not to act on it.
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. |
![]() | | #23 | ![]() |
Groans: 78
| Not Ranked : 0 score this is more than awesome, great idea and can't wait to see it finished!
__________________ [Precision 5557 T4 flanged Journal Bearing Turbo][Race Roots Ceramic Coated T4 Manifold][Race Roots 3" V-Band Catless Downpipe][Race Roots Under-Car FMIC kit][CXracing 18"x31"x3" IC Core][Tial 44mm EWG With 0.9Bar Spring][Cobb AP][Full Str33tunit Mount Set][Madvillain 4" Inlet/Intake][Cp-e xcelXL Maf Housing][Devilsown Meth Injection Kit][HKS Ignition Amplifier][Cp-e Catback Exhaust][HKS bov][PTP IM Spacer][Whoosh EGR Delete][AEM Digital Boost Gauge][Matt Damond OCC Kit][Trunk Mounted Optima Battery with KnuKonceptz Kit][Madvillain ECU box][TWM Short Shifter][BC Coilovers][Cobb Rear Sway Bar][Falken Azenis rt615's][Eibach Pro 25mm Spacers] |
![]() | | #24 | ![]() |
![]() Join Date: Apr 2008 Location: Atlanta, GA
Rep Power: 334 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 247
| Not Ranked : 0 score Just a thought would be to put the how to focus on the items that are unique to the MZR DISI engine. Such as the DI injectors. The special service tools needed for doing the timing. Uninstall/install into the engine bay. Installing the piston rings, rods, bearings, etc are standard for any engine build and there are probably 100s of how to books on this. This would definitely be very interesting how to no matter what direction you take it. |
![]() | | #25 | ![]() |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3771 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
| Not Ranked : 0 score awesome idea! cant wait for pix |
![]() | | #26 | ![]() |
![]() Join Date: Jul 2009 Location: Vancouver, BC
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score That'd be cool, these cars are rarer than M3 BMWs up north here so, There ain't alot of JY examples sitting around for me to pluck bits from and try stuff. Can anybody answer this for me: Is the regular 3GT 2.3 using the same block and crank as our car? |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score I remember reading somewhere that they handle heat expansion better than other upgraded pistons. I'll confirm this though to be sure. I still believe somewhat that heat on the face of the piston can be an issue, especially with stratified fueling, where the injection occurs in a smaller area than the whole combustion chamber. It seems like it would let the outer portion of the piston heat up more than the inside, and possibly create some issues. Definitely not a fact, just a gut feeling.
![]() | | #28 | ![]() |
| Not Ranked : 0 score Well I never got a hold of a spare engine so im thinking of pulling it and doing this myself as well. Thou this would only be possible with help on here, but Ive got to get it built, but I only want to do it once so I want to do it right. Ive been keeping my eye on this thread as well: GI: CNC mains/girdle but I have to do this on a budget. However I already have a bad ass upgraded head ready to on so I wont have to budget anything else for that. Main issue is I still dont even know how to pull the engine out the top and thats how its got to come out...I plan to do this in jan/feb after I get it back from the insurance company...
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score I think with a few friends and a hoist, it won't be too terrible going in & out the top. Motor is actually really light IMO. Getting it out of my jeep was a breeze. I'm definitely going to be porting the head, but i kinda want some input from the brains on here. I'm not sure how ridiculous this is, but i think it would be cool to port both runners for each cylinder into one big runner. And then compliment this with a knife edge on the intake mani & of course vcts delete. Then just port the IM gasket same as the head. I have no clue where coolant lines run in the head, and i'm not sure i have the $$ to drop 1k on DCR's head porting, though it looks soooo damn beautiful. Also, does the exh ports have to be enlarged to compliment the int ports? 06speed6 i know you have these flow rate tatood on the back of your hands, care to share?
| The Following User Says Thank You to djuosnteisn For This Useful Post: | KoukiS14 (12-23-2009) |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Im going to get a hoist and figure out how to do it. I dont think it will flow well if you do that. At the most V the head and have the only 1 runner in the IM(/cyl obv). I bet if you had DCR do you head it would cost more than $1000 as you would at least need to have the DCR valve adjustment added per their requirements. They certainly ported their intake runners more than the mine were done, but I dont think i will have an issue with my goals, thou I still wish mine were gasket matched. I know I may have to do some work to get them to match the IM that is being made, but im hopping that is a small issue that possibly could even be dealt with thru trimming the phenolic or whatever they used gasket to make it a smooth transition. But other things were done to the head to help flow as well. I certainly think the exh ports need to be enlarged also, but I have nothing to base that on other than the fact that mine were done just as DCR is doing. I figured I could have done some of the PnP myself but I just took the easy route. This is what was done to the head: Justice racing in Winchester VA built the head and the PnP work was done by Headgames. -Ferrea Custom Valve train -CompPlus intake and exhaust valves -Turbo spring valve -Titanium retainers -Spring seat locator -Billet Valve locks -Custom Manganese/Bronze valve guides -Intake and exhaust valve stem seals for custom guides -CnC porting done to the intake and exhaust side, as well as a fair about of bowl blending and a performance valve job. Now another person that had his head, IM and TB flow tested is CorpusSpeed on Mazda6club. For reference here are the flow test stuff. I already posted pics of the head here: Kriebs SPD Intake Manifold Project! EDIT: I suggest COMBINIG the MazdaSpeed 3 - Engine, Transmission & Driveline w./ the MazdaSpeed 3 - Engine, Transmission & Driveline and if needed make 2 subforums for transmission and driveline, but the engines are the SAME. So now we have some good threads here and some lost over there...needs to be addressed and fixed.
| The Following User Says Thank You to aviator79 For This Useful Post: | djuosnteisn (12-22-2009) |
![]() | | #31 | ![]() |
![]() Join Date: Nov 2008 Location: Alexandria, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 413
Groans: 40
Groaned at 27 Times in 21 Posts
| Not Ranked : 0 score I have been curious about this. How much? What parts are available? What is involved? Looks like this thread will be a catch-all. Thank you bro!
__________________ CP-E SRI / Forge BPV / Corksport TP / Corksport CBE |
| The Following User Says Thank You to toprock For This Useful Post: | djuosnteisn (12-22-2009) |
![]() | | #32 | ![]() |
| Not Ranked : 0 score Do it with lots of pics DJ. The recipe is similar for most engines with the little tricks that make the difference. You also have to remember that the level of the build depends on your requirements. An all out race motor is different from a street motor. Here's where the choices come from. Clearances, component choices, etc etc etc. Are you set on the VTCS delete? |
| The Following User Says Thank You to Lex For This Useful Post: | djuosnteisn (12-23-2009) |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have two manis so it would be easy to swap back and forth. Only cons against the vtcs delete that i know of right now are: - decreased idle air velocity, and potential rough idle, but noone has confirmed this yet. - decreased swirl. I don't fully understand the role that the flappers play with vertical swirl, and i'm not 100% how necessary it is at higher air flow (wot) situations. pro's are: - obvious room for gasket matching and porting. - removal of the lump that holds the vtcs rod on cylinder 1. - a better match to a ported head, which i do definitely want to do. As far as hardware, i've got a few emails out right now to several companies, just asking general questions. Kinda like the dating game, where i ask all of them why i should choose them lol. I think the carillo rods are available with the stock wrist pin size now (or can be honed to it), and i'm interested in the Pro-H series: 4 PRO-H MA-23DISI>-65927S 3/8 CARR 5.927 150.55 0.858 21.79 0.859 21.82 2.1667 55.034 22mm 4 PRO-H MA-23DISI>-65927H 3/8 WMC 5.927 150.55 0.858 21.79 0.859 21.82 2.1667 55.034 22mm 4 PRO-SA MA-23DISI<SA-65927H 3/8 WMC 5.927 150.55 0.858 21.79 0.859 21.82 2.1667 55.034 22mm Their catalog claims stock pin size is 22.5mm, is this right? So carillo's come with smaller pin size? I'm confused on the bolts though, mainly the difference between H-11 steel (WMC) and multiphase (CARR). I'll research more tomorrow.
![]() | | #34 | ![]() |
Groans: 78
| The Following User Says Thank You to madvillain For This Useful Post: | djuosnteisn (12-23-2009) |
![]() | | #35 | ![]() |
![]() Join Date: Apr 2008 Location: Utah
Rep Power: 573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 120
| Not Ranked : 0 score Also you can have your bearings coated with dry film lubricant |
| The Following User Says Thank You to JumpingJackson For This Useful Post: | djuosnteisn (12-23-2009) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Yes the exhaust ports need to be matched to the intake ports, from the factory the intake flow to exhaust flow ratio is near ideal and it is good to try to maintain that same ratio. BTW, I am CorpusSpeed6 on 6club.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | djuosnteisn (12-23-2009) |
![]() | | #37 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score I like the WPC treatment better than films for lubricity and oil retention. I do like the idea of removing the divider on the manifold and head ports to make one big port, with the divide pushed further down into the head port. That's how most modern heads are. I think our head port design sucks in comparison to lots of other designs out there. |
| The Following User Says Thank You to KoukiS14 For This Useful Post: | djuosnteisn (12-23-2009) |
![]() | | #38 | ![]() |
| Not Ranked : 0 score lol WHAT!!! holy fuck this all makes sense now!!! haha
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner Last edited by superskaterxes; 12-23-2009 at 07:57 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Im feeling that I would prefer to find a cheep engine as you did Dj. How much did you pay? PM me if you want. I think it would be silly to do this to my perfectly working engine so if I can find one for cheap enough I would prefer going that route as Im finally getting my car back on the road and would like to keep it that way while I build the block. 06Speed6, I guess previously I knew that you were CorpusSpeed from your location, but from being off this forum and on 6club only for so long I forgot. Wow, you certainly are more active over here. Great info over when you know who’s posts to read. So you got that head installed? Any comments on the work that was done to mine (above)? This is the first car I have modded so...
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score I paid under 1k for the complete long block, with a gob of extras. Seriously the deal of the century.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | danesti (12-23-2009) |
| Lutz lays out his strategy for GM advertising: "Memorable," "clever," "viral" [w/VIDEO] | Haltech | Automotive News | 0 | 08-04-2009 09:40 AM |
| Chrysler reveals more facets of "We Build" campaign | Haltech | Automotive News | 0 | 05-08-2009 08:50 AM |
| Saudi government bans "lewd" personalized license plates including: "SEX," "ASS," and "USA" | Haltech | Automotive News | 0 | 04-14-2009 01:40 PM |
| Strange But True: Honda Motor Co. reportedly denied trademark for "Acura RL" | Haltech | Automotive News | 0 | 03-12-2009 08:00 AM |
