![]() Join Date: May 2014 Location: Topeka, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
(Thread Starter) | Not Ranked : 0 score It bothers me driving around like this, knowing my car isn't "right", but my part didn't come in today (or my local Mazda dealership just decided to not call me because they're dicks) and it's looking like it's going to be next weekend at the earliest before I can fix it. Should I have any concerns about this in the interim? I hadn't planned on going and doing any hot-rodding, but still.. Also, I need an AP so I can get rid of the factory tune. How many cocks does one guy have to suck to get one of those fucking things? Fuck!
__________________ 2006 Mazda Speed6; bone stock with 115k as of 06/01/14 |
![]() Join Date: Sep 2012 Location: Phoenix, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
Groans: 89
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score I just did mine. It went from seeping to puking in less than a week. I would top off the fluid and just watch it closely. Carry some fluid with you and the tools to loosen and tighten the fill plug. If it pukes, top it off at a gas station or parking lot and then drive it home and park it. |
(Thread Starter) | Not Ranked : 0 score Fuck me sideways. That's why I really wanted to do it this weekend.
![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
| Not Ranked : 0 score @ItsNox; drove with his leaking for quite awhile, however as stated above sooner rather than later. It's a pretty straight forward job, didn't take too long.
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() |
| The Following User Says Thank You to ms6mil For This Useful Post: | ItsNox (06-09-2014) |
(Thread Starter) | Not Ranked : 0 score I'm assuming this is why the lot detailed the engine bay before selling me the car. Makes perfect sense. So...no fucking clue how long it's been leaking. I bought some gear lube to carry with me just in case. I'll check levels ASAP. Hopefully the part arrives Monday....
![]() Join Date: Aug 2008 Location: Oxford, PA
| Not Ranked : 0 score Yeah just get it done you'll feel better about it. Did mine a few months back and it is a pretty easy job. I was worried about low fluid also so I filled it but it only took half a quart after about a month of leakage. Decided to do it myself when Mazda quoted me $400 to fix it.
__________________ 06 Speed 6: Cobb SRI/ TIP, AP stage 2, CS TB, CP-E FMIC, Forge BPV, Cp-e rear mm. TT FMM, AT internals, Freek tuned on 50% e85. |
(Thread Starter) | Not Ranked : 0 score Just realized I bought GL5, to boot. Jebus fucking Christ.
Groans: 307
| Not Ranked : 0 score $400 for an 1.5 hrs work. screw them thieves.. OP just in case you haven't seen this already... MS6 Fluid Notes & DIY Pictures
(Thread Starter) | Not Ranked : 0 score Yeah, dealerships can suck it. I've got that page, as well as one with a how-to for seal replacement (I know, it's easy. I like pictures and I'm mechanically retarded) pulled up and ready to go. Debating whether I try this after work or not. It makes me uneasy waiting. It's filthy as a mother fucker on the driver's side of this whore.
Groans: 89
| Not Ranked : 0 score Go get motorcraft XT-M5-QS The motorcraft fluid is fucking unicorn blood. |
| The Following User Says Thank You to Big Dog For This Useful Post: | ArmanRus (06-07-2014) |
(Thread Starter) | Not Ranked : 0 score lol
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
Like ms6mil mentioned...its an easy fix. Just make sure you read through the walk-through and its comments a few times. And clean the fuck out of everything around it. You don't want that grime in your trans. Sent from my SPH-L710 using Tapatalk
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() | |
(Thread Starter) | Not Ranked : 0 score The wait is killing me. Hopefully mazda calls today about the part. Any idea if unicorn blood is carried in stock or not? I might as well flush and refill while I'm at it. God only knows when that was done last. Thinking I'll do the same with coolant when I replace my thermostat that seems to be stuck open.
On a side note I just remembered that I had my transfer case resealed under warranty and they refilled the trans fluid so that would explain my extended mileage with the pivot seal leak.
(Thread Starter) | Not Ranked : 0 score Yeah, I'm kind of nervous about mine. Just called and the seal isn't fucking in yet. They said they do have the XT-M5-QS in stock though. $21.xx/qt. Fuck my ass with a yard stick.
Groans: 89
| Not Ranked : 0 score Honestly $21 a quart is not bad. You'll need 3 quarts. |
(Thread Starter) | Not Ranked : 0 score Ah, it's fine. At least I'll know I'm good there for a while. I'll probably go ahead and flush the coolant also, and I'll change the oil to top off the "I'm fucking broke now" sundae.
| Not Ranked : 0 score mine was just dripping a little bit or it was what i though....after i had to replace a tranny bearing, i realised that the tranny missed about 1 quart out of 3. I can't say it was the complete cause of the bad bearing but it wouldn't help for sure... So watch it.
| The Following User Says Thank You to Jeff23spl For This Useful Post: | ItsNox (06-10-2014) |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score Mazda fucked orders up so my part STILL isn't in. Tomorrow, they said... Jesus fuck.
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score All done. XT-M5-QS goes in Wednesday after a flush. Shit was dirty as a $2 whore.
| HOW-TO: shaft pivot seal replaced | jrzy ms6 | MazdaSpeed 6 - How-To's | 287 | 08-18-2018 07:47 PM |
| MS3 Shaft Pivot Seal Replacement | jmen73 | MazdaSpeed 3 - How-To's | 9 | 06-22-2015 11:19 PM |
| Shifter Pivot/Seal Fix? | Gru_Nuts | MazdaSpeed 6 - How-To's | 8 | 11-08-2014 12:03 PM |
| I think it called a shifter pivot seal | nospeed | MazdaSpeed 6 - How-To's | 39 | 04-19-2013 12:51 PM |
| Shaft pivot seal useless tip | paveltol | MazdaSpeed 6 - Engine, Transmission & Driveline | 1 | 07-11-2012 03:48 PM |
