![]() Join Date: Jan 2011 Location: Atlanta, Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 207
(Thread Starter) | Not Ranked : 0 score So I just had a new OEM clutch and Fidanza lightweight fly wheel put in my 2006 MS6. So I picked the car up and one of the first things I noticed was the clutch is now super light/soft compared to before. Is this normal? Corey
__________________ 2006 Mazdaspeed6 Autotech Internals | ETS TMIC | Cobb AP | JBR Tru-3.5" Wide Path Aluminum | JBR RMM | JBR TMM | JBR PMM | JBR Short Shift Plate | Fidanza Flywheel | TWM Weighted Shift Knob | Hawk HPS 5.0 Pads | Techna-Fit Brake Lines | RedLine Fluids and Unicorn Blood | NGK 1 Step Colder | Damond OCC | TurboSmart Duel Port | CP-e SafeSeals | JBR TIG | JBR TBG | Damond EGR Delete Miltuned!!! Ready to Install ATP Downpipe ![]() ![]() |
![]() Join Date: May 2013 Location: Summerville, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 184
| Not Ranked : 0 score Try bleeding the slave cylinder. Make sure you don't have any air in the lines. Or you could try replacing the slave cylinder.
__________________ 2009 CWP Mazdaspeed3 - COBB AP V3 - Richtune - 50/50 E85 - Autotech HPFP Internals - CNT Catless Downpipe - HTP 3" Intake - NGK One Step Colder Plugs - - Kozmic Motorsports EGR Deletes - JBR 88 RMM/TMM/PMM - JBR Shifter Bushings - JBR TIG + Coolant Bypass - JBR OCC - - JBR RSB - GroundControl Coilovers - CorkSport Camber Plates - CorkSport Rear Camber Arms - CorkSport Rear Toe Arms - - WhiteLine Front Endlinks - WhiteLine Bumpsteer Kit - WhiteLine Poly LCA Bushings - AWR Rear Endlinks - - 18x8 Mazdaspeed MS-01S - Nitto NT05 245/40/18 - |
(Thread Starter) | Not Ranked : 0 score Only thing is that its easy to shift gears and it does not feel spongy. Its just not as stiff as my old clutch. I was wondering if it could be I had a version 1 clutch since mine was an early 06 and now I have a later version. Especially since Mazda reworked the clutch and issued a TSB due to clutch engagement point and pressure profile. Here is the TSB I am referring to: TSB: 05-003/07
__________________ 2006 Mazdaspeed6 Autotech Internals | ETS TMIC | Cobb AP | JBR Tru-3.5" Wide Path Aluminum | JBR RMM | JBR TMM | JBR PMM | JBR Short Shift Plate | Fidanza Flywheel | TWM Weighted Shift Knob | Hawk HPS 5.0 Pads | Techna-Fit Brake Lines | RedLine Fluids and Unicorn Blood | NGK 1 Step Colder | Damond OCC | TurboSmart Duel Port | CP-e SafeSeals | JBR TIG | JBR TBG | Damond EGR Delete Miltuned!!! Ready to Install ATP Downpipe ![]() ![]() Last edited by zer010gic; 03-15-2014 at 05:52 AM. |
| Not Ranked : 0 score Reading the TSB it sounds like they revised the pressure plate. If you did have the original design then it's likely the new pressure plate that is giving you a softer pedal feel.
| The LuK clutch with Fidanza Flywheel Combo | CaseyBueno | Mazdaspeed3/6 General Discussion | 22 | 05-14-2015 08:30 AM |
| Soft Clutch? | SRHTX | 2010 MS3 - Engine, Transmission & Driveline | 1 | 10-15-2013 02:09 PM |
