![]() Join Date: Nov 2010
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Found The Answers to some 1. Is the speed3 Crank Forged?? YES 2. How much HP can a Speed3 crank take before breaking?? 3. Is there a crank that can hold upto 700ish HP other then the Billet one for $3400?? 4. other then the rod journals being bigger on the speed 3 crank will the crank fit a mazda3 2.3L??? YES it bolts right in!! The rods journals are bigger on the speed3 Crank Any help would be awsome Last edited by relenger; 12-19-2010 at 08:22 AM. |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Not Ranked : 0 score Yes its forged, and I dont think we know the limit cause nobodys busted one. Not sure about your other questions. |
| Not Ranked : 0 score The rod and main journals on the ms3 crank are both larger and the ms3 crank may have a bigger stroke, I cant remember what the stoke is for the 2004 2.3l The ford ranger 2.3l crank was/is forged and should a bolt in.
(Thread Starter) | Not Ranked : 0 score Accourdint to my Mazda speed3 spec sheet (right from Mazda who sponsors are schools race speed3s) Its showin the mains as the same size as the mazda3..... the rods look to be bigger but no big deal. Looks like the crank throw is also the same.... HHHmmmm??????? |
| Not Ranked : 0 score The speed 3 crank specs: The block/girdle ID is ~58.42mm or ~2.3" The crank main OD is 2.045" Crank main available width on crank .835" Crank main bearing width .747" Main bearing thickness ... I forgot to get... I think its ~.115" but im prolly wrong. Rod ID 2.16" Crank rod OD 2.045" Rod bearing width .655" Rod bearing thickness .055" Rod bearing available room on rod .78" Rod bearing available width on crank .665" Those are approximate because every crank and bearing is slightly different.
(Thread Starter) | Not Ranked : 0 score Thanks for the info... Any guys with 600hp steet driven car? |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| Not Ranked : 0 score .................................................. ..........why not just buy a speed3............................................ ........... |
| The Following User Says Thank You to TRex For This Useful Post: | BrianZX10R (11-23-2010) |
| Banned ![]() Join Date: Feb 2010 Location: Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 500
Groans: 132
Groaned at 166 Times in 92 Posts
| The Following 3 Users Say Thank You to MS33SM For This Useful Post: |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
| The Following 2 Users Say Thank You to m4tic For This Useful Post: | Dash08 (11-28-2010), SIXual Panda (12-19-2010) |
| Not Ranked : 0 score I think a guy called Cagey has one.... Wait, no, nevermind. He just wanted one. Sent from my iPhone using Tapatalk
| The Following 3 Users Say Thank You to Dano For This Useful Post: |
![]() Join Date: Mar 2010 Location: Athens GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 491
Groans: 214
Groaned at 114 Times in 83 Posts
| Not Ranked : 0 score Xtremeboost is suppose to be bringing us a 600 hp one....
__________________ |
(Thread Starter) | Not Ranked : 0 score I could care less how stuff is spelled... So 600 must be a hard number to reach?? |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score this far i think cagevet has only gotten ~550 and i think he only did it once. but i stopped checking that thread a while ago because theres too many posts in it for me to care anymore lol. if you're ambitious enough though, i say go for it.
__________________ 2008 true red MS3 |
(Thread Starter) | Not Ranked : 0 score We are We are.... The speed3 is direct cylinder injection right?? How are you guys tuning? Handheld? |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
| The Following User Says Thank You to Tomas For This Useful Post: | neotide87 (11-29-2010) |
| The Following User Says Thank You to relenger For This Useful Post: | Tomas (11-29-2010) |
Groans: 132
| Not Ranked : 0 score I usually tune my car using a harmonica cause I'm tight like that. It may be the reason my g string is a little flat when I go wot. |
| The Following User Says Thank You to MS33SM For This Useful Post: | Tomas (11-29-2010) |
![]() | | #19 | ![]() |
![]() Join Date: Nov 2010 Location: NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 530
Groans: 68
![]() | | #20 | ![]() |
![]() Join Date: Feb 2010 Location: OH & NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,558
| Not Ranked : 0 score eye kan haz inglish lezzonz? aye |
![]() | | #21 | ![]() |
Groans: 68
![]() | | #22 | ![]() |
I see this must be a kiddie forum?? Im not here to talk trash or be a a$$ hole to anyone. Simple questions... if you cant answer them then please dont bother to post... | |
![]() | | #23 | ![]() |
![]() Join Date: Dec 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29,434
Groans: 40
| Not Ranked : 0 score yes...we iz kiddiez 4um. You want answers tho, be an active part of the community, you get out what you put in here. If you're not willing to do that...go fuck yourself and good luck finding info elsewhere.
__________________ | Steedspeed Top Mount Mani | Precision BB 5857 | Perm Tuning 3.5" Intake | Perm Tuning 2 Piece DP | Perm Tuning PCV Plate and Vented Catch Can | Mishimoto Catch Can | Weisco Pistons | Pauter Rods | AWR Tranny Mount | CP-e RMM | Turbinetech FMM | Turbinetech FDM | CP-e RDM | CX Racing FMIC | TWR Short Shifter | JBR SSP | AP w/ Base Map | BLOWN MOTOR | | 1974 Nova | SBC 350 | TH350 | Weiand Team G | Edelbrock 1406 | Aluminum 4 Core Radiator | Pro Comp HEI Distributor | |
![]() | | #24 | ![]() |
| Not Ranked : 0 score 24 and 61k...now whose dick is bigger? |
![]() | | #25 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score Something is wrong on the internet. |
| The Following User Says Thank You to overdrift For This Useful Post: | 06Speed6 (12-02-2010) |
![]() | | #26 | ![]() |
![]() | | #27 | ![]() |
![]() Join Date: Jul 2010 Location: Austin, TX
Rep Power: 877 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 200
| Not Ranked : 0 score I don't think he gets it. 1. He thinks he's doing pretty well for himself considering his lack of spelling skills. (Hell, maybe he is; I'm not sure I know anyone else who can't spell to compare salaries to.) 2. He does't take to dick-ish sarcasm very well. Welcome to the forum buddy. Now DONATE!
__________________ 2009 CWP MS3 SportBuilt Motor and Twinscroll T3 35r - 415WHP/400WTQ - 93 Pump Gas, No Meth - Mustang Dyno Custom Tubular Manifold - HTP 3.5" Intake - 3" V-Band TBE - Custom COBB FMIC - COBB EBCS - COBB 44mm WG - KW V2 Coilovers SOLD! 2008 Toyota Tacoma TRD Sport 4x4 |
![]() | | #28 | ![]() |
Pointless, as is this thread and when did i say " He thinks he's doing pretty well for himself considering his lack of spelling skills"??? Imagine if i could spell.. "2. He does't take to dick-ish sarcasm very well." Grow up!! do you see your parents talking like retards to one another?? Im here to help a local mazda3 guy get his car together!!! i think im donating RIGHT there!! i could care less about a speed3!! i got two SRT's that are faster in stock form then a modded speed3... Im not big into getting grocerys Last edited by relenger; 12-03-2010 at 06:28 AM. | |
| The Following 2 Users Say NO Thank You to relenger For This Un-useful Post: | I Love Brownies (12-07-2010), tbot (12-03-2010) |
![]() | | #29 | ![]() |
![]() Join Date: Apr 2010 Location: BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,102
41000 hahahaha I pay that in taxes little fella | |
![]() | | #30 | ![]() |
![]() | | #31 | ![]() |
| Not Ranked : 0 score 1. the amount of dough it would take to make a n/a speed remotely fast would greatly exceed that of a stock speed 3...and it would still be slow 2. maybe he realizes the value of a speed 3 and because he understands the value of items is the reason he has so much money 3. fuck off brownie |
| The Following 2 Users Say Thank You to TRex For This Useful Post: | Cataphract_40 (12-06-2010), SIXual Panda (12-19-2010) |
![]() | | #32 | ![]() |
![]() Join Date: Oct 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,548
Groans: 30
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks |
![]() | | #33 | ![]() |
| meh, no ideas ![]() Join Date: Dec 2009 Location: St.Louis MO
Rep Power: 201 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
| Not Ranked : 0 score oh dear lol lets move on....im not much help but the highest ive seen personally is jwilkens88 on here who dynoed 410 i believe on stock internals ..... oh and btw dont take anything personally on here. welcome and GL......oh and one more thing, its cool if you wanna go for a NA-T Mazda 3 its cool to be different lol
__________________ 89 toyota supra 1JZ Twin Turbo---Sold 2006 MS6 GT few mods ---Sold Monaco White '13 Genesis 2.0T R-Spec-- ISIS downpipe/testpipe, Agency Power CBE, Injen SRI, Forge BOV, JBR Heavy Shift knob should be 240ish wheel right now, tune coming April 27th |
![]() | | #34 | ![]() |
![]() Join Date: Dec 2008 Location: VA Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 930
| Not Ranked : 0 score Maybe you should try posting this on mazdas247.
__________________ 06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block... 08 Speed 3|SOLD |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score I found a local guy who is big into mazda's. Thank you to all the guys who helped |
| The Following User Says Thank You to relenger For This Useful Post: | 06Speed6 (12-07-2010) |
![]() | | #36 | ![]() |
![]() Join Date: Jun 2010 Location: Santa Fe NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,637
Groans: 371
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score I got ahold of a speed3 Crank and it bolted right in!!! |
| Power at the crank - after tuning | bcmps | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 2 | 08-17-2009 09:11 AM |
| Crank gear & BSD info | 06Speed6 | Mazdaspeed3/6 General Discussion | 85 | 04-04-2009 10:19 AM |
| Crank case filter? | Element | MazdaSpeed 3 - Engine, Transmission & Driveline | 4 | 03-09-2009 07:37 PM |
