 Old 03-19-2009, 05:02 AM   #1
Qluber's Avatar
Posts: 267   (View Stats)
Qluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud ofQluber has much to be proud of
Default KR and Colder Plugs
So I have been entertaining the thought of running 1 step colder plugs. My question is for you guys with Dashawks and other monitoring devices, are you seeing a significant reduction in KR with 1 step colder plugs? With my basic mods, is it worth it? Please chime in
08.5 BLACK MICA GT,
CP-e CAI,
Black Forge bov
DEBADGED
Magnaflow Catback
Corksport Test Pipe
TRZ Rear Mount
1 Step Colder NGK's
Qluber is offline   Reply With Quote
 Old 03-19-2009, 09:32 AM   #2
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
Generally speaking I think colder plugs will prevent pre-ignition, but not so much detonation. I went 1 step colder and didn't notice a difference in KR.
Seafoam to clean out the carbon deposits made a difference. As did fixing boost/vacuum leaks, as did pulling timing w/ the standback, as did water injection.
New spark plugs probably will not cure the KR.
2006 Lotus Elise: Toy car
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
 Old 03-19-2009, 09:54 AM   #3
Qluber's Avatar
Thanks for your input, where are the most common vacuum leaks?, I agree about the Seafoam, man these cars run rich, and rich equals carbon build up..............
08.5 BLACK MICA GT,
CP-e CAI,
Black Forge bov
DEBADGED
Magnaflow Catback
Corksport Test Pipe
TRZ Rear Mount
1 Step Colder NGK's
 Old 03-19-2009, 11:09 AM   #4
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
do a pressure test and make sure everything is sealed.
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 03-19-2009, 11:21 AM   #5
toprock's Avatar
Posts: 749   (View Stats)
toprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the world
Groans: 40
Groaned at 27 Times in 21 Posts
how do you do a pressure test?
CP-E SRI / Forge BPV / Corksport TP / Corksport CBE
toprock is offline   Reply With Quote
 Old 03-19-2009, 11:23 AM   #6
kingpin748's Avatar
Posts: 2,611   (View Stats)
Groans: 78
I didn't notice much change going to colder plugs.
I don't have leaks either.
In reality I love lenny
kingpin748 is offline   Reply With Quote
 Old 03-19-2009, 11:29 AM   #7
ChrisK's Avatar
Posts: 1,168   (View Stats)
ChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the world
Groans: 56
I used something like this on my old DSMs. Was like $15 to build at Lowes.
You have to have an air compressor or access to one. Connect that to do turbo, or you could probably get away with hooking it up to the turbo inlet. Then pump air into it and try to get to 10psi + on the gauge. And then listen for leaks.
here's a build thread.
http://www.dsmtuners.com/forums/arti...ternative.html
ChrisK is offline   Reply With Quote
The Following 2 Users Say Thank You to ChrisK For This Useful Post:
Crossbow (03-19-2009), glocK23 (03-19-2009)
 Old 03-20-2009, 06:31 AM   #8
wassup61's Avatar
Posts: 1,232   (View Stats)
wassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the world
TERRIBLE for your turbo bearings, but it works. Colder plugs work to reduce pre-ignition due to advanced timing for a more controlled burn. Denso is the way to go, either ITV22 or ITV24, as they come pregapped.
Jeff at PG
All wagon, No traction
wassup61 is offline   Reply With Quote
 Old 03-20-2009, 06:44 AM   #9
Qluber's Avatar
Jeff at PG
aren't the NGK's much cheaper, and you can get them from AutoZone..
08.5 BLACK MICA GT,
CP-e CAI,
Black Forge bov
DEBADGED
Magnaflow Catback
Corksport Test Pipe
TRZ Rear Mount
1 Step Colder NGK's
 Old 03-20-2009, 07:17 AM   #10
ThEsHoCkEr's Avatar
Posts: 457   (View Stats)
ThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond repute
Groans: 68
I think they are a little bit cheaper, but the densos come pregapped like wassup said.
2010 Dodge Ram Hemi
1967 Camaro RS/SS
2008 Caliber SRT-4 (SOLD)
2008.5 MS3 GT (R.I.P.)
ThEsHoCkEr is offline   Reply With Quote
 Old 03-20-2009, 07:23 AM   #11
Qluber's Avatar
well heck, I have a feeler guage..............
08.5 BLACK MICA GT,
CP-e CAI,
Black Forge bov
DEBADGED
Magnaflow Catback
Corksport Test Pipe
TRZ Rear Mount
1 Step Colder NGK's
 Old 03-20-2009, 07:25 AM   #12
ThEsHoCkEr's Avatar
Groans: 68
Feel away then
2010 Dodge Ram Hemi
1967 Camaro RS/SS
 Old 03-20-2009, 07:29 AM   #13
bnoon's Avatar
Posts: 1,770   (View Stats)
Just be forewarned, it's MUCH MUCH harder to gap platinum tipped plugs than it is standard plugs. You may end up bending one of the electrodes and rendering the plug useless. What works for me is tapping the ground strap with a small body hammer while holding the plug in my other hand. If I go to far, a micro-screwdriver between the ground strap and the threads (being careful to not crack the porcelain insulator).
For me, 1 step colder and 93 octane and no knock at all.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
 Old 03-20-2009, 07:32 AM   #14
NEC
The NGKs come with a larger gap so you have to bend the ground to an angle to get it to the right gap. The denso come with a smaller gap (you still have to set the gap yourself, they are NOT pre-gapped correctly) but you can keep the ground at an optimal angle.
Now I've had both NGK and Densos in mine (they're cheap and I'm a mod slut, I like to try everything) and I didn't notice a difference between the two.
 Old 03-20-2009, 07:37 AM   #15
mazdaj's Avatar
Posts: 369   (View Stats)
mazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the worldmazdaj is the leader of the world
its been said many times, but i cannot stress it enough to check all your boost tubes and vacuum connections. the other day i redid all of my vacuum lines for my boost gauge because i my stft/ltft's were out of wack and i knew i had a leak somewhere.....i skipped over the boost tubes because i thought they were trivial and i tightened them a few months ago....well, after resetting the ecu, i was still getting wacky fuel trims (25+- stfts) so i looked over it last night and low and behold my cold pipe tube was practically falling off and my the hot side was loose as well as the turbo inlet was pretty loose....again, evenif it seems dumb or obvious, just double check you work......
mazdaj is offline   Reply With Quote
The Following User Says Thank You to mazdaj For This Useful Post:
Qluber (03-20-2009)
 Old 03-20-2009, 07:41 AM   #16
mazdaj's Avatar
subparpunk, what is the proper gap for the spark plugs, you say the densos are not pregapped? .30 -.32 is what haltec says in the spark plug sticky, is this good?
 Old 03-20-2009, 07:43 AM   #17
bnoon's Avatar
.30 is what I've done and had no knock or blowout.
2002 BMW M3 - Sold!
The Following User Says Thank You to bnoon For This Useful Post:
mazdaj (03-20-2009)
 Old 03-20-2009, 07:56 AM   #18
NEC
My ITV-22s were just a little off, and I have mine gapped to whatever is in the sticky.
The densos might be advertised as pre-gapped, but I did a check and found them to be gapped just slightly higher than reccomended in the sticky so I closed 'em up a little. They will probably run with the slightly larger gap, but ehhh I wanted 'em right
The Following User Says Thank You to subparpunk03 For This Useful Post:
mazdaj (03-20-2009)
 Old 03-20-2009, 07:58 AM   #19
mazdaj's Avatar
cool thanks, do u use one of those little 1 dollar discs from autozone to measure your spark gap or is there something more accurate to use?
 Old 03-20-2009, 08:08 AM   #20
wassup61's Avatar
Technically you arent supposed to gap iridium plugs at all. I called Denso, and was told that if the gap isnt where its supposed to be (.029-.032) to send it back for a new one. The Densos are pre-gapped, and just need to be checked with a FEELER GAUGE not a disc.
Jeff at PG
The Following 2 Users Say Thank You to wassup61 For This Useful Post:
mazdaj (03-20-2009), subparpunk03 (03-20-2009)
 Old 03-20-2009, 08:13 AM   #21
NEC
hmmmmm...... interesting.
 Old 03-20-2009, 08:26 AM   #22
Qluber's Avatar
I have gapped iridiums before on previous cars, just take your time and don't get in a hurry, or try to adjust too much at once.............
08.5 BLACK MICA GT,
CP-e CAI,
Black Forge bov
DEBADGED
Magnaflow Catback
Corksport Test Pipe
TRZ Rear Mount
1 Step Colder NGK's
1step colder or 2 step colder plugs, need to decide which plugs before tune day(by CHURCH) johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 8 12-13-2008 04:17 PM
HKS spark plugs installed *2 steps colder than stock whoosh@Realtune MazdaSpeed 3 - Engine, Transmission & Driveline 17 10-02-2008 02:15 PM
1 step colder plugs - stutter in 3rd bova MazdaSpeed 6 - Engine, Transmission & Driveline 55 08-19-2008 07:02 AM
Page generated in 0.42770 seconds with 29 queries
