![]() Join Date: Aug 2019
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Of course Rock Auto say's they fit, the manufacture say's they fit, so far everything I found say's they will fit but there are difference's that are making me question it. |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Oh my god. Please stop using apostrophes. They are very rarely appropriate, and only in instances where you are trying to show possession (e.g. "That chain guide was Peter's.") or contract a word together with "is" (e.g. "That is a chain guide." --> "That's a chain guide."). If we rewrote your post without the apostrophes you added, it would read as follows:
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| The Following 3 Users Say Thank You to Vansquish For This Useful Post: |
| Not Ranked : 0 score Sum people just don't no how two use proper spelling and grammar these daze.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | MSMS3 (08-31-2019) |
Groans: 60
| Not Ranked : 0 score Don't care what rock auto says, send them back. The oem parts are not overpriced, buy them.
![]() Join Date: Jun 2009
| Not Ranked : 0 score Cloyes makes really good timing parts. I’ve used their gears and chains in race engines for decades. But if they don’t fit, it’s a waste of time and money.
(Thread Starter) | Not Ranked : 0 score Well I am sure they will bolt on and fit, they are just pretty different then OEM so I wanted to see if anyone else was running them but I decided not to dick around with em and sent them back and got OEM like everything else. |
| The Following User Says Thank You to broncomitch For This Useful Post: | MSMS3 (09-03-2019) |
I would not go with anything other than OEM for a Mazdaspeed 2.3L engine without more information to confirm fit. But, that would not be because there is anything wrong with Cloyes by brand. I'd want to check directly with Cloyes for fitment before taking the chance that the vendor has it listed incorrectly.
| Not running after timing chain replacement | YetyFromMaNety | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 25 | 06-15-2016 11:35 AM |
