![]() | | #81 | ![]() |
![]() Join Date: Feb 2010 Location: NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,089
| Not Ranked : 0 score EJ7Z-6303-B OEM Can get the Ford Racing model for about $70 more shipped. Was all set on getting one then discovered this. https://www.focusst.org/forum/focus-...-oem-ford.html Last edited by dagrimey1; 03-13-2019 at 10:38 AM. |
![]() | | #82 | ![]() |
![]() Join Date: Mar 2016
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score abdul yamucu, owner of the 750+ speed6 is using the EB crank, dont know how many miles but hes making power, also for the oil pump, its guarantee fit no problem or that either, dont know if its an upgrade since oil passages seems a little bit bigger |
![]() | | #83 | ![]() |
Groans: 111
| Not Ranked : 0 score We have forum members here using the 2.3EcoBoost crank.
![]() | | #84 | ![]() |
| Not Ranked : 0 score I was trying to release some stress to dagrimey1 because i did also heard about some using it, and, by deduction, if it don't work, it won't take 20 000miles to figure it out so it should be a win. But there is nothing like a solid confirmation,can you tag them if they want to confirm it here ?
![]() | | #85 | ![]() |
| Not Ranked : 0 score So last night reached out to MS friends all over via the social media and got confirmation on my questions. No one could tell me the difference between the Performance model and OEM, but it seems everyone is using the OEM one and it's holding strong and handles gobs if power. Can't believe I using Tapatalk again! |
![]() | | #86 | ![]() |
Groans: 111
| Not Ranked : 0 score @Fstrnyou ?
![]() | | #87 | ![]() |
| Not Ranked : 0 score I'm still on OE crank and oil pump. Those are the only 2 things I heard an EB part would work in its place, but no first hand accounts.
![]() | | #88 | ![]() |
![]() Join Date: Nov 2009
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score If the crank fits, does that mean we can use an ecoboost piston/rod/wrist pin set so long as they are all 3 EB? This opens a lot of piston/ rod options, including the RS pistons with steel ring lands,.. |
![]() | | #89 | ![]() |
| Not Ranked : 0 score have you read the thread or just the last post ?
![]() | | #90 | ![]() |
![]() Join Date: May 2018
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score Alright guys, reviving a dying thread. Has anyone been able to locate the EB cranks lately at their normal OE pricing? The only ones I'm finding seem to be the Ford Performance ones that cost twice as much |
![]() | | #91 | ![]() |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
| Not Ranked : 0 score You wanna crank? I hais one.
__________________ |
![]() | | #92 | ![]() |
| 2015 Ford Mustang EcoBoost | Haltech | Automotive News | 0 | 05-16-2014 10:30 AM |
| 2015 Mustang to get 250hp EcoBoost I-4 | anavrinIV | Automotive News | 5 | 08-30-2012 11:20 AM |
| Rumormill: Ford reviving Mustang SVO with 300 hp Ecoboost four | Haltech | Automotive News | 1 | 07-03-2008 09:38 AM |
