Like Tree12Likes
 Old 12-30-2016, 03:18 PM   #41
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
where do you get that price from msm for $60 gen2 pistons?
that fucking RS short block is a steal.
See attached. (note the rings are $115)
Yes, it is a steal. The Mazda assembled short block is $1800 (my price, MSM), so it's about the same price and a way better engine.
2007 Mazdaspeed3 GT
 Old 01-01-2017, 11:33 AM   #42
nindoja's Avatar
Posts: 2,395   (View Stats)
I think that's $60/piston, not $60/4 pistons.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 01-01-2017, 03:17 PM   #43
MD1032's Avatar
Groans: 143
It says "piston set" very clearly.
2007 Mazdaspeed3 GT
 Old 01-01-2017, 04:14 PM   #44
SaveMelMac's Avatar
Posts: 485   (View Stats)
It's one piston
 Old 01-01-2017, 04:42 PM   #45
MD1032's Avatar
Groans: 143
Originally Posted by SaveMelMac View Post
It's one piston
No, it clearly says "piston set". Where's your proof?
2007 Mazdaspeed3 GT
 Old 01-01-2017, 05:44 PM   #46
SaveMelMac's Avatar
Set is refering to the wrist pin and piston. Hence "set"
blackms3_71 likes this.
The Following 3 Users Say Thank You to SaveMelMac For This Useful Post:
impossible (01-01-2017), nindoja (01-01-2017), torquemaniac (01-01-2017)
 Old 01-01-2017, 05:58 PM   #47
torquemaniac's Avatar
Posts: 733   (View Stats)
Thats the price for one piston/pin set...I knows cause I bought 4 a couple months ago
See the Jim Ellis listing here (it state that 4 are required) : PISTON SET. PISTON, CRANKSHAFT & FLYWHEEL (2300CC) made by Mazda. #L3Y411SA0
2011 CX-7 AWD 2.3 turbo
 Old 01-01-2017, 06:06 PM   #48
MD1032's Avatar
Groans: 143
Thanks for the clarification. It's still worth noting that a set of 4 mzr pistons is less costly than a single EcoBoost piston
2007 Mazdaspeed3 GT
impossible (01-01-2017), SaveMelMac (01-01-2017)
 Old 01-05-2017, 06:05 AM   #49
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Since the guys at SP63 started to play with 2.3EcoBOost engines a while ago, I asked them on failbook about using these parts in 2.3DISI-T engines. They gave a very short an concise answer: "None!".
Well... in this case we may very well import the whole engine into this platform.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-05-2017, 06:14 AM   #50
MD1032's Avatar
Groans: 143
I do not understand what you are saying. Perhaps there is a translation error somewhere. Are you saying SP63 believes none of the ecoboost parts are compatible? I don't believe importing the entire short block as a unit would work because the turbo bracket and oil feed and drain lines are likely different. Modifying it to work with our parts would probably not be worth it.
2007 Mazdaspeed3 GT
 Old 01-05-2017, 06:19 AM   #51
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
basically the rod being 52mills shorter with Mazda piston would reduce compression by 1 point 9.5 to 8.5 or 10.5 to 9.3...not sure if it would be safe to shave that much on the block height for the sleeve and timing chain and will it worth the savings ? Do a shorter rod can reduce engine harmonics if the stroke remain the same ?
i'm more concern about the crank itself to know if it can fit or not on each ends with our accessories? OR using the whole short bloc
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 01-05-2017, 06:24 AM   #52
I wouldn't use the block (my opinion). For some reason Ford decided to change it to an open deck design. Makes no sense to me because the 2.0 still uses a closed deck. The mustang guys have lots of issues with losing head gaskets around 450-500whp. My guess is the cylinders are moving around on them. Livernois makes a deck insert but that's not cheap.
 Old 01-05-2017, 06:42 AM   #53
MD1032's Avatar
Groans: 143
I agree. The open deck was probably adopted for cooling advantages at the lower power levels, but I wouldn't trust it at the power levels we typically operate at with forged internals.
Why would you use the MZR pistons with the EB rods? The point is to swap out the entire piston-rod combo for an Ecoboost equivalent unit, which would keep the overall length of the assembly the same but hopefully down the road lower the cost of parts for us. Otherwise it would just make more sense to use MZR rods. You definitely don't want to lower compression with these engines IMO. 9.5:1 is low enough.
I do question the harmonics part of it. I wonder how the EB parts would play with our balance shaft unit.
2007 Mazdaspeed3 GT
phate (01-06-2017)
 Old 01-05-2017, 06:46 AM   #54
mituc's Avatar
Groans: 111
To be honest all I want from the 2.3EcoBoost engine is the head, eventually without the cam shafts. This will open our 2.3DISI-fTw platform for a lot of injector options, manifolds (eventually a twin scroll exhaust manifold), the awesome factory intake manifolds from ford, and so on. the short block itself is pretty solid as is (or can be made very solid with only rods, pistons and bearings), I'm not sure we need any 2.3ecoboost part.
 Old 01-05-2017, 06:52 AM   #55
I'm actually looking into this already. I need to see if I still have a headgasket laying around that I can lay over one of the EcoBoost ones we have at work. If the coolant and oil passages line up then the only other concern is for the timing cover to line up as well. Everything else can be adapted over I think.
Right now I am hopeful. If this works it means we have larger injector options and HPFPs that are full E85 compatible possibly.
Dennisms3 likes this.
Jeff23spl (01-05-2017)
 Old 01-05-2017, 07:22 AM   #56
Jeff23spl's Avatar
It was because they look at it for an economical option but you and others said MZR pistons are a lot cheaper so it may not worth it unless you mix it...But i agree i would pay the 200$ extra to get the Ford pistons.
I'm curious to know if it is better to have a shorter rod with longer piston or the oppposite...It would change the rotating angle so it would probably affect the blance shft efficiency too...Do they have the same kind of BS in the EB ?
Wife drive 2010 CX7
 Old 01-05-2017, 08:59 AM   #57
nindoja's Avatar
I seem to remember hearing that the coolant passages on the head are different, making a direct swap of the head not possible. If you need a used head gasket, I can drop one in the mail to ya.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
Mazdazilla6 (01-05-2017)
 Old 01-05-2017, 09:07 AM   #58
I've got one of my blocks at work. I'm gonna go run back to the build area and see how the EB head gasket lays on that.
My biggest concern is the fuel system. I don't think we have enough space in the engine bay to carry over our HPFP because it moves to the exhaust cam. And I don't think we can use the EB HPFP because it uses a solenoid on the HPFP for the relief valve to dump fuel back into the low pressure side. So without a mechanical relief or a way to control the electronic relief we don't really have any options that I can think of.
 Old 01-05-2017, 09:37 AM   #59
MD1032's Avatar
Groans: 143
Well, ours works the same way. Our spill valve runs off a duty cycle set by the ECU to dump fuel back to the low pressure side based on the pressure setpoint. The real problem is that the EB pump spill valve probably won't respond the same way as ours if it was driven by our ECU (could be different duty cycle or voltage). Who knows, maybe it would still work. After all, we put internals that move 50% more fuel into the same housing and our ECU's don't seem to mind at all.
If you have a block at work, do you have any way of verifying the crank compatibility? The person I reached out to about donating one for science never responded to my message and I don't trust my ability to verify that they are the same for all intents and purposes. It's a shame because we stand to gain a lot from being able to use EB cranks since ours cost around 4 times as much.
2007 Mazdaspeed3 GT
impossible (01-05-2017)
 Old 01-05-2017, 10:26 AM   #60
Yes but there's no mechanical relief valve on the EB stuff. I see that as an issue since I'm guessing their ECU can control fuel pressure a lot more precisely.
Yea I can, you'll have to send me a set of main bearings though.
Also, head gasket lines up but covers up a lot of water jackets. It's strange because the deck is nearly identical to ours.
 Old 01-05-2017, 03:11 PM   #61
Jeff23spl's Avatar
pictures ?
Wife drive 2010 CX7
 Old 01-05-2017, 04:55 PM   #62
jbywaters's Avatar
Posts: 20   (View Stats)
jbywaters has a spectacular aura aboutjbywaters has a spectacular aura about
At the end of the day it would be convenient if these parts worked.. but c'mon, do you really wanna rebuild your mazda to be driving a ford lol
jbywaters is offline   Reply With Quote
The Following User Says NO Thank You to jbywaters For This Un-useful Post:
WetzMS3 (01-06-2017)
 Old 01-05-2017, 08:20 PM   #63
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Guess you've never seen any FoMoCo stamps on your car yet....
silvapain and Wcdfmt510 like this.
The Following 4 Users Say Thank You to Etipp98 For This Useful Post:
MD1032 (01-06-2017), monkey.bones.007 (01-07-2017), sharksinspace (01-06-2017), WetzMS3 (01-06-2017)
 Old 01-05-2017, 11:02 PM   #64
Probs never opened the hood.
Sent from my Pixel XL
MD1032 (01-06-2017)
 Old 01-06-2017, 06:08 AM   #65
zenit's Avatar
Posts: 1,364   (View Stats)
imma leave this here:
https://forum.miata.net/vb/showthread.php?p=8100140
WetzMS3 likes this.
-feejay
-wetzel
 Old 01-06-2017, 08:11 AM   #66
MD1032's Avatar
Groans: 143
This thread is why I offered to send a crank to an engine builder in the community, since they look visually compatible, but the thread is ultimately useless because no measurements were taken. The snout and pilot bearing area are potential areas of incompatibility.
Now it looks like @Mazdazilla6; will accept my offer. So hopefully I will be sending him a crank and Mazda main bearings, and possibly other goodies for inspection. Honestly I just want the community to have a cheap crank option because I am sure lots of engines will be showing up on the used market in the coming years with spun bearings.
2007 Mazdaspeed3 GT
Mazdazilla6 (01-06-2017)
 Old 01-06-2017, 10:13 AM   #67
That pretty much settles it. I haven't looked at the bottom end stuff in months but it's not a surprise to me. Still should check pilot hole. My biggest reserve was the snout diameter, since we know it's the same now then things are looking pretty good.
I also made a list of what I think would be needed to fit an ecoboost head onto our shortblock. I thiiink it's fairly doable without much hassle.
monkey.bones.007 (01-07-2017), zenit (01-06-2017)
 Old 09-09-2017, 06:11 PM   #68
adamsjus1's Avatar
Posts: 10   (View Stats)
adamsjus1 will become famous soon enough
I'm sitting here thinking wait... Ford claimed that the 2.3 turbo motors used the same 6speed as the v8's did.... Which would mean that there is a tranny option if i where to 2.3 mzr swap a miata... Am interested now.
I wish my speed6 sounded like a RS tho... Factory exhaust in those things are pretty good.
adamsjus1 is offline   Reply With Quote
 Old 11-07-2017, 12:46 PM   #69
Djohns's Avatar
Posts: 3,944   (View Stats)
So did anyone find out if the cranks are okay to use?
2010 black mica speed3
Soon:built motor
 Old 11-08-2017, 02:33 PM   #70
ajkulish's Avatar
Posts: 412   (View Stats)
ajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the world
Groans: 40
Groaned at 15 Times in 12 Posts
Update after 3k on built motor, Ecoboost oil pump is holding up great.
2006 Mazdaspeed 6 VRM
GTX3076r|Manley Pistons+Rods|AEM WMI|PnP Head|ACT 6 puck+Streetlite|COBB AP|Dramatuned|CorksportTBE|Autotech Internals|Forge v1|JBR Mounts|H&R Springs
RIP - 2007 Mazdaspeed3 GT 22V
COBB AP+SF+TIH|E30 tuned by Mark Gibson|H&R Springs|eBay Downpipe|CXRacing FMIC|KMD+Aviva|SU RMM|TurboXS Hybrid|TWM Base Bushings|Masonvi Knob
ajkulish is offline   Reply With Quote
 Old 11-11-2017, 03:26 PM   #71
Djohns's Avatar
Originally Posted by mister.speed3 View Post
Would you recommend this set up?
Well he did say it’s holding up great.....so what does common sense dictate?
Soon:built motor
The Following 3 Users Say Thank You to Djohns For This Useful Post:
ajkulish (12-05-2017), MD1032 (11-11-2017), Varomnia (11-11-2017)
 Old 11-11-2017, 07:24 PM   #72
Varomnia's Avatar
Posts: 459   (View Stats)
I don't think it's holding up well at all, it's not engineered to hold much weight at all, pumping however, i'm sure it's doing a fantastic job. Kidding aside, very interesting thread.
Edit: Something meaningful to add if it hasn't already been added. Ecoboost has been having some issues with their headgaskets at 20-22 psi. So, wouldn't necessarily recommend that part specifically. https://drivetribe.com/p/ford-focus-...T_eDel9ZAllzfw
 Old 11-11-2017, 08:46 PM   #73
mituc's Avatar
Groans: 111
We can't use their head gaskets anyway because the water passages differ in location and size. Also, a head gasket from an open deck block will not fit a closed deck block like ours, and it's also suspected that the open deck design may be part of the problem.
 Old 04-07-2018, 08:44 AM   #74
tmillner's Avatar
Posts: 621   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
So I guess I'm going to be the first try this aren't I...
Sent from my SM-N950U using Tapatalk
UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC
tmillner is offline   Reply With Quote
 Old 04-07-2018, 09:38 AM   #75
MSMS3's Avatar
Posts: 2,830   (View Stats)
What "this" are you going to try? Lots of different Ecoboost 2.3 parts being discussed in this thread.
 Old 04-07-2018, 09:48 AM   #76
tmillner's Avatar
Reply didn't show up right, was replying to someone asking about the crank. Really the only part that matters out of all the parts.
 Old 04-09-2018, 02:08 PM   #77
nindoja's Avatar
It's been done. It is a direct fit. Chris @ Speed Solutions recommends them for people with destroyed cranks.
Jeff23spl likes this.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
Db09ms3 (04-09-2018), Jeff23spl (04-09-2018)
 Old 04-09-2018, 02:10 PM   #78
tmillner's Avatar
You just made my damn day sir
 Old 03-13-2019, 06:25 AM   #79
dagrimey1's Avatar
Posts: 1,246   (View Stats)
Rehash I know internet murder me!
FML can't use my crank as I don't want to go with +1 sized bearings. I've read and seen about the EB crank but has there been sustainable miles on one of these cranks? I know KJ MZR is running kne from his Speed Solutions build be he doesn't have very many miles. Are their any other success stories? I rather not be a guinea pig.
Can't believe I using Tapatalk again!
 Old 03-13-2019, 09:23 AM   #80
Jeff23spl's Avatar
If the crank doesn't really fit, one will probably know in the first 100 miles....
dagrimey1 likes this.
Wife drive 2010 CX7
dagrimey1 (03-13-2019)
2015 Ford Mustang EcoBoost Haltech Automotive News 0 05-16-2014 10:30 AM
2015 Mustang to get 250hp EcoBoost I-4 anavrinIV Automotive News 5 08-30-2012 11:20 AM
Rumormill: Ford reviving Mustang SVO with 300 hp Ecoboost four Haltech Automotive News 1 07-03-2008 09:38 AM
Page generated in 0.61724 seconds with 38 queries
