| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
Groans: 113
(Thread Starter) | Not Ranked : 0 score I know the post is for the gen1 but its the same wire on the gen2's just different color. 7th wire from the top |
| Fuck sushi rolls ![]() Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,168
Groans: 356
| Not Ranked : 0 score no asshole.... 2 ecu connectors...one close to firewall one closest to front bumper. looking at the car standing in front of the front bumper look at the ecu connector closest....now look at the wire at the bottom left..... and count 7 wires up on the left most column...the 7th is the MAP wire
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE |
Groans: 113
(Thread Starter) | Not Ranked : 0 score stfu lenny I posted the instructions from Devil's Own on how to find the map wire. |
Groans: 356
| Not Ranked : 0 score u said from the top.........its from the bottom bottom is the front bumper. top is the firewall. go drink some more.....ive done enough of these kits to do them blindfolded.
![]() Join Date: Jun 2010 Location: Mandeville, Louisiana
Rep Power: 244 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 426
| Not Ranked : 0 score I appreciate both of your help in getting me set up. I used lenny's advice and the nigga knows his shit. I had taken the car out shortly after and everything worked perfect. On a gen2 the wire color is "RED" for map, just remember the bottom ecu connector looking from the bumper. Now look at the bottom left wire and count 7 up, tap it.
__________________ 2010 Mazdaspeed 3 Black Mica - Evo X Wheels(Enkei's 18x8.5 +38) - H&R Springs - CS SRI - CS TIP - CP-E TMIC - CNT DP - Turbosmart BPV - KMD Internals - Cobb AP - JBR 88 RMM - JBR EGR Delete + Block Off - 5k HID low beams - Maisonvi Shift Knob - JBR Shifter Bushings - JBR RSB - Ford Motorcraft Tranny Fluid - Rotella 5w40 Oil - Moog Front/Rear End Links. |
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score maybe you should post more information about your setup...cause maybe other gen2ers want to know and stuff cunt
__________________ |
Groans: 224
| Not Ranked : 0 score Fuck the MAP, the MAF signal wire is so much easier to find. FYMWN
Groans: 356
fyan
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE | |
| Approved MSF Vendor ![]() Join Date: Jan 2009
Rep Power: 229 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score Where is the map sensor on the motor? |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Not Ranked : 0 score got a pic? sorry i am beign lazy and i don't have one i can just walk out and look. |
Groans: 113
(Thread Starter) | Not Ranked : 0 score Just read it now Lenny, Glad it was resolved that pdf is still helpful though. |
| Not Ranked : 0 score Here's one ssinstaller took for me a while back..... |
| Not Ranked : 0 score Well thats not to hard to get to is it? |
![]() Join Date: Apr 2009 Location: LOUISIANA!! Football, Guns, Cars, Crawfish, and Beer
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 735
This post saved my install...
__________________ Traded | |
![]() Join Date: Jan 2009 Location: Newark, NJ
Rep Power: 1040 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,110
Groans: 661
| Not Ranked : 0 score So, which wire is it? You guys say 7th from the bottom but the one thats tapped in that photo is not the 7th |
| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
| Not Ranked : 0 score moar meth
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
![]() | | #19 | ![]() |
| Not Ranked : 0 score 7th do it
![]() | | #20 | ![]() |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
| Not Ranked : 0 score Well fuck i should have gotten this controller. My dvc-30 does whatever the fuck it wants to. This one uses a boost source vs a signal wire. EDIT: NVM im gonna rewire mine. |
![]() | | #21 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45885 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
| Not Ranked : 0 score Discuss here: Map wire for meth injection
__________________ 2 years after hitting 700hp and still running strong. Happy to see others joining the club. |
| Display Modes | |
| going pre turbo meth injection | dooderek | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 211 | 01-29-2014 11:20 AM |
| Map wire for meth injection | NJSPEED3 | 2010 MS3 - Fuel, Nitrous & Water Injection | 19 | 04-19-2012 12:05 PM |
| Meth injection troubles | Meder | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 21 | 05-16-2009 07:41 PM |
| Fuel Injection wire. | bioevolve | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 1 | 04-09-2009 06:50 AM |
| Water-Meth injection | EvilMonkey | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 08-06-2008 10:41 AM |
